Hjelp med PunBB
nja, fant ikke noe.
men leste dette på punBB:
3.3 - How do I add my own footer/header so that I can integrate my forums into design of the rest of my website?
For this purpose, PunBB has a simple template system. The template files are located in include/template/. There are five templates - main.tpl, admin.tpl, help.tpl, maintenance.tpl and redirect.tpl. The file main.tpl contains the template for almost all pages that are displayed in the forum, admin.tpl is the template for the admin interface, help.php is for the help screen, maintenance.tpl is the template for the message page that is displayed when the forum is put in maintenance mode, and finally the file redirect.tpl is used to display the redirect pages e.g. when logging in or when posting a message.
The templates contain variables that are replaced with actual content when a page is displayed. All variables in PunBB are enclosed in less-than and more-than signs (< and >). For example, the variable for the title of the forums is called <pun_title>. When PunBB displays the index page, it reads the file main.tpl and replaces <pun_title> with the title of the forums. There are 11 replacement variables in main.tpl.
If you want to customize the look of PunBB so that it fits the design of other pages on your website, it is primarily the template files you should edit. For example, if you wanted to add your own logo at the top of all forum pages, you would edit main.tpl and add markup for displaying your logo at the appropriate position in the file. It is possible to include PHP scripts from the templates. See the next FAQ entry for more info on that.
men jeg får ikke åpnet disse filene. hvorfor ikke :(
