Impreza_wrcsti Skrevet 14. april 2007 Del Skrevet 14. april 2007 Taken out Pentium D 3.2ghz and put in E6300. Reset the bios and nothing is overclocked but yet every time I am playing DCON (bf2) my system totally freezes. Do I have to reinstall windows xp when you put a new processor in? Any ideas what I am doing wrong? What should the voltage be for a stock e6300? How about voltage for the ram? TwinMOS DDR2 PC4200 x 2 http://www.komplett.no/k/ki.asp?sku=306870 Its currently at 1.8v. Does that sound right? This is the motherboard: http://www.komplett.no/k/ki.asp?sku=324695 Graphics card: HIS Radeon X1650PRO 512MB http://www.komplett.no/k/ki.asp?sku=327297 So any ideas what I have done wrong or could it just be a broken processor? Thanks in advance? Lenke til kommentar
AKIRAx77 Skrevet 14. april 2007 Del Skrevet 14. april 2007 (endret) Nevermind! But if you have a probem...a reinstall usually fixes it. AKIRA Endret 14. april 2007 av AKIRAx24 Lenke til kommentar
Impreza_wrcsti Skrevet 14. april 2007 Forfatter Del Skrevet 14. april 2007 (endret) Nevermind! But if you have a probem...a reinstall usually fixes it. AKIRA 8383499[/snapback] Ok thanks. Hoping that perhaps flashing the bios will help. Better support for the e6300 aparently. *Fingers crossed* Thanks again. UPDATE: System is running problem free now. Thanks alot! Endret 14. april 2007 av Impreza_wrcsti Lenke til kommentar
