grimsbo Skrevet 7. september 2007 Del Skrevet 7. september 2007 Noen som har ett nærkamps grep/teknikk for å komme seg løs fra en zombies hender eller eventuelt? Lenke til kommentar
Bytex Skrevet 7. september 2007 Del Skrevet 7. september 2007 Gylden regel: Du går ikke i nærkamp med en zombie. En liten rift i huden kan være nok til at du er dødsdømt etterpå. Lenke til kommentar
grimsbo Skrevet 7. september 2007 Del Skrevet 7. september 2007 Gylden Regel: Kunnskap er makt. Det er ikke noen detaljer som er for irrevelante. Lenke til kommentar
Cutthroat Bill Skrevet 7. september 2007 Del Skrevet 7. september 2007 (endret) Du tror altså ikke at en rotten kropp ikke produserer slike gasser bare fordi det er noe som styrer den? Den er jo like råtten som alle andre døde kropper, og råtner mer og mer hele tiden. Så det er bare logisk at slike gasser oppstår også i zombier. 9445771[/snapback] Det står følgende i guiden: When a human body dies, it's flesh is immediately set upon billions of microscopic organisms. These organisms were always present, in the external environment and within the body itself. In life, the immune system stood as a barrier between these organisms and their target. In death, that barrier is removed. The organisms begin multiplying exponentially as they proceed to eat and, thereby, break down the corpse on a cellular level. The smell and discoloration associated with any decaying meat are the bioligical process of these microbes at work. When you order an "aged" steak, you are ordering a piece of meat that has begun to rot, its formerly toughened flesh softened by microorganisms breaking down it's sturdy fiber. Within a short time, that steak, like human corpse, will dissolve to nothing, leaving behind only material too hard or innutritous for any microbe, such as bone, teeth, nails, and hair. This is the normal cycle of life, nature's way of recycling nutrients back into the food chain. To halt this process, and preserve dead tissue, it's necessary toplace it in an enviroment unsuitable for bacteria, such as in extreme low or high temperatures, in toxic chemicals such as formeldahyde, or, in this case, to saturate it with Solanum (zombie-virus). Altså vil ikke bakteriene som bryter ned kroppen kunne klare seg i en Solanum-infisert kropp. Om ikke dette er samme bakterie som som lager gassen, så må vi bare anta at også den bakterien ikke ville klare seg i en Solanum-infisert kropp. Endret 7. september 2007 av Cutthroat Bill Lenke til kommentar
Gjest Slettet-yzDjfSSl Skrevet 10. september 2007 Del Skrevet 10. september 2007 Det lureste er vel å dra med båt ut til en eller anen øy midt på havet, med dypt vann rundt, helst brådyp/undervannsklipper, og være der til zombiene har forsvunnet. Ha med vindmølle, og et dieselagregat som kan gå på planteolje vil lager på øya. Det må være en ferskvannskilde der, samt mattilgang. Zombier eksploderer jo av trykket på dypt vann? Lenke til kommentar
MrLee Skrevet 10. september 2007 Del Skrevet 10. september 2007 Om den skulle gjøre noe, så var det å implodere men en zombie har ikke lufta i lungene på samme måte som mennesker og tåler trykket meget mye bedre på grunn av det Lenke til kommentar
Konnis Skrevet 10. september 2007 Del Skrevet 10. september 2007 Morsom tråd, må følge med for flere tips Lenke til kommentar
Rabbid Skrevet 10. september 2007 Del Skrevet 10. september 2007 (endret) Den ultimate plan for å slippe unna zombies (og her regner vi ikke med å forlate planeten) må vel være å reise til en oljeplattform. Gjerne med en gjeng ingeniører og plattformarbeidere som kan holde greia i drift slik at man får olje til å produsere strøm. Slike plattformer er jo også ganske store så det er god plass til drivhus og gårdsdyr (et par griser f.eks), og man kan jo alltid koke saltvann fra havet for å drikke. Det er også veldig gode muligheter for helikopter på plattformer og man kan lett fly innover mot land og finne overlevende og forsyninger, samt å plaffe ned noen zombier med missiler. Vil helst finne den plattformen som står på det dypeste vannet slik at zombiene ikke har sjans til å komme seg opp, selv om de samarbeidet og sto på skuldrene til hverandre. Noen som har noe å si på denne planen? Kommer jeg til å overleve? Endret 10. september 2007 av IQ Lenke til kommentar
Konnis Skrevet 10. september 2007 Del Skrevet 10. september 2007 Den var ikke dum, IQ Mulig det hadde vært enda bedre å dra til en militær "oljeplattform", med våpenlager etc. Lenke til kommentar
Vrengtpolvott Skrevet 10. september 2007 Del Skrevet 10. september 2007 Likte virkelig idèen din IQ! Hadde faktisk kunne utspilt seg bra i et spill Lenke til kommentar
Cutthroat Bill Skrevet 10. september 2007 Del Skrevet 10. september 2007 IQ: Det der er en meget god plan. Uansett hvor dypt det er der plattformen står, så vil ikke zombier klare å klatre opp. Og de blir neppe så mange at du kan klatre oppå hverandre. For første så vil det trenges vannvittig mange zombier for å kunne lage en rampe som er... 40-60 meter høy? Og for det andre så kan ikke zombier som er i vann signalisere til andre sombier om hvor det finnes mat. Altså vil neppe mer enn 3-6 zombier prøve å komme opp. Med mindre man kan se plattformen fra land, da er det vel en mulighet at zombiene hadde tatt turen ut for å sjekke. Mat tror jeg ikke du trenger å tenke på da disse platformene ofte har mat for mange uker, om ikke måneder. Og da er det beregnet på ett stort mannskap. Er du alene eller med familie eller venner, så vil maten vare mer enn lenge nok vil jeg tro. Har du med deg ingeniører og plattformarbeidere så vil du som du sier få strøm, men også varme. Problemet da er jo at maten vil blir oppbrukt fortere, og det samme gjelder om du skal ha en eller to helikopterpiloter. Men joda, jeg tror så absolutt du ville overleve. Lenke til kommentar
Rata101 Skrevet 10. september 2007 Del Skrevet 10. september 2007 Litt konstruktiv kritikk Å komme seg til en oljeplatform er vel den ultimate planen, men satt i sammenheng blir det vel like realistisk for en gjennomsnittsperson å komme seg til en oljeplatform som å komme seg til en romstasjon (svak overdrivelse, men dog...). Man trenger helst 1 stk. helikopter + helikopterpilot (som er klar for å ta akkurat deg med) og ikke minst posisjonen til platformen. Hvis zombiekrisa allerede er i full gang, så kan det jo fort bli kinkig å få det til å klaffe. Alternativ 2 er vel å ankomme i båt, men hvordan kommer man seg opp på en 30-40 meter høy platform? I tillegg er oljeplatformer bemannet 24/7, så det er ikke sikkert at de som allerede er der har lyst på besøk... Lenke til kommentar
Rabbid Skrevet 10. september 2007 Del Skrevet 10. september 2007 I tillegg er oljeplatformer bemannet 24/7, så det er ikke sikkert at de som allerede er der har lyst på besøk... 9465533[/snapback] De har reist for å beskytte familier og venner Må vel få tatt med helikopterførerkortet, da får jeg ihvertfall kuttet ut en ekstra person , blir vel også en del forsyninger å hente i land, slik at vi slipper å sulte/spise bønner. Lenke til kommentar
Coffey Skrevet 10. september 2007 Del Skrevet 10. september 2007 Hva med disse hangarskipa da? Lenke til kommentar
Rabbid Skrevet 10. september 2007 Del Skrevet 10. september 2007 Hva med disse hangarskipa da? 9468565[/snapback] De flyter bare til land til slutt, er risikable greier når du ikke har mer drivstoff. Lenke til kommentar
Bytex Skrevet 10. september 2007 Del Skrevet 10. september 2007 Bønner er godt, men kjipt når alle ligger og fiser under dyna hver natt. Lenke til kommentar
Crazy_Man Skrevet 10. september 2007 Del Skrevet 10. september 2007 feil tråd anyone? med mindre han ikke liker zombier som spiser bønner og "ligger og fiser under dyna" Lenke til kommentar
Bytex Skrevet 10. september 2007 Del Skrevet 10. september 2007 (endret) Nope, det var et svar på han som ville ha noe annet å spise på plattformen enn bønner. Tro meg, jeg er klar for utbruddet som en gang er uunngåelig. Endret 10. september 2007 av Bitex Lenke til kommentar
Rabbid Skrevet 10. september 2007 Del Skrevet 10. september 2007 (endret) Crazy_Man: Det kan ha noe med dette å gjøre:https://www.diskusjon.no/index.php?showtopic=746096&st=280# Bønner gir meg luft i magen, så å kunne unngå det ville vært topp! Tror Zombie-døden er å foretrekke over ekstreme mengder luft i magen Endret 10. september 2007 av IQ Lenke til kommentar
Zlatzman Skrevet 10. september 2007 Del Skrevet 10. september 2007 Hva med disse hangarskipa da? 9468565[/snapback] De flyter bare til land til slutt, er risikable greier når du ikke har mer drivstoff. 9468583[/snapback] Større hangarskip går på atomkraft, ikke vanlig drivstoff. Så vidt jeg vet kan de være uten forsyninger veldig lenge, de er tross alt laget for å være en base langt borte fra eget land. Lenke til kommentar
