remi-a Skrevet 9. april 2007 Del Skrevet 9. april 2007 Jeg har problemer med å koble til mitt kamera og kortleser til min laptop med Ubuntu 6.10. Når jeg skriver lsusb: Klikk for å se/fjerne innholdet nedenfor Bus 005 Device 001: ID 0000:0000 Bus 003 Device 008: ID 04a9:3075 Canon, Inc. IXUS 400 Camera Bus 003 Device 001: ID 0000:0000 Bus 002 Device 001: ID 0000:0000 Bus 004 Device 003: ID 076b:3021 OmniKey AG CardMan 3121 Bus 004 Device 001: ID 0000:0000 Bus 001 Device 001: ID 0000:0000 Beskjed ved importering av foto: Klikk for å se/fjerne innholdet nedenfor An error occurred in the io-library ('Could not claim the USB device'): Could not claim interface 0 (Operation not permitted). Make sure no other program or kernel module (such as sdc2xx, stv680, spca50x) is using the device and you have read/write access to the device. Når jeg prøver å installere pcsc-lite-1.4.0 for usb kortleser: Klikk for å se/fjerne innholdet nedenfor checking for a BSD-compatible install... /usr/bin/install -cchecking whether build environment is sane... yes checking for gawk... gawk checking whether make sets $(MAKE)... yes checking build system type... i686-pc-linux-gnu checking host system type... i686-pc-linux-gnu checking for gcc... gcc checking for C compiler default output file name... a.out checking whether the C compiler works... yes checking whether we are cross compiling... no checking for suffix of executables... checking for suffix of object files... o checking whether we are using the GNU C compiler... yes checking whether gcc accepts -g... yes checking for gcc option to accept ISO C89... none needed checking for style of include used by make... GNU checking dependency style of gcc... gcc3 checking how to run the C preprocessor... gcc -E checking for grep that handles long lines and -e... /bin/grep checking for egrep... /bin/grep -E checking for ANSI C header files... yes checking for sys/types.h... yes checking for sys/stat.h... yes checking for stdlib.h... yes checking for string.h... yes checking for memory.h... yes checking for strings.h... yes checking for inttypes.h... yes checking for stdint.h... yes checking for unistd.h... yes checking whether byte ordering is bigendian... no checking whether to enable maintainer-specific portions of Makefiles... no checking how to run the C preprocessor... gcc -E checking for a BSD-compatible install... /usr/bin/install -c checking whether ln -s works... yes checking whether make sets $(MAKE)... (cached) yes checking for flex... flex checking lex output file root... lex.yy checking lex library... -lfl checking whether yytext is a pointer... yes checking for bash... /bin/bash checking for ksh... (cached) /bin/bash checking for sh... (cached) /bin/bash checking for pkg-config... /usr/bin/pkg-config checking pkg-config is at least version 0.9.0... yes checking for the pthreads library -lpthreads... no checking whether pthreads work without any flags... no checking whether pthreads work with -Kthread... no checking whether pthreads work with -kthread... no checking for the pthreads library -llthread... no checking whether pthreads work with -pthread... yes checking for joinable pthread attribute... PTHREAD_CREATE_JOINABLE checking if more special flags are required for pthreads... no checking for cc_r... gcc checking for a sed that does not truncate output... /bin/sed checking for ld used by gcc... /usr/bin/ld checking if the linker (/usr/bin/ld) is GNU ld... yes checking for /usr/bin/ld option to reload object files... -r checking for BSD-compatible nm... /usr/bin/nm -B checking how to recognise dependent libraries... pass_all checking dlfcn.h usability... yes checking dlfcn.h presence... yes checking for dlfcn.h... yes checking for g++... no checking for c++... no checking for gpp... no checking for aCC... no checking for CC... no checking for cxx... no checking for cc++... no checking for cl.exe... no checking for FCC... no checking for KCC... no checking for RCC... no checking for xlC_r... no checking for xlC... no checking whether we are using the GNU C++ compiler... no checking whether g++ accepts -g... no checking dependency style of g++... none checking for g77... no checking for xlf... no checking for f77... no checking for frt... no checking for pgf77... no checking for cf77... no checking for fort77... no checking for fl32... no checking for af77... no checking for xlf90... no checking for f90... no checking for pgf90... no checking for pghpf... no checking for epcf90... no checking for gfortran... no checking for g95... no checking for xlf95... no checking for f95... no checking for fort... no checking for ifort... no checking for ifc... no checking for efc... no checking for pgf95... no checking for lf95... no checking for ftn... no checking whether we are using the GNU Fortran 77 compiler... no checking whether accepts -g... no checking the maximum length of command line arguments... 32768 checking command to parse /usr/bin/nm -B output from gcc object... ok checking for objdir... .libs checking for ar... ar checking for ranlib... ranlib checking for strip... strip checking if gcc supports -fno-rtti -fno-exceptions... no checking for gcc option to produce PIC... -fPIC checking if gcc PIC flag -fPIC works... yes checking if gcc static flag -static works... yes checking if gcc supports -c -o file.o... yes checking whether the gcc linker (/usr/bin/ld) supports shared libraries... yes checking whether -lc should be explicitly linked in... no checking dynamic linker characteristics... cat: /etc/ld.so.conf.d/*.conf: No such file or directory GNU/Linux ld.so checking how to hardcode library paths into programs... immediate checking whether stripping libraries is possible... yes checking if libtool supports shared libraries... yes checking whether to build shared libraries... yes checking whether to build static libraries... yes configure: creating libtool appending configuration tag "CXX" to libtool appending configuration tag "F77" to libtool checking for ANSI C header files... (cached) yes checking for sys/wait.h that is POSIX.1 compatible... yes checking getopt.h usability... yes checking getopt.h presence... yes checking for getopt.h... yes checking sys/filio.h usability... no checking sys/filio.h presence... no checking for sys/filio.h... no checking syslog.h usability... yes checking syslog.h presence... yes checking for syslog.h... yes checking dl.h usability... no checking dl.h presence... no checking for dl.h... no checking fcntl.h usability... yes checking fcntl.h presence... yes checking for fcntl.h... yes checking for an ANSI C-conforming const... yes checking for uid_t in sys/types.h... yes checking for size_t... yes checking whether time.h and sys/time.h may both be included... yes checking for error_at_line... yes checking whether lstat dereferences a symlink specified with a trailing slash... yes checking whether stat accepts an empty string... no checking for vprintf... yes checking for _doprnt... no checking for daemon... yes checking for flock... yes checking for getopt_long... yes checking for nanosleep... yes checking for strerror... yes checking for vsnprintf... yes checking for strlcpy... no checking for strlcat... no checking for inline... inline checking for -fvisibility=hidden... yes checking for dlopen in -ldl... yes checking for socket in -lsocket... no checking for LIBUSB... no no checking for libusb-config... no configure: WARNING: libusb-config not found. checking usb.h usability... no checking usb.h presence... no checking for usb.h... no configure: error: usb.h not found, use ./configure LIBUSB_CFLAGS=... Noen som kan hjelpe meg å få dette til å fungere? Lenke til kommentar
RusleBiff Skrevet 9. april 2007 Del Skrevet 9. april 2007 Installer pcsc via pakkesystemet? synaptic eller apt-get i konsoll. Den andre, tja. prøv sudo modprobe -r sdc2xx stv680 spca50x Lenke til kommentar
remi-a Skrevet 9. april 2007 Forfatter Del Skrevet 9. april 2007 Det er installert en pakke som heter libpcsclite1 1.3.1-2, men jeg finner ikke en som heter bare pcsc lite i pakkehåntereren. Etter at jeg har skrevet ./config og skal skrive make får jeg melding om at make filen ikke finnes. Prøvde å skrive: sudo modprobe -r sdc2xx stv680 spca50x Fikk da FATAL: Module sdc2xx not found. Tok vekk sdc2xx fra komandoen og fikk da FATAL: Module spca50x not found. Kan det være noe sånt som at det er noen USB drivere som ikke er installert eller korrupte? Er ganske nybegynner på dette med linux. Lenke til kommentar
kommers Skrevet 10. april 2007 Del Skrevet 10. april 2007 sdc2xx og spca50x er vel bare navn på kjernemoduler der x-tegnet brukes som wildcard for ulike numre. Dermed funker det ikke å fjerne "sdc2xx" direkte. For å sjekke om du har lastet noen av disse (slik at du deretter kan prøve å fjerne dem, for å teste tipset du fikk) så får du ut listen over alle aktive kjernemoduler vha lsmod-kommandoen. F.eks. for å raskt sjekke om du bruker disse to kan du grep'e outputen via en pipe: lsmod | grep sdc2 og lsmod | grep spca[/i] e.l. Jeg har ikke peiling på pcsc, men hva med pakken pcscd -- og kanskje også pcsc-tools (begge to finnes i universe-repository). Disse er begge avhengige av libpcsclite1. Lenke til kommentar
