Ladere og oppladingstid?
Hvordan kan ladetiden være så utrolig forskjellig? 2-5 timer i forhold til 15 min?
8329417[/snapback]
Finnes ladere som bruker 12-14 timer også. Forskjellen er at de tregeste laderne gjerne lader batteriene fullere enn en hurtiglader, da den første delen av batteriet tar kort tid å lade, mens de siste prosentene er de tregeste. Men det er så klart ikke kun den faktoren som bestemmer ladetid.
Mulig hurtiglading sliter mer på batteriet også, men det vet jeg ikke sikkert.
NiMH batterier skal helst hurtiglades for optimal levetid.
"NiMH batteries should be rapid charged rather than slow charged. The amount of trickle charge applied to maintain full charge is especially critical. Because NiMH does not absorb overcharge well, the trickle charge must be set lower than that of the NiCd. The recommended trickle charge for the NiMH battery is a low 0.05C. This is why the original NiCd charger cannot be used to charge NiMH batteries. The lower trickle charge rate is acceptable for the NiCd.
It is difficult, if not impossible, to slow-charge a NiMH battery.
Some lower-priced chargers may not apply a fully saturated charge. On these economy chargers, the full-charge detection may occur immediately after a given voltage peak is reached or a temperature threshold is detected
Kilde:http://www.technick.net/public/code/cp_dpa...ide_bpw2_c04_05
