vil denne funke med vista 64bit?
Creative Europes nettsider finnes det en Vista-side med alle drivere.
SoundBlaster X-FI Xtreme er en av de som listes med drivere til 64bit, men med begrensede muligheter.
This download is a driver providing Microsoft® Windows Vista™ 64-bit and Windows Vista 32-bit support for the audio device listed below. For more details, read the rest of this web release note.
Current Release Features
    * Provides basic audio support and control options for sampling rate and speakers only. Applications bundled with your audio device will not work with this driver.
Known Issues
    * This download does not support direct monitoring.
    * Speakers can be configured in Control Panel only.
Requirements
    * Windows Vista 64-bit or Windows Vista 32-bit
    * Sound Blaster® X-Fi™ Xtreme Audio
Notes
    * This package is only for the Creative Sound Blaster audio device listed above. DO NOT install this package for other Sound Blaster audio devices.
    * To install this driver
        1. Close all other Windows applications.
        2. Double-click the downloaded file.
        3. Follow the instructions on the screen.
