Impreza_wrcsti Skrevet 7. april 2007 Del Skrevet 7. april 2007 (endret) Trying to decide between the two. Similar price but what about performance wise? Both have dobbelkjerne but the Pentium D has 3.4ghz and the E6400 2.2ghz. Intel Pentium D 945: https://prisguiden.no/product.php?productId=55550 Intel Core 2 Duo E6400: https://prisguiden.no/product.php?productId=45526 Thanks in advance. Endret 9. april 2007 av Impreza_wrcsti Lenke til kommentar
Fritz0r Skrevet 7. april 2007 Del Skrevet 7. april 2007 Core 2 Duo is newer, has newer designe on the core, should be the better buy, check if there is any comparison test on the web, like www.tomshardware.com, they usually compare all CPU's to date in a single graph. Lenke til kommentar
Impreza_wrcsti Skrevet 7. april 2007 Forfatter Del Skrevet 7. april 2007 Core 2 Duo is newer, has newer designe on the core, should be the better buy, check if there is any comparison test on the web, like www.tomshardware.com, they usually compare all CPU's to date in a single graph. 8325534[/snapback] Thanks alot for that. That chart guide on the middle right hand side is great. Wish I had of known about it before buying my apparently rubbish graphics card! Thanks alot for that. E6400 it is then. Perhaps stretch to the e6600. Lenke til kommentar
imfrommanndame Skrevet 7. april 2007 Del Skrevet 7. april 2007 You really don't need the E6600 if you have already have a crappy system. Just go for the E6400. Even E4300 or E6300 would be good choises. Personally I would've purchased the E4300, due to its supreme overclocking abilities. Lenke til kommentar
Impreza_wrcsti Skrevet 7. april 2007 Forfatter Del Skrevet 7. april 2007 You really don't need the E6600 if you have already have a crappy system. Just go for the E6400. Even E4300 or E6300 would be good choises. Personally I would've purchased the E4300, due to its supreme overclocking abilities. 8325979[/snapback] Hi there well this is my motherboard: http://www.komplett.no/k/ki.asp?sku=324695 Bought it 2 months along with these: 2 X TwinMOS DDR2 PC4200 1024MB CL4, 64M*8/16chip, 533MHz, 240pin http://www.komplett.no/k/ki.asp?sku=306870 Intel Pentium 4 640 3.2GHz Socket LGA775, 2MB, BOXED m/vifte http://www.komplett.no/k/ki.asp?sku=307538 HIS Radeon X1650PRO 512MB, iSilence II, PCI-Express, GDDR3, 2xDVI/Tv-Out, Retail http://www.komplett.no/k/ki.asp?sku=327297 Arctic Cooling Freezer 7 Pro CPU-Kjøler, Socket 775 http://www.komplett.no/k/ki.asp?sku=313239 But I have to say that Im really disappointed with the results. Still lag with alot of games.... Thats why I am looking at upgrading again with a better processor. What would you guys suggest? Lenke til kommentar
Brusfantomet Skrevet 7. april 2007 Del Skrevet 7. april 2007 if it is better gaming then a better grafics card would be nice, but what resolution are you runing at? Lenke til kommentar
Impreza_wrcsti Skrevet 7. april 2007 Forfatter Del Skrevet 7. april 2007 (endret) if it is better gaming then a better grafics card would be nice, but what resolution are you runing at? 8327151[/snapback] I am trying all resolutions at the moment. Around 1280 x 800 on most games. I dont understand why this graphics card is so bad? 512mb gddr3 pci-e........ Could it be a setting I have wrong? Endret 7. april 2007 av Impreza_wrcsti Lenke til kommentar
foffle Skrevet 7. april 2007 Del Skrevet 7. april 2007 if it is better gaming then a better grafics card would be nice, but what resolution are you runing at? 8327151[/snapback] I am trying all resolutions at the moment. Around 1280 x 800 on most games. I dont understand why this graphics card is so bad? 512mb gddr3 pci-e........ Could it be a setting I have wrong? 8327170[/snapback] Probably no settings wrong.. It's not an up to date graphic card.. Lenke til kommentar
Brusfantomet Skrevet 7. april 2007 Del Skrevet 7. april 2007 the amamunt of vram has little to do with how good the card is, as an example, my two 7800 GTs have only 256 MiB ram when used in SLi, but they wil probably beat yours by a margin of at least two. A 8800 GTS 320 is round 2000 kr and gives god prefomance, considering you does not use 1600 x 1200 and upp you realy do not need more vram. A e6300 or a e6400 would be nice to, and maybe some more ram, then you wil have a realy beefy computer Lenke til kommentar
Impreza_wrcsti Skrevet 7. april 2007 Forfatter Del Skrevet 7. april 2007 the amamunt of vram has little to do with how good the card is, as an example, my two 7800 GTs have only 256 MiB ram when used in SLi, but they wil probably beat yours by a margin of at least two. A 8800 GTS 320 is round 2000 kr and gives god prefomance, considering you does not use 1600 x 1200 and upp you realy do not need more vram. A e6300 or a e6400 would be nice to, and maybe some more ram, then you wil have a realy beefy computer 8327707[/snapback] Ok well thats really helpful. Thanks alot to you all for your help. On a seperate note..... where the hell is the demo section on Kompletts website? Lenke til kommentar
Ayb Skrevet 8. april 2007 Del Skrevet 8. april 2007 (endret) On a seperate note..... where the hell is the demo section on Kompletts website? 8328007[/snapback] Komplett.no is updating their site during the Easter, therefore some things (including the "demovare" section) are down. Endret 8. april 2007 av GW Lenke til kommentar
Impreza_wrcsti Skrevet 8. april 2007 Forfatter Del Skrevet 8. april 2007 Komplett.no is updating their site during the Easter, therefore some things (including the "demovare" section) are down. 8333929[/snapback] Ah ok. Thought perhaps they had stopped with that section. Would of been silly as I always check there first and end up vurtually everything new anyway! Lenke til kommentar
Øyvind Skogseide Skrevet 8. april 2007 Del Skrevet 8. april 2007 Trying to decide between the two. Similar price but what about performance wise? Both have dobbelkjerne but the Pentium D has 3.4ghz and the E6400 2.2ghz. 8325520[/snapback] Koffor snakke dåke ikkje norsk? Lenke til kommentar
Impreza_wrcsti Skrevet 8. april 2007 Forfatter Del Skrevet 8. april 2007 Trying to decide between the two. Similar price but what about performance wise? Both have dobbelkjerne but the Pentium D has 3.4ghz and the E6400 2.2ghz. 8325520[/snapback] Koffor snakke dåke ikkje norsk? 8334627[/snapback] He he! I understand most of it written but to write it im REALLY bad! Lenke til kommentar
Gjest Slettet-CkrM7QVpfE Skrevet 9. april 2007 Del Skrevet 9. april 2007 this topic title is not very good. the title is supposed to explain what the question is in the post. Strange that no moderators mentioned it. But perhaps they find it difficult to repeat the Rules here in english. A better title would be for example: What gives most per Krone, Intel PD 945 or Intel C2D E6400? or Best performance of Intel PD 945 or Intel C2D E6400? im not sure if that was to long but you got the picture Lenke til kommentar
JohndoeMAKT Skrevet 9. april 2007 Del Skrevet 9. april 2007 What KRAFortune wrote is true, the threads title should better explain its topic. Use the -button on the first post to edit it. Send a to me or another moderator if you have any questions. Lenke til kommentar
Impreza_wrcsti Skrevet 9. april 2007 Forfatter Del Skrevet 9. april 2007 Yes sorry about that. Changed title. And thanks again to all for your help. Lenke til kommentar
