Stephen Colbert Skrevet 5. april 2007 Del Skrevet 5. april 2007 (endret) Microsoft and Epic Games made a boo boo this afternoon. Someone uploaded all the details on the upcoming Gears of War update onto the official website, and before they could remove all the information, gamers had already copy and pasted it everywhere. So, what to expect? The next update comes on Monday, April 9, and features the already mentioned Annex multiplayer game type, an evolution of the Domination mode introduced in the original Unreal Tournament on the PC. Gamers are divided into teams and tasked to hold specific objectives or locations throughout the map. The longer the point is held, more points are racked up, until that location gives 60 points. These points could be split any number of ways to the teams, depending on how long they hold it.Once the 60 points are gone, the next objective or location is chosen. Unlike other Gears of War gametypes, this one involves respawning -- players return into battle every 15 seconds. Total round scores can be set as low as 120 points or as high as 480 points. As for HUD and map changes related to Annex: " On the HUD, the current objective appears below the team scores at top left. This indicator contains several pieces of relevant information. The weapon icon inside the circle indicates which weapon-spawn location is being used as the objective. The compass along the outer edge of the circle shows the relative direction to the objective. The number inside the circle indicates how many points remain at that objective and the background icon color indicates which team currently controls it. No color means the objective awaits capture, a red icon means the Locust Horde hold the objective and a blue icon means the COG hold it. When the icon in the indicator circle fills, the corresponding team's score also changes color, the team begins collecting points from the objective, and the point value of the objective drops. On the map, a projected ring marks the physical location and boundaries of the objective in the world. The ring's color indicates the current captor: White means neutral, blue COG, and red Locust. To capture an objective, players must stand inside the glowing ring uncontested for a short period of time. How long depends on how many teammates stand in the ring at once. One player can capture an objective in eight seconds, two players in four seconds, three players in two seconds, and four players in one second. Once a team takes an objective, they are not required to remain inside the ring to maintain ownership. The captured objective's points drain until an opposing team member enters the ring, or until its points fall to zero." NO NEED TO FLAME, IF YOU ALREADY KNOW! "Kilde" Dette er ikke bekreftet men det virker GANSKE synlig, og virker som en fet gametype, ikke gled dere for mye, men tror nok dette stemmer ganske bra! The situation has escalated! For noe dritt da, får vel håpe den kommer til fredag da Endret 5. april 2007 av SaintedThomas Lenke til kommentar
boffeeen Skrevet 5. april 2007 Del Skrevet 5. april 2007 Det er bekreftet at det er en slik gametype, men det er ikke sagt noe om en dato. Lenke til kommentar
Comprade Skrevet 5. april 2007 Del Skrevet 5. april 2007 Skal bli gøy å ta dette med deg, sainted Lenke til kommentar
Snorre Skrevet 5. april 2007 Del Skrevet 5. april 2007 Det er jo ikke uvanlig at en spillutvikler ved et "uhell" laster opp en masse informasjon om kommende patcher, ekspansjoner, spill osv, for så å fjerne det igjen kort tid etter. Er uhyre bra markedskommunikasjon det der. Det får jo alle fansene til å starte tråder på alle verdens forum for å diskutere om det er sant eller ikke. Snorre Lenke til kommentar
Vale Tudo Skrevet 5. april 2007 Del Skrevet 5. april 2007 Det er jo ikke uvanlig at en spillutvikler ved et "uhell" laster opp en masse informasjon om kommende patcher, ekspansjoner, spill osv, for så å fjerne det igjen kort tid etter. Er uhyre bra markedskommunikasjon det der. Det får jo alle fansene til å starte tråder på alle verdens forum for å diskutere om det er sant eller ikke. Snorre 8313387[/snapback] Bingo! *Se hva vi driver med nå* Lenke til kommentar
E-wok Skrevet 5. april 2007 Del Skrevet 5. april 2007 Gamereactor sier: Det er snakk om en slags Territory-mode hvor du sammen med vennene skal holde visse deler av banen under kontroll. Andre ganger kan det være spesifikke krav som skal møtes for å vinne et bestemt antall poeng. Ifølge Epic Games har hver eneste bane et sted mellom to og fem steder som kan kapres med en oppgave om gangen. Epic har også rettet den eksisterende spillmodeen Assassination til at lederen på laget ikke lengre skal samle opp våpnene og kaste de igjen for at andre på laget kan bruke de. De er alle tilgjengelige fra start. Dessuten er det nå slik at lederen skal drepes via en Execution og ikke som det tidligere var tilfellet via Warzone-regler. Hva som ellers er i oppdateringen vites ikke, men den lanseres den 9. april og så kan du jo selv se etter. Lenke til kommentar
MindTooth Skrevet 7. april 2007 Del Skrevet 7. april 2007 9 poster om GoW vs. GeOW slettet. Tråden handler ikke om det.. Keep on-topic! Lenke til kommentar
Comprade Skrevet 7. april 2007 Del Skrevet 7. april 2007 (endret) 9 poster om GoW vs. GeOW slettet. Tråden handler ikke om det.. Keep on-topic! 8326244[/snapback] hehe. La akkurat merke til hvor lett man driver vekk ifra diskusjoner her på forumet. Bare se hva jeg gjør nå! Tilbake til topic igjen: Noen Microsoft dudes har sagt at info`n som lekket ut er ekte, bortsett fra datoen. Enten lyver han, eller så kommer patchen tidligere/senere. EDIT: Ser at jeg var aaaltfor sen med denne nyheten. DAMN YOU SAINTEDTHOMAS! :!: Endret 7. april 2007 av Comprade Lenke til kommentar
iStephano Skrevet 7. april 2007 Del Skrevet 7. april 2007 (endret) Typisk at dem vil legge den ut etter PÅSKE! Da jobber jeg jo, nå har jeg jo fri i noen dager....... Hvis ryktet er sant da. Men gleder meg, men stiller meg skeptisk til respawn.. Synes det ikke passer inn i GeOW verdenen. Du skal bare ha en sjangse for og overleve. Ikke 5... Endret 8. april 2007 av BanAnus Lenke til kommentar
Claus3000 Skrevet 7. april 2007 Del Skrevet 7. april 2007 Typisk at dem vil legge den ut etter PÅSKE! Da jobber jeg jo, nå har jeg jo fri i noen dager....... Hvis ryktet er sant da. Men gleder meg, men stiller meg skeptisk til respawn.. Synes det ikke passer inn i GeOW verdenen. Du skal bare ha en sjansje for og overlever. Ikke 5... 8326308[/snapback] Tjo... Men da er det jo bare å la være å spille denne modusen. Jeg er spent på å prøve dette. Om det passer inn i GOW for meg får tiden vise. Lenke til kommentar
-iL- Skrevet 8. april 2007 Del Skrevet 8. april 2007 9 poster om GoW vs. GeOW slettet. Tråden handler ikke om det.. Keep on-topic! 8326244[/snapback] jeg kan ikke være mere uenig. når jeg klikket meg inn på tråden trodde jeg det omhandlet God of War, som er den opprinnelige forkortelsen for GoW, og når idiotiske 360 eiere omtaler Gears of War som GoW blir det bare feil. Greit at begge spillene er bra, men det må gå ann å finne forkortelser som ikke fører til misforstaåelser, som det gjør i dette tilfellet. Lenke til kommentar
Comprade Skrevet 8. april 2007 Del Skrevet 8. april 2007 hvorfor kan ikke God of War forkortes til GooW a? Samme side av samme sak. Nei fysj, nå gikk det OT igjen Lenke til kommentar
Stephen Colbert Skrevet 8. april 2007 Forfatter Del Skrevet 8. april 2007 hvorfor kan ikke God of War forkortes til GooW a? Samme side av samme sak. Nei fysj, nå gikk det OT igjen 8330683[/snapback] Det må være det beste forslaget jeg noen gang har hørt :!: Lenke til kommentar
Bamsemumsen Skrevet 8. april 2007 Del Skrevet 8. april 2007 Helt enig, Gears fortjener GoW-forkortelsen! Patch på mandag, fuck yeah. Har fri da og. Lenke til kommentar
iStephano Skrevet 9. april 2007 Del Skrevet 9. april 2007 Er dette bekreftet nå eller? Lenke til kommentar
Landeplagen Skrevet 9. april 2007 Del Skrevet 9. april 2007 TeamXbox i hurtigbuffer - via google. "Annex became available as a Gears of War multiplayer game mode in the April 9 update." Lenke til kommentar
Stephen Colbert Skrevet 9. april 2007 Forfatter Del Skrevet 9. april 2007 Phalse! BTW; Martin, må du legge deg Lenke til kommentar
