meny som fungerer uansett browser
er det noen som vetom en meny i javascript/css som fungerer i alle browsere uten å lage noe bøll?
hadde funnet den perfekte menyen ,men neida... den funker selvfølgelig ikke i IE
Klikk for å se/fjerne innholdet nedenfor
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
<html>
<head>
<title>Suckerfish Dropdowns</title>
<style type="text/css">
body {
font-family: arial, helvetica, serif;
ul { /* all lists */
padding: 0;
margin: 0;
list-style: none;
li { /* all list items */
float: left;
position: relative;
width: 10em;
li ul { /* second-level lists */
display: none;
position: absolute;
top: 1em;
left: 0;
background-color: #FFFFFF;
li>ul { /* to override top and left in browsers other than IE, which will position to the top right of the containing li, rather than bottom left */
top: auto;
left: auto;
li:hover ul, li.over ul { /* lists nested under hovered list items */
display: block;
#content {
clear: left;
</style>
<script type="text/javascript"><!--//--><![CDATA[//><!--
startList = function() {
if (document.all&&document.getElementById) {
navRoot = document.getElementById("nav");
for (i=0; i<navRoot.childNodes.length; i++) {
node = navRoot.childNodes;
if (node.nodeName=="LI") {
node.onmouseover=function() {
this.className+=" over";
node.onmouseout=function() {
this.className=this.className.replace(" over", "");
window.onload=startList;
//--><!]]></script>
</head>
<body>
<ul id="nav">
<li>Sunfishes
<ul>
<li><a href="">Blackbanded sunfish</a></li>
<li><a href="">Shadow bass</a></li>
<li><a href="">Ozark bass</a></li>
<li><a href="">White crappie</a></li>
</ul>
</li>
<li>Grunts
<ul>
<li><a href="">Smallmouth grunt</a></li>
<li><a href="">Burrito</a></li>
<li><a href="">Pigfish</a></li>
</ul>
</li>
<li>Remoras
<ul>
<li><a href="">Whalesucker</a></li>
<li><a href="">Marlinsucker</a></li>
<li><a href="">Ceylonese remora</a></li>
<li><a href="">Spearfish remora</a></li>
<li><a href="">Slender suckerfish</a></li>
</ul>
</li>
</ul>
<div id="content">
<p>Lorem ipsum dolor sit amet, consectetuer adipiscing elit. Suspendisse egestas ultricies pede. Phasellus suscipit blandit risus. Praesent nonummy. In erat. Duis nibh pede, accumsan eu, pulvinar et, volutpat vel, elit. Curabitur nec dui sed nunc congue tempus. Nulla ac dui ac libero fringilla nonummy. Maecenas ullamcorper sodales risus. Vivamus pretium dolor. Proin eu turpis. Phasellus ut mauris non nulla mattis luctus. Nunc porttitor dapibus sapien. In malesuada fermentum metus. Nulla egestas, tellus a vestibulum pharetra, nunc purus auctor lacus, ut semper purus ipsum eu velit. Praesent dui. Nulla accumsan turpis at erat.</p>
</div>
</body>
</html>
Endret av ilpostino
sett opp menyen slik
<ul id="menu">
<li><a href="#">Hjem</a></li>
<li><a href="#">Galleri</a></li>
<li><a href="#">Kontakt</a></li>
</ul>
så setter du css sånn:
ul#meny li a {
background: #ddd;
color: #fff;
og en slik
ul#meny li a:hover {
background: #666;
i dette tilfellet skifter bakgrunnsfarge fra #ddd til #666
her er det bare fantasien som begrenser hva du kan gjøre..
Endret av rønning
