Current Blu-ray Players Obsolete by October?
MrZ
From gamerawr.com:
Here's the deal. Blu-ray was rushed out the door in order to stay competitive with HD DVD. The Blu-ray Disc Association has only recently finalized the formats specifications, which most current players do not conform to. This includes the Playstation 3, and all of Sony's own Blu-ray players. The lacking features include PIP support, part of BD-Java technology. Many players that even support BD-Java, do not support picture in picture.
After October 31, 2007, picture-in-picture (via BD-J) will be mandatory for players to carry the Blu-ray logo. New specification requirements also include 256MB of persistent memory storage, and a required 1GB for players with an internet connection. This new memory requirement is also part of the BD-J picture-in-picture spec.
So what does this mean for your current Blu-ray player? A simple firmware update, right? Well, a firmware update obviously won't give you memory that isn't already there.
Given the nature of the PS3s hardware, it's reasonable to assume PIP will eventually be supported. Other players wont be so lucky.
Even if your Blu-ray player isn't up to spec, it is promised you will be able to watch all Blu-ray discs in the most basic form.
www.gamerawr.com
Eg er fullstendig einig angåande å ha standarden klar først. Men eg trur ikkje dette er eit altfor stort problem:
På overskrifta høyrast det ut som om dagen's BD-spelarar vil bli ubrukelege. Og det stemmer jo ikkje, når dei fortsatt vil kunne spele av alle BD-filmar som kjem. PiP er sikkert kjekt å ha, men for dei fleste av oss er det vel sjølve filmavspelinga som er hovudpoenget.
Når det gjeld PS3, reknar eg med at Sony vil sørge for å halde den oppdatert. :)
Kay
Artikkelen er noe misvisende, spillerene blir jo ikke utdatert selv som det kommer en ny profil. Det finnes ulike BD-J profiler - alt fra den enkle "music only" til den mest omfattende som hete "BD-live" med nettverkstilgang og krav til 1 GB lagringsplass.
Alle spillere i dag støtter profil 1.0, til høsten blir det obligatorisk for NYE spillere å støtte profil 1.1. Noen spillere kan helt klart oppgraderes, f.eks. PS3 som har cpu og lagringsplass nok til å støtte alle profiler, både eksisterende og kommende.
Det er uansett ikke noe problem for eksisternde spillere da de som lager BD-J programmer kan kode inn sjekkeer på hvilken "maskin profil" som benyttes. Er det 2.0 så kan man vise fram Internettvalg i spillet/programmet, er det 1.0 så lar man være.
Profil 2.0 (BD-Live) vil uansett være valgfri, det er ikke alle typer spiller som trenger nettverkstilgang (f.eks. en BD discman). Det er heller ikke alle som vil ha mulighet til å koble videoavspilleren sin til Internett.
Så å fremstille dette som en stor bakdel for BD er misvisende, det viser jo bare at fleksibiliteten til BD-J gir BD en gigantisk fordel. Det er jo ikke umulig at det dukker opp ytterligere profiler i framtiden, som gir enda flere features.
Filmer kan utnytte de nyeste finessene på spillere der de finnes og la være for alle andre.
