Impreza_wrcsti Skrevet 2. april 2007 Del Skrevet 2. april 2007 Hi all. Englishman living in Drammen here but was hoping for a little advice. Was looking at buying this machine but was wondering how much its worth. Any information is welcome. (Please write in norwegian. I can understand it just useless at writing it! ) INTEL 'E6600 Core2 DUO' - 1066Mhz FSB 6,600 MHz - 64Bit Core2Duo On 1066Mhz FSB - Intels Fastest CPU - 40% Quicker Than Dual CoreX2 - LGA-775 Design & 2 x L2 Caches - Genuine Retail Box With Heatsink/Fan VIA 1066Mhz 16XPCI-E Chipset Motherboard - 2 x PCI Slots, LAN Port & 6 x USB2.0 Ports - DDR2 - DDR667/533/400, IDE, SATA, & 16XPCI-Express - 7.1 Intergrated High Defination Sound & Superb Graphics 2GB DDR2 533 PC4200 RAM Memory 250GB SATA300 HDD (Ultra Fast SATA) 18X DVD+/-RW Dual Layer & Dual Format Connectivity Range - 6 USB2.0 Ports (Inc 2 On The Front) - LAN Port For Networking/Broadband - 7.1 High Definition Quality Intergrated Sound - 56K Modem (Optional Extra) - 3 Port Firewire Card (Optional Extra) nVIDIA 7300 512MB 16XPCI-Express Thanks in advance! Lenke til kommentar
bushnut Skrevet 2. april 2007 Del Skrevet 2. april 2007 Den maskina der ligger godt under titusen.. kanskje åtte tusen. Det ville vært lettere hvis jeg så annonsen. Er den brukt eller er den ny? Lenke til kommentar
Impreza_wrcsti Skrevet 2. april 2007 Forfatter Del Skrevet 2. april 2007 (endret) Den maskina der ligger godt under titusen.. kanskje åtte tusen. Det ville vært lettere hvis jeg så annonsen. Er den brukt eller er den ny? 8290873[/snapback] Its a brand new system. You can put your own system together but I didnt know if it was a good price. Endret 2. april 2007 av Impreza_wrcsti Lenke til kommentar
