AC'97 integrert lydkort og Linux
For å sitere fra Linux journal september 2002. De satte opp den "ultimate linux boksen"
Quote:
The sound support front is a happer place. We used the ALSA drivers, and with a properly set up ALSA-based-system you shouldn't need to disable the sound chipset on the motherboard to use a high-end sound card. You can use both. We would run the motherboard's audio in and out as a dedicated conference system to chat with headquarters, while saving the Sound Blaster Live! for playing Ogg Vorbis files on headphones. We still like the now-inexpensive Sound Blaster Live! for the ubiquitous kernel support, easy setup, good sound and, most important the fact that 32 programs can have the audio device open at the same time.
... bare sånn siden du hintet at du skulle kjøpe et kort snart :smile: Lyddelen av mitt fremtidige kjøp er hvertfall klar: NVidia chipset på jovedkortet med integrert lyd og Soud Blaster Live!
  • 2 uker senere...
