galaxee Skrevet 13. desember 2002 Del Skrevet 13. desember 2002 eg har admin-mod på cs,men får ikke pod-bot til å virke,manuellen som var med sjønte eg ikke havlparten av,fikk denne og: Okay so you have read the directions in the Admin Mod Manual, but you either don't understand it, or you are still having problems. For this guide, I am going to assume that you are using PODBot and Windows. If you are using a bot other than PODBot, you will change the bot.dll to the one that your bot uses. Or if you are using linux, change the file extensions accordingly. With all that said and done, here is the guide: Method 1 This method is for those who have not yet installed Admin Mod. 1. Install the bot files into the proper directory. 2. Copy and paste the podbot.dll into the dlls folder. 3. Install Adminn Mod using either the installer or folowing the instructions for a Manual Install. 4. Add +localinfo mm_gamedll dlls/podbot.dll to your shortcut's properties. Method 2 This method is for those who already have Admin Mod installed 1. Install the bot files into the proper directory 2. Copy and paste the podbot.dll into the dlls folder. 3. Open up your liblist.gam file with a simple text editor like Notepad. 4. Find the line that reads gamedll "dllspodbot.dll" 5. Edit this line to read gamedll "dllsmetamod.dll" 6. Add +localinfo mm_gamedll dlls/podbot.dll to the shortcut's properties. vis noen kan oversette dette til meg? >>>>>galaxee<<<<< Lenke til kommentar https://www.diskusjon.no/topic/73702-adminmod-waypoint/
galaxee Skrevet 13. desember 2002 Forfatter Del Skrevet 13. desember 2002 ops,beklager at den kom ut her:=) Lenke til kommentar https://www.diskusjon.no/topic/73702-adminmod-waypoint/#findComment-547951
Sagacious Skrevet 13. desember 2002 Del Skrevet 13. desember 2002 Vet ikke noe om det du spør om med bot's. Men den admin-moden skal vist være skikkelig buggy. Bare så du vet det. Lenke til kommentar https://www.diskusjon.no/topic/73702-adminmod-waypoint/#findComment-547968
