Intervju med Phil Harrison ang. Home
En del interessante spørsmål og svar finner du her.
Akkurat dette likte jeg spesielt:
Q: Is there an area where you can just get a list of all the things you want to go to in Home without having to physically walk to all the areas?
PH: You’ve got shortcuts which are built into the virtual PSP. You’ll be able to go to what — this is a working title – is called the World Map. this is just our internal model. This is still being worked on, but there’ll be search in here, there will be ways to filter, there will be ways to group, there will be ways to identify particular spaces that you want to go to. This will be a lot more sophisticated than what we’re showing at the moment – it was intended just to give a sense of a vast galaxy of connected spaces where you can find a new space and download it, check it out and, if you like it, it’s just like bookmarking a webpage. So you can dictate that the Socom barracks, or whatever, would be your landing point every time you come back into Home.
Dette spørsmålet måtte jo bare komme:
Q: What about uploading porn from your PS3’s hard-disk to your private space? And maybe inviting people you don’t necessarily know back and them being slightly offended by what they see, then going to a moderator?
Trykk på linken for å lese svaret. ;)
Unnskylder hvis dette har vært postet før.
