Hvordan innstalere Beryl i Sabayon?
Du har Internet tilgang og er sikker på at den ikke var nede akkurat da du kjørte scriptet?
Du kan laste ned:
http://autopackage.org/downloads/latest/autopackage.tar.bz2
og
http://autopackage.org/downloads/latest/autopackage-gtkfe
Og legge de i samme katalog som amsn.package og prøve på nytt, men velg offline installation.
Her er kanskje noen litt bedre instruksjoner enn hva jeg kan gi deg:
http://autopackage.org/docs/howto-install/
Etter å ha gjort dette:
Section "Extensions"
    Option  "Composite" "Disable"
EndSection
Section "ServerFlags"
    Option  "AIGLX" "off"
EndSection
xorg.conf:
Klikk for å se/fjerne innholdet nedenfor
Section "Files"
   #FontPath	"/usr/share/fonts/local/"
   FontPath	"/usr/share/fonts/misc/"
   FontPath	"/usr/share/fonts/Type1/"
   FontPath    "/usr/share/fonts/TTF/"
   FontPath	"/usr/share/fonts/75dpi/"
   FontPath	"/usr/share/fonts/100dpi/"
   FontPath  "/usr/share/fonts/corefonts"
EndSection
# Module section -- this is an optional section which is used to specify
# which run-time loadable modules to load when the X server starts up.
Section "Module"
   Load	"dbe"
   Load	"i2c"
   Load	"glx"
   Load	"ddc"
   Load	"type1"
   Load	"freetype"
   Load	"extmod"
   Load	"synaptics"
   Load	"vbe"
  Load        "dri"
EndSection
# Server flags section.  This contains various server-wide Options.
    Option  "AllowMouseOpenFail" "true"
EndSection
# Input devices
# Core keyboard's InputDevice section
Section "InputDevice"
   Identifier  "Synaptics1"
   Driver  "synaptics"
   Option  "SendCoreEvents"	"true"
   Option  "Device"  "/dev/psaux"
   Option  "Protocol"  "auto-dev"
   Option  "HorizScrollDelta"	"0"
   Option  "SHMConfig"  "on"
   # For ALPS TouchPads
   Option  "MaxSpeed"  "0.7"
   Option  "MinSpeed"  "0.18"
   Option  "AccelFactor"  "0.08"
   Option  "TopEdge"  "120"
   Option  "LeftEdge"  "120"
   Option  "BottomEdge"  "830"
   Option  "RightEdge"  "650"
   Option  "FingerLow"  "25"
   Option  "FingerHigh"  "30"
   # Do you keep moving the mouse while typing? Try this trick.
   #synclient TouchpadOff=1 disable your synaptics touchpad
   #synclient TouchpadOff=0 enable your synaptics touchpad
EndSection
   Identifier	"Keyboard1"
   Driver	"kbd"
   Option	"AutoRepeat"	"500 5"
   Option      "XkbModel"	"pc105"
   Option	"XkbLayout"	"no"
   Option      "XkbRules"      "xorg"
EndSection
 Driver        "wacom"
 Identifier    "wacom1"
 Option        "Device"        "/dev/wacom"          # Change to
                                                     # /dev/input/event
                                                     # for USB
 Option        "Type"          "stylus"
 Option        "ForceDevice"   "ISDV4"               # Tablet PC ONLY
EndSection
 Driver        "wacom"
 Identifier    "wacom2"
                                                     # /dev/input/event
                                                     # for USB
 Option        "Type"          "eraser"
EndSection
 Driver        "wacom"
 Identifier    "wacom3"
                                                     # /dev/input/event
                                                     # for USB
 Option        "Type"          "cursor"
EndSection
# Core Pointer's InputDevice section
# Identifier and driver
   Identifier	"Mouse1"
   Driver	"mouse"
   Option	"Protocol"	"ImPS/2"
   Option "ZAxisMapping" "4 5"
EndSection
   Identifier	"Mouse2"
   Driver	"mouse"
   Option	"Device"	"/dev/input/mice"
EndSection
# Monitor section
# Any number of monitor sections may be present
Section "Monitor"
   Identifier	"Generic Monitor"
   #Option      "DPMS"
   VertRefresh 43 - 60
   HorizSync	28 - 80
EndSection
# Graphics device section
# Any number of graphics device sections may be present
Section "Device"
   Identifier  "VESA"
   Driver      "fglrx" # do not remove vesa
   #Option "RenderAccel" "on"
   #Option "XAANoOffscreenPixmaps"
   #Option "BusType" "PCI"
   #Option "ColorTiling" "on"
   #Option "EnablePageFlip" "on"
EndSection
# Screen sections.
Section "Screen"
# The Identifier, Device and Monitor lines must be present
   Identifier	"Screen 1"
   Device	"VESA"
   Monitor	"Generic Monitor"
   #Option "AddARGBGLXVisuals" "true"
# The favoured Depth and/or Bpp may be specified here
   DefaultDepth 24
   SubSection "Display"
       Depth  8
       ViewPort	0 0
       Modes  "1024x768" "800x600" "640x480"
   EndSubsection
       Depth           16
       ViewPort        0 0
   EndSubsection
       Depth           24
       ViewPort        0 0
   EndSubsection
EndSection
Section "ServerLayout"
# The Identifier line must be present
   Identifier	"Main Layout"
   Screen 0  "Screen 1"
   InputDevice	"Mouse1" "CorePointer"
   InputDevice	"Mouse2" "SendCoreEvents"
   InputDevice "Synaptics1" "SendCoreEvents"
   #InputDevice "wacom1" "SendCoreEvents"
   #InputDevice "wacom2" "SendCoreEvents"
   #InputDevice "wacom3" "SendCoreEvents"
   InputDevice "Keyboard1" "CoreKeyboard"
EndSection
Section "DRI"
   Mode 0666
EndSection
EndSection
Kommer fortsatt:
$ beryl
* Beryl system compatiblity check                            *
Detected xserver                                : AIGLX
Checking Display :0.0 ...
Checking for XComposite extension               : failed
No composite extension
beryl: No composite extension
$ ls -lh /usr/lib/xorg/modules | grep dri
lrwxrwxrwx 1 root root   12 2007-03-22 00:43 dri -> /usr/lib/dri
drwxr-xr-x 2 root root 4.0K 2007-03-22 03:19 drivers
$ glxinfo | grep rendering
direct rendering: Yes
$ cat /var/log/Xorg.*.log |grep "glx"
(II) LoadModule: "glx"
(II) Loading /usr/lib/xorg/modules/extensions//libglx.so
(II) Module glx: vendor="X.Org Foundation"
$ ps ax | grep -i xgl
9995 pts/6    R+     0:00 grep --colour=auto -i xgl
Endret av Svedge
Bruker du faktisk den xorg.conf filen du postet der? Den mangler:
EndSection
Prøv å legg til det, kjør:
sudo /usr/sbin/accel-manager
Velg XGL.
Trykk Ctrl+Alt+Backspace (eller start maskinen på nytt).
Så trenger du ikke å starte beryl i Sabayon.
Når man starter beryl, bruker man vanligvis beryl-manager og ikke beryl.
Beryl-manager kjører vel allerede og ligger som et icon av en rød diamant oppe i høyre-hjørne (hvis du ikke har forandret på det da).
Du får fortsatt opp dette:
Det virker derfor som x.org ikke registrerer at AIGLX ikke skal kjøre. Prøv å flytt den delen helt sist i xorg.conf og restart maskinen, kjør accel-manager velg xgl.
