knaggen Skrevet 20. mars 2007 Del Skrevet 20. mars 2007 maskinen vil ikkje fungere. eg har nett tatt systemgjennoppretting på maskina, men når eg ska starte maskina står det berre: NTLDR is compressed. press ctrl+alt+del to restart`? noken som har forslag til kva eg kan gjere? Lenke til kommentar
Turbosiggen Skrevet 20. mars 2007 Del Skrevet 20. mars 2007 Når man støter på slike problemer kan det være lurt å skrive feilmeldingen inn i Google. Da får man ofte svar. Som regel er ikke du den første som opplever akkurat dette problemet. Fant dette etter to sekunders søk fra http://www.madboot.com/index.php?option=co...msg18;topicseen An NTLDR is compressed error is pretty easy to fix(much better then NTLDR is missing errors!). First you need to boot to the recovery console. To boot to the recovery console follow these steps: 1. Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer. Click(or press any key) to select any options that are required to start the computer from the CD-ROM drive if you are prompted. 2. When the "Welcome to Setup" screen appears, press R to start the Recovery Console. 3. When prompted type "1" or if you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console. 4. When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER. 5. Now you should be at the comman prompt and ready to repair the ntldr file! Now all you need to do is enter the following commands(in order) and each command on a new line just like you see them here: Code: cd \ attrib -c ntldr exit Your computer should now reboot, and everything "should" work! Lenke til kommentar
