Hva er Packetwriting???
Athlon Power
General Information -
Packet Writing -
This is a method in which a CD disk is pre-formatted and using the appropriate software use the CD disk as if it was a regular hard drive.
Packet Writing is defined in the OSTA (the Optical Storage Technology Association) Universal Disc Format ( UDF ) standard.
There are two types of packets can be written: fixed-length and variable-length.
Fixed-length packets are more suitable for CD-RW using 32K long packets.. The high overhead of this format only leaves about 500MB usable space.
Variable-length packets use less space and are best suited for CD-R recordings.
OK ?
Radar
Packetwriting er brenning til CDR/RW i UDF format. Kort forklart kan du etter å gjort en cd UDF klar kopiere/brenne direkte til cd'en i windows utforsker osv..
Software jeg har prøvd som støtter dette er InCD fra Nero og DirectCD fra Adaptec/Roxio.
Har ikke altfor gode erfaringer med dette, men hver sin smak..?
