Free Rider -> Lag bane og post
Newt32
Denne var litt spesiell
-1i,1i,1i,1i 2b,13,43,2o 1i,1i,3u,36 43,2n,4a,2t 4a,2t,6p,1l 3t,35,4i,3i 4i,3i,7a,1v #
Kjør sakte ned til midten, ok. Brems
Etterpå prøver du å snu (x) og gi gass (Om ønskelig spill av Beattraax-Project Well for bedre effekt)
Genialt spill btw
Lagde en kjapp en:
Klikk for å se/fjerne innholdet nedenfor
-2g,-14,-2c,-1m -2c,-1m,-23,-24 -23,-24,-1k,-2f -1k,-2f,-11,-2n -2g,b,-2i,-c -2i,-c,-2g,-14 -1h,1i,-1u,1f -1u,1f,-27,18 -27,18,-2b,t -2b,t,-2g,b -11,-2n,-d,-2t -d,-2t,g,-2u -1i,1i,1i,1i g,-2u,19,-2p 19,-2p,21,-2e 21,-2e,2l,-2b 2l,-2b,39,-2d 1i,1i,25,1l 25,1l,2k,1t 2k,1t,30,2a 30,2a,36,2n 3u,-2o,6c,-4e 39,-2d,3u,-2o 36,2n,38,37 38,37,38,3t 38,3t,3b,4f 3b,4f,3h,4s 3h,4s,3q,55 3q,55,49,5c 49,5c,4i,5e 4i,5e,94,5e 6c,-4e,7a,-56 7a,-56,7u,-5i 92,-5s,98,-5s 9j,-5p,97,-5s 93,-5s,8m,-5q 7u,-5i,8c,-5n 8c,-5n,8m,-5q 94,5e,9v,5c 9v,-5s,a7,-5u a7,-5u,ar,-5u ar,-5u,bb,-5o a0,-5t,9j,-5p 9v,5c,aj,58 aj,58,b0,52 bb,-5o,br,-5k br,-5k,cc,-5m cc,-5m,ct,-5q b0,52,cs,3g ct,-5q,df,-5r dp,-5p,e5,-5h dp,-5p,de,-5r cs,3g,da,30 da,30,dl,2n dl,2n,e0,2i e0,2i,ei,2g e8,3v,dv,3s dv,3s,do,3u dm,42,dm,4a dm,4a,dm,4n dp,3u,dm,43 dq,5a,du,5i du,5i,e6,5s dm,4n,dq,5b e5,-5h,eg,-56 fe,-4o,fo,-4r fe,-4o,f2,-4p f2,-4p,em,-4v em,-4v,eg,-56 ei,2g,eq,2g eq,2g,f8,2h f8,2h,fh,2j fh,2j,fq,2p fp,40,fh,47 fh,47,f3,4a f3,4a,ep,4a ep,4a,eg,46 eg,46,e8,3v e6,5s,ef,63 ef,63,er,68 er,68,fa,6a fa,6a,fk,6b fv,-4o,gt,-46 fo,-4r,ft,-4p gt,-46,i4,-3j fq,2p,fu,30 fu,30,fv,3a fv,3a,ft,3p ft,3p,fp,40 fk,6b,fu,6b fu,6b,k9,6b i4,-3j,jl,-2l jl,-2l,kg,-2a k9,6b,lk,6a kg,-2a,l3,-27 l3,-27,ll,-26 ll,-26,ne,-28 lk,6a,mt,68 ne,-28,p8,-2g mt,68,of,64 of,64,q6,5u p8,-2g,qi,-31 qh,-30,s5,-3r q6,5u,rn,5l rn,5l,ti,51 s5,-3r,tv,-4m ti,51,v2,43 tv,-4m,vj,-54 v2,43,106,2p vj,-54,10a,-5g 10a,-5g,10s,-61 106,2p,10m,1e 10m,1f,112,m 11j,-7e,124,-83 124,-83,131,-8j 10s,-61,11a,-6l 11a,-6l,11j,-7e 11f,7,11u,-1 11u,-1,12e,-4 112,m,11f,7 131,-8j,142,-8u 12e,-4,130,-5 130,-5,13l,-3 13j,-4,13v,1 142,-8u,153,-92 153,-92,16o,-94 13v,1,14a,b 14a,b,14e,m 14e,m,14f,13 14f,13,14p,40 14o,3u,153,64 153,64,15j,7v 16o,-94,17n,-92 15j,7v,16o,ao 16o,ao,183,d3 17n,-92,18r,-8q 183,d3,19f,et 18r,-8q,19l,-8a 19l,-8a,1af,-7b 1aq,3m,1a5,56 1a5,56,19r,6a 19r,6a,19n,7p 19n,7p,19p,8r 19p,8r,1a6,ad 1a6,ad,1au,br 19f,et,1bs,gu 1af,-7b,1av,-64 1av,-64,1b8,-50 1b8,-50,1bg,-2j 1bg,-2j,1be,-4 1be,-4,1b5,2c 1b5,2c,1aq,3m 1au,br,1bj,ch 1bj,ch,1ck,dd 1ck,dd,1dj,e0 1bs,gu,1en,ie 1dj,e0,1el,e8 1el,e8,1fv,ea 1en,ie,1hf,j1 1fv,ea,1hi,e8 1hi,e8,1iu,e5 1hf,j1,1j5,j1 1iu,e5,1lk,e3 1j5,j1,1k3,iu 1k3,iu,1ks,io 1ks,io,1lc,io 1l8,jd,1kv,jp 1kv,jp,1ks,k5 1ks,k5,1kt,kf 1kt,kf,1kt,ko 1kt,ko,1kv,l6 1kv,l6,1l2,lq 1l2,lo,1ld,nv 1lk,e4,1pb,e8 1lc,io,1li,ir 1li,ir,1li,j0 1li,j0,1li,j6 1li,j6,1ld,ja 1ld,ja,1l8,jd 1ld,nv,1lg,o9 1lg,o9,1lm,ol 1lm,ol,1lv,os 1lv,os,1me,p2 1me,p2,1mt,p5 1mt,p5,1n9,ou 1n9,ou,1ni,p5 1oo,pc,1o8,of 1o8,of,1ot,p2 1o8,pb,1nv,os 1nv,os,1nv,pg 1ni,p5,1nn,pc 1nn,pc,1nm,po 1nm,po,1nv,po 1nv,po,1nu,pd 1pa,e7,1rt,ec 1o8,pc,1oo,pc 1ot,p2,1p8,p5 1p8,p5,1p8,r5 1p8,r5,1pd,pj 1pd,pj,1pj,pd 1pj,pd,1pr,pj 1qq,p0,1r5,oc 1r5,oc,1rm,oi 1rh,ol,1r8,oo 1r8,oo,1r5,p0 1r5,p0,1rf,pg 1pr,pj,1pv,p5 1pv,p5,1ql,pb 1ql,pb,1qq,pm 1qq,pm,1r5,pj 1r5,pj,1qq,p0 1rt,ec,1te,ek 1rm,oi,1rn,p4 1rn,p4,1rd,ou 1rd,ou,1rh,ol 1si,pj,1t0,p7 1rf,pg,1s0,pc 1s0,pc,1s6,pr 1s6,pr,1sb,p7 1sb,p7,1sj,ph 1te,ek,1ut,eu 1u3,p3,1u2,oe 1u2,oe,1ua,p0 1ua,p0,1ua,pi 1t0,p7,1tm,pd 1tm,pd,1tu,pl 1tu,pl,1u3,p3 1ua,pi,1um,pa 1ut,eu,20m,fe 1um,pa,1uv,pf 1uv,pf,1v8,pl 1v8,pl,1uv,pl 1uv,pl,1vi,pe 1vi,pe,1vc,p3 1vc,p3,1vm,p8 1vm,p8,1vm,pf 20m,fe,21q,fo 20k,pc,211,o3 211,o3,211,pa 1vm,pf,209,ph 209,ph,201,p1 201,p1,209,p3 209,p3,20a,pc 20a,pc,20k,pc 211,pa,21q,pd 21q,fo,238,g7 229,p2,22h,os 22h,os,22p,p7 21q,pd,21g,p1 21g,p1,229,p2 22p,p7,22v,pf 22v,pf,23e,p5 238,g7,24o,gj 24o,gj,25i,gu 247,p7,24e,oq 24e,oq,24u,ot 24u,ot,24i,ok 24i,ok,245,oq 245,oq,23q,p6 24s,qs,24l,pb 24l,pb,246,p6 23q,p6,23e,p6 25i,gu,26e,hf 25p,p7,267,or 267,or,26h,ob 25c,pb,25p,p7 25d,pb,251,p1 251,p1,24s,qs 26e,hf,276,hu 276,hu,282,ik 26k,nq,26q,n8 26q,n8,272,mt 272,mt,27f,mk 27f,mk,280,mg 26h,ob,26k,nq 282,ik,28c,j3 28c,j3,28r,jn 28p,jl,293,jt 293,jt,29i,k2 280,mg,28c,mg 28c,mg,29b,mi 29b,mi,2a1,mm 29i,k2,2a2,k2 2a2,k2,2ah,k0 2ah,k0,2au,ju 2au,ju,2b9,k1 2a1,mm,2ah,ms 2ah,ms,2bp,n6 2cd,jq,2cm,j8 2b9,k1,2bl,k3 2bl,k3,2bv,k2 2bv,k2,2c9,jv 2c9,jv,2cc,jp 2bp,n6,2cl,nb 2dj,e4,2ec,dl 2cu,i0,2d5,f3 2d5,f3,2d8,ei 2d8,ei,2dj,e4 2cm,j8,2cu,i0 2ck,nb,2ef,nm 2fi,cj,2g9,bh 2ec,dl,2fi,cj 2ef,nm,2g6,nu 2g9,bh,2gr,au 2gr,au,2hg,ai 2g6,nu,2hq,o3 2hg,ai,2id,a9 2id,a9,2jl,9n 2hq,o3,2j8,o4 2jl,9n,2ks,9c 2j8,o4,2k9,o4 2k9,o4,2lt,o1 2lr,o1,2mi,nr 2mi,nr,2n3,nt 2n3,nt,2nk,o5 2nk,o5,2o0,ob 2o0,ob,2oc,oe 2oc,oe,2oo,oe 2oo,oe,2p5,oa 2p5,oa,2pj,o4 2pj,o4,2q0,o4 2q0,o4,2qe,o7 2qe,o7,2r0,o8 2r0,o8,2rg,o6 2rg,o6,2s5,o7 2s5,o7,2si,oa 2si,oa,2t8,ok 2t8,ok,2tm,om 2tm,om,2u5,ok 2u5,ok,2uf,ol 2uf,ol,2uu,op 2uu,op,2vc,on 2vc,on,2vr,op 2vr,op,30e,p2 30e,p2,30v,ou 30v,ou,31b,ov 31b,ov,320,p3 320,p3,32l,p0 32l,p0,338,os 338,os,33m,ok 33m,ok,345,oi 345,oi,34n,ol 34n,ol,351,oq 351,oq,35h,p0 35h,p0,365,os 365,os,36n,ou 36n,ou,371,p4 371,p4,37m,p3 37m,p3,383,p5 383,p5,38h,pe 38h,pe,392,pb 3ap,bq,3a6,6f 392,pb,39h,pa 39h,pa,39r,pd 39r,pd,3ac,p9 3bg,eh,3ap,bp 3c8,gt,3bg,eh 3ac,p9,3ar,p9 3ar,p9,3b9,pd 3b9,pd,3c1,p7 3d8,ik,3c8,gt 3e3,kb,3d8,ik 3c1,p7,3ck,p9 3ck,p9,3d0,pc 3d0,pc,3di,p7 3f4,lm,3e3,kb 3di,p7,3eb,p8 3eb,p8,3em,pa 3em,pa,3ev,pg 3g6,n0,3f4,lm 3h9,ns,3g6,n0 3ev,pg,3f7,pp 3f7,pp,3fe,q5 3fe,q5,3fg,qh 3fg,qh,3ff,rj 3ff,rj,3fj,sb 3fj,sb,3fk,t0 3fk,t0,3fr,tv 3fr,tv,3g5,ut 3g5,ut,3g6,vl 3g6,vl,3g9,10d 3g9,10d,3g9,111 3g9,111,3gd,126 3gd,126,3gm,13e 3hb,fp,3hq,ev 3hq,ev,3iu,e6 3h8,hk,3h8,gf 3h8,gf,3hb,fo 3h8,iu,3h8,hk 3hg,ld,3h8,k2 3h8,k2,3h8,iu 3i9,mo,3hg,ld 3hp,p6,3h9,ns 3hr,qj,3hp,p6 3i4,sp,3hn,rk 3hn,rk,3hr,qj 3gm,13e,3h3,143 3h3,143,3hf,14c 3hf,14c,3i8,14p 3iu,e6,3kg,dm 3jf,nj,3i9,mo 3km,nr,3jf,nj 3jh,u8,3il,tl 3il,tl,3i4,sp 3kg,ul,3jh,u8 3i8,14p,3j1,151 3j1,151,3ju,159 3l1,6a,3l5,4c 3l5,4c,3lf,n 3la,7h,3l1,6a 3kg,dm,3ld,do 3me,nn,3km,nr 3li,vh,3kg,ul 3ju,159,3kq,15e 3kq,15e,3lt,15h 3lf,n,3ld,-84 3m6,8q,3la,7h 3ld,do,3mq,e1 3ok,n6,3me,nn 3nc,10e,3md,103 3md,103,3li,vh 3lt,15h,3np,15i 3mq,e1,3nk,eo 3nk,eo,3o8,fn 3o8,fn,3ok,gv 3or,10e,3nc,10e 3np,15i,3pe,15c 3ok,gv,3ov,ho 3ov,ho,3pk,in 3pk,in,3q8,j7 3tt,m3,3pl,mn 3pm,mo,3ok,n6 3qe,vr,3or,10e 3pe,15c,3qr,150 3q8,j7,3r1,jh 3r1,jh,3rk,jj 3rf,up,3qe,vr 3qr,150,3ru,14a 3ri,ji,3sv,jj 3sv,jj,3tn,jeg 3to,st,3s6,tt 3s6,tt,3rf,up 3ru,14a,3sp,13g 3sp,13g,3tc,12k 3tn,jeg,3uj,it 3tt,m3,3u8,m4 3u8,m4,3uk,m9 3v8,rt,3to,st 3tc,12k,3tt,122 3tt,122,3u9,11c 3u9,11c,3ut,10p 3uj,it,3vo,ic 3vo,ic,41h,i0 3uk,m9,3uq,mi 3uq,mi,3uv,n6 3uv,n6,3vb,nk 3vb,nk,400,o2 400,o2,40j,o4 40f,qq,3v8,rt 3ut,10p,3va,104 3va,104,3vv,vh 3vv,vh,40p,v2 41h,i0,43c,hg 40j,o4,41b,oe 41a,oe,41l,or 41l,or,41l,p9 41l,p9,41i,pp 41i,pp,417,q6 417,q6,40f,qq 40p,v2,41b,uh 41b,uh,41l,to 41l,to,424,t1 432,s5,43d,rh 424,t1,42i,sk 42i,sk,432,s5 43c,hg,44m,gl 44m,gl,45j,fd 440,qq,44h,qc 44h,qc,456,q7 43d,rh,440,qq 45j,fd,46f,e8 456,q7,45l,po 46j,qm,463,q4 463,q4,45m,po 46f,e8,47k,da 47k,da,482,d0 475,r7,47s,rl 47s,rl,48n,rs 475,r7,46j,qm 482,d0,499,c5 499,c5,49s,b5 48n,rs,49p,s1 4at,8k,4b3,7h 4a3,9f,4at,8k 49s,b5,4a3,9f 49p,s1,4bd,rv 4bk,6q,4cj,5v 4cj,5v,4dh,5u 4b3,7h,4bk,6q 4bd,rv,4cp,rq 4e9,51,4e4,3q 4e4,3q,4f0,2t 4dh,5u,4e9,51 4cp,rq,4en,r5 4f2,1m,4g1,q 4f0,2t,4f2,1m 4en,r5,4g0,q7 4g1,q,4ga,-8 4ga,-8,4gv,-h 4g0,q7,4h6,ot 4h6,ot,4i5,n3 4in,kv,4j5,hc 4i5,n3,4in,kv 4jg,-1,4jg,-8n 4jg,a8,4jg,-1 4jf,c6,4jg,a8 4j5,hc,4jf,c6 #dv,4f hb,-21 14u,-60 3i1,fr 3nn,gu 4i7,br
-5b,-39,-87,-2j -5a,-3l,-89,-2u -82,-2k,-82,1h -1h,1h,-8c,1h -84,c,-96,c -96,c,-96,1i -96,1i,-8b,1j -6f,1h,-6f,-31 -71,-2s,-71,1h -7h,1h,-7h,-2o -m,-1s,-5b,-39 -o,-29,-5a,-3l -5b,-39,-5b,1h -5s,-34,-5s,1f -4r,1h,-4r,-34 -5t,1h,-5t,12 -3q,-15,-3q,-2q -4a,-2u,-4a,1h -45,-14,-2n,-14 -46,p,-46,-15 -3j,-c,-3j,-14 -3j,-14,-3a,-15 -3a,-15,-3a,-c -47,-d,-2o,-d -3a,-1,-3a,p -3j,-1,-3j,p -46,o,-2n,o -3o,1h,-3o,o -45,0,-2o,-1 -21,-29,-22,1g -2i,1g,-2i,-2e -33,-2j,-33,-14 -2n,-13,-2n,p -2n,-14,-2n,-t -34,o,-34,1g -1l,1f,8j,8g -1i,1i,-1i,-25 -o,-1s,-o,-29 -1g,1f,1q,1h 20,-1h,5n,-3d 5n,-3e,3u,-3p 4p,2q,45,2u 5n,-3e,5n,-23 a0,1l,4q,2t 8f,38,ab,52 a7,50,8f,56 8j,8g,i8,ci a2,1l,bj,16 ab,52,9t,3d bj,16,bi,1n bj,1m,dq,3r ej,5,e1,1 e1,1,dd,b dd,b,d4,g e4,42,dr,3s dr,3s,dn,3p dn,3p,dh,3m e2,-4c,gl,-5o gl,-5o,ff,-5u ej,4,hb,-1e fo,4m,fc,4j fc,4j,f2,4h f2,4h,ec,47 ec,47,e4,42 gh,-5q,gi,-4q gs,18,hl,10 gq,18,g2,1d g1,4n,fo,4m h5,4n,gm,4n gm,4n,g9,4n g9,4n,g1,4n iu,-1u,ig,-1n ig,-1n,ia,-1 hl,10,i8,l i8,l,ir,5 l0,40,i8,4m i8,4m,h8,4o i8,ci,q6,df jp,-v,k5,-1o k3,-1n,ni,-1o l2,-3e,iu,-20 ip,-1v,iu,-1u ir,5,jb,-c jb,-c,jp,-v l8,-1o,l8,-3h l8,-3f,o0,-5c l9,-3f,m5,-3f l2,-3d,oc,-5m m6,-32,l8,-32 l8,-2n,o1,-2n o1,-28,l7,-28 l8,-1s,o1,-1s p3,2u,l0,40 oa,-gq,n9,-k2 n4,-4o,o0,-4o m6,-3i,m6,-2o n5,-2o,n5,-3k n5,-3k,m5,-3k m5,-3k,m6,-3b mk,-3k,mk,-2o pi,-d9,oa,-gq o1,-5e,o1,-1m o9,-5l,pb,-6g mg,-4b,o0,-4b lv,-3u,o0,-3u n5,-3f,o0,-3f o0,-31,n6,-31 ne,-1n,p2,-1n pj,-d8,pu,-c4 pt,-cb,q2,-bp pr,-74,r7,-91 pb,-6g,pr,-74 p2,-1n,p2,-14 p2,-14,ph,-14 ph,-14,ph,-i ph,-i,q0,-j q0,-j,q0,0 pv,0,12i,-2l p1,2u,vi,r q6,df,14d,e6 u5,-82,rj,-9p rj,-9p,r9,-91 sr,-8e,r8,-96 ur,-7t,sn,-8f 107,-7t,ur,-7t 12q,-87,107,-7t vh,t,11f,o 14u,-9b,120,-87 11f,o,12t,h 17o,-9a,12q,-87 12t,h,144,7 17q,-9a,14s,-9a 144,7,15a,-7 15a,-7,16c,-o 14d,e6,15l,e1 16m,-f0,17p,-gm 16l,-f1,162,-c0 163,-c2,15v,-bc 16c,-o,17b,-1e 15l,e1,16a,dk 16a,dk,16t,d2 16t,d2,171,cs 171,cs,178,cd 17p,-gm,194,-if 17b,-1e,185,-24 185,-24,18r,-2t 184,b5,18n,af 178,cd,17d,c3 17d,c3,17i,br 17k,bq,184,b5 194,-if,1a3,-jv 1a2,-jv,1cl,-os 19s,-7a,19q,-8b 19q,-8a,1ev,-6v 19p,-5c,19s,-6d 19s,-6d,19s,-7a 19k,-4j,19p,-5e 18r,-2t,19a,-3n 19a,-3n,19k,-4j 196,9r,19u,91 19u,91,1a9,88 18n,af,196,9r 1c0,6c,1ar,5n 1ad,6d,1ad,5k 1ad,5k,1b1,5o 1bo,69,1as,5m 1a9,88,1ab,79 1ab,79,1ad,6d 1cp,6l,1bo,69 1da,6q,1c0,6c 1eh,74,1cp,6l 1c7,83,1ct,80 1ct,80,1do,87 1dm,94,1d0,96 1cc,93,1c6,91 1c3,83,1bv,ak 1cu,97,1c8,95 1d3,96,1c2,92 1cc,ac,1bv,a8 1c0,9h,1cs,9i 1cs,9i,1df,9g 1dg,a7,1d6,a8 1d6,a8,1cs,a7 1cs,a7,1ck,a7 1ck,a7,1ca,a7 1et,75,1da,6q 1gg,7c,1ep,74 1gv,7f,1eh,74 1do,87,1dq,8d 1dq,8d,1dm,94 1eb,89,1e9,ah 1e9,ah,1fa,ai 1df,9g,1dh,9t 1dh,9t,1dg,a7 1eu,-6v,1g4,-6q 1g4,-6q,1hj,-6p 1fa,ai,1fc,8b 1fo,ak,1g8,8d 1g8,8d,1gl,ah 1hj,-6p,1j6,-6r 1iq,7g,1hu,7f 1hu,7f,1gg,7c 1ip,7h,1gv,7f 1gl,ah,1h6,8h 1hj,ag,1hj,8h 1hj,8h,1i4,8j 1id,al,1hi,ae 1j6,-6r,1ki,-70 1jp,7g,1it,7h 1jr,7g,1iu,7h 1il,7f,1j2,7h 1j2,7h,1jp,7g 1jp,7g,1ip,7h 1i4,8j,1id,8v 1id,8v,1ii,9c 1ii,9c,1ij,9v 1j3,8i,1jh,9s 1ij,9v,1id,al 1jh,9s,1ke,8e 1jh,9q,1j2,b0 1kh,-70,1lf,-75 1lh,76,1kn,7d 1kp,7c,1jo,7h 1m1,-jp,1nd,-lt 1nt,-kf,1mi,-kn 1lf,-75,1mg,-7e 1mg,-7e,1nf,-7r 1n8,68,1mc,6p 1mc,6p,1lh,76 1nd,-lt,1o6,-jp 1nf,-7r,1o7,-89 1o7,-89,1os,-8p 1or,4o,1o3,5j 1o3,5j,1n8,68 1pu,-lp,1pc,-lp 1pc,-lp,1p3,-l7 1p3,-l7,1pj,-ko 1pj,-ko,1qe,-kk 1qa,-jq,1p8,-jq 1pd,-9c,1pq,-a3 1os,-8p,1pd,-9c 1pu,2o,1pc,40 1pc,40,1or,4o 1qj,-lo,1pu,-lp 1qe,-kk,1qo,-k4 1qo,-k4,1qa,-jq 1qp,-bg,1qv,-co 1qv,-co,1r1,-c4 1q2,-au,1q6,-bi 1r2,-c5,1r7,-aj 1q5,-bi,1qe,-c6 1qe,-c6,1qi,-be 1qi,-be,1qk,-ce 1qk,-ce,1qp,-bg 1pq,-a3,1q2,-au 1r7,-aj,1rc,-9h 1rf,2,1ra,-u 1ra,-u,1ql,-v 1ql,-v,1q9,1i 1q9,1i,1pu,2o 1t2,-lk,1sj,-lj 1sj,-lj,1s2,-lk 1s2,-lk,1rj,-lm 1rj,-lm,1rj,-l5 1rj,-l5,1rh,-kn 1rh,-kn,1rs,-kj 1rs,-kj,1sg,-kj 1sg,-kj,1sr,-kl 1t3,-je,1sr,-ji 1sr,-ji,1sg,-jh 1sg,-jh,1s1,-jh 1s1,-jh,1rj,-je 1rc,-9h,1rj,-8n 1ri,-8p,1rq,-88 1rq,-88,1s4,-7t 1s4,-7t,1sl,-7i 1sl,-7i,1ta,-7c 1s2,20,1rn,13 1rn,13,1rf,2 1t5,3b,1sh,2o 1sh,2o,1s2,20 1sr,-kl,1t1,-kc 1t1,-kc,1t5,-k1 1t5,-k1,1t8,-jj 1t8,-jj,1t3,-je 1ta,-7c,1u4,-79 1u4,-79,1v3,-79 1vu,4h,1ua,40 1ua,40,1t5,3b 1v3,-79,1vn,-7b 1vn,-7b,20c,-7e 22i,52,1vu,4h 20b,-7e,211,-7k 20v,-7j,21o,-7r 22f,-86,231,-8h 231,-8h,23e,-8t 21o,-7r,22g,-86 24i,58,22i,52 24g,-ag,24o,-b7 23e,-8t,23s,-9d 23s,-9d,246,-9t 246,-9t,24f,-ag 29j,59,24i,58 24o,-b7,24r,-bo 24s,-bn,25v,-3g 25v,-3g,26c,-1s 26c,-1s,26s,-d 26s,-d,27b,f 27b,f,27s,12 27s,12,28t,1n 28t,1n,2a6,2a 2a6,2a,2bg,2q 2bm,56,29j,59 2be,2q,2cn,30 2eg,4u,2bm,56 2cn,30,2e0,32 2e0,31,2er,2u 2ha,4j,2eg,4u 2mb,-38,2ip,-38 2ha,4j,2p1,3i 2mb,-39,2l5,-40 2mb,-39,2lc,-25 2ll,-1f,2kr,-n 2kr,-n,2ko,-18 2kq,-p,2ln,-q 2p1,3i,2ql,36 2ql,36,2ri,2r 2ri,2r,2s9,2e 2su,1u,2tg,1a 2tg,1a,2ts,m 2s9,2e,2su,1u 2v2,-1i,33d,-5f 2v3,-1i,2v2,-1p 2v2,-1p,33e,-5n 2ts,m,2u6,-5 2u6,-5,312,-5 302,-2e,302,-5 30m,-5,30m,-30 30m,-1l,31o,-3v 30m,-p,32k,-4p 311,-6,30n,23 30n,23,30g,5j 30g,5j,30i,9b 30i,9b,30n,ap 30n,ap,31g,f2 31g,f2,330,ji 33e,-5n,33e,-5e 330,ji,345,lo #o5,-60 1a0,-8g 1b7,5a 1qq,-ea 24o,-eg 337,-67
Modifiserte litt på en bane som en allerede har laget :)
Min første.
-e2,-83,-3o,6d -9v,-87,-a1,-cn -a4,-dl,-a4,-cq -j,-al,-9p,-b1 -9v,-2d,-9v,-87 -3k,18,-52,p -1i,1h,-3k,18 -3p,1a,6h,c7 -3o,6d,g,b3 c,-bg,-2,-b4 -2,-b4,-j,-aj -1i,1i,1i,1i 28,-cc,1h,-c3 1h,-c3,v,-bt v,-bt,c,-bg g,b3,68,g6 39,-co,2l,-ck 2l,-ck,28,-cc 1i,1i,45,1h 4p,-d1,45,-d1 45,-d1,3j,-cs 3j,-cs,39,-co 45,1i,62,1h ah,-ct,4p,-d1 62,1h,8k,1i 6h,c7,fp,kk 68,g6,e7,ma 8k,1h,aa,1d be,-c5,9s,-cg aa,1d,c4,v d0,-b7,be,-c5 c4,v,dt,0 e9,-9u,d0,-b7 dt,0,f3,-1c fc,-8d,e9,-9u g3,-67,fc,-8d f3,-1c,fs,-2v e7,ma,mr,qa g4,-49,g3,-67 fs,-2v,g4,-49 fl,kh,ns,o5 13h,tg,mo,q9 nt,o4,10r,qg 140,rb,10f,qc 13h,tg,1ae,u5 1bd,sc,140,rb 1bb,sb,1ig,sh 1b7,sa,1bd,sc 1ai,u5,1jh,ua 1ig,sh,1rq,r4 1jh,ua,1o9,tv 1o9,tv,23h,ro 1rq,r4,26j,nk 23h,ro,2c6,nr 26j,nk,2en,g9 2c6,nr,2kr,hc 2df,fg,2gn,gv 2ig,ej,2fk,d7 2hk,fs,2ef,e5 2er,g3,2g2,f1 2gn,bp,2js,d3 2ho,ai,2kj,bo 2i3,c7,2j7,b2 2lg,a4,2iu,9c 2k5,9h,2t1,3m 2kr,hc,2r0,9r 2r2,9r,2t2,7q 2rs,b2,2rj,ap 2s8,ba,2rs,b2 2tj,c8,2to,c9 2tg,c8,2t9,c4 2t9,c4,2t2,bt 2t2,bt,2sm,bj 2sm,bj,2s8,ba 2uh,b6,2uh,a5 2to,c9,2tu,ca 2tu,ca,2u6,ca 2u6,ca,2uf,cc 2uf,cc,2uu,cc 2uu,cc,2va,cd 2vv,b2,2vu,9v 2va,cd,2vp,cd 2vp,cd,309,cb 309,cb,30p,c6 30p,c6,315,c0 315,c0,31f,bs 31f,bs,31m,bo 31m,bo,31u,bn 31u,bn,329,bj 329,bj,32g,bg 36m,d4,33u,ab 33u,ae,33a,9q 32g,bg,32r,b7 32r,b7,331,b3 36m,d5,3ac,g6 39k,3m,3at,9k 3at,9k,3h5,gl 3ac,g6,3lb,n3 3h5,gl,3p0,mt 3lj,n8,3ok,p9 47r,sr,3pq,mt 3pq,mt,3os,mq 3ok,p9,3r4,qh 3r4,qh,3vi,rr 3vg,rr,486,v2 4b4,su,47r,sr 486,v2,4er,v2 4lf,su,4b4,su 4er,v2,4ol,v1 4pd,rh,4ll,rh 4ll,rh,4lk,st 4p7,uk,4ok,v1 4p6,uj,4pb,rl #-62,23 a0,-c2 1j9,tr 2q7,9o 3v5,r7 4ol,u3
her er min korte men bittelitt tricky
-lt,-n,-ls,-2v -ll,n,-lt,-n -lj,-4l,-ko,-5q -ko,-5q,-jp,-6a -ls,-2v,-lj,-4l -kk,2s,-ll,n -ju,3p,-kl,2s -i4,4v,-j2,4g -j2,4g,-ju,3p -gl,55,-i5,4t -fe,59,-gl,55 -e3,-4u,-ct,-34 -e2,-4s,-el,-5j -e1,51,-fe,59 -ct,-34,-bu,-p -1c,1k,-ch,4n -ch,4n,-e1,51 -bp,-o,1c,-7c -1i,1i,1i,1i 15,-74,19,20 17,-79,c9,-7i 18,1k,4s,1e 1t,2j,13,2g 13,2g,13,1t 3a,-2b,1k,-13 3h,-1p,32,-2e 1k,-13,2b,-4 2b,-4,2t,1 3m,-1t,2j,-12 2j,-12,2i,-t 2i,-t,2f,-i 2f,-i,2v,-c 2v,-c,2n,0 26,g,1q,s 1q,s,2f,18 1r,s,3p,k 21,5k,1t,2j 9g,5g,21,5k 50,-5k,3m,-42 3m,-42,56,-26 3m,-46,8a,-42 2p,-12,64,-10 5h,-6,2h,-j 3q,24,34,2m 34,2m,5s,4c 34,2r,8i,2l 3r,1q,48,20 66,-2a,8b,-24 66,-2d,7b,-37 64,-10,5h,-6 6q,0,5l,s 5l,s,6m,24 5o,s,8h,o 6a,-2m,7b,-15 cf,2l,9g,5g c9,-7i,cf,2l eh,-g,l2,4b l0,4c,md,4u md,4u,ng,52 ng,52,oi,54 oi,54,pm,55 pm,55,qb,53 qb,53,qq,50 r3,4o,rd,4g rd,4g,rp,43 rp,43,rs,3p rs,3p,vr,3i qq,50,r3,4o vr,3i,17d,32 17d,32,1fk,bb 1fl,bd,1ge,c6 1ge,c6,1hk,cs 1hk,cs,1ke,do 1ke,do,1lt,di 1lt,di,1me,db 1me,db,1n5,cv 1n5,cv,1nl,ce 1nl,ce,1ns,bo 1ns,bo,1o3,b2 1o3,b2,224,av #-5,-73 21e,ai
Endret av fanboy
Uff, jeg er blitt addicted. Denne var gøy:
-1i,1i,1i,1i -1h,1j,-1h,9t -j,dh,3,88 -1h,9t,-j,dh 3,88,c,dn c,dn,1k,88 26,1r,58,3u 1k,88,2q,ds 2q,ds,3e,7r 3e,7r,5e,eg 58,3u,6k,47 5e,eg,6g,9j 6g,9j,7m,ed 7m,ed,8t,ad 92,5f,at,6g 8t,ad,9o,eg 9o,eg,a4,a6 a4,a6,bd,eq bd,eq,bp,bd bp,bd,bp,f5 bp,f5,el,bc dg,7s,g2,8c el,bc,es,g5 es,g5,g2,d3 h3,ch,ii,e1 g2,d3,ha,gr ha,gr,h3,ci ii,e1,jf,ej jf,ej,kt,f1 kt,f1,mf,f9 mf,f9,nr,fd nr,fd,ov,fd ov,fd,qu,fd qu,fd,si,fc si,fc,u8,f7 u8,f7,v7,es v7,es,vt,ec vt,ec,10f,dn 10f,dn,10l,d2 10l,d2,13r,d5 1gh,-3s,12g,-3s 13r,d5,14a,i1 14a,i1,14m,ja 14m,ja,15e,kg 15e,kg,16g,ld 16g,ld,17q,m3 17q,m3,19b,me 19b,me,1an,mi 1an,mi,1c9,ml 1c9,ml,1es,mh 1es,mh,1go,mb 1mv,-3r,1gh,-3s 1hm,m1,1im,le 1go,mb,1hm,m1 1im,le,1js,kd 1kt,iq,1lp,gl 1js,kd,1kt,iq 1m8,e8,1ml,ak 1ml,ak,1mt,53 1lp,gl,1m8,e8 1mt,53,1mv,-3r #im,99 12g,8s 1l2,-23
Edit: Gjorde om litt.
Endret av HorSe
Mulig å laste ned dette spillet? Det er genialt.
edit:
Ny bane btw. Ikke mulig å vinne, er ingen stjerner med, men den er relativt morsom å kjøre igjennom. Går ann å kjøre begge veier.
-26l,-ar,-247,-ca -27k,-8t,-26l,-ar -27k,-6n,-27k,-8t -268,-4d,-27k,-6n -25e,-88,-1q8,-7t -25k,-88,-25r,-8k -24f,-31,-268,-4d -247,-ca,-22d,-ce -22q,-26,-24f,-31 -1v2,-24,-22q,-26 -1nm,-1o,-1v2,-24 -1qc,-7t,-1kt,-3t -1dr,48,-1nm,-1o -1o0,-1t,-1nv,44 -1nv,44,-1dl,4c -1kt,-3t,-1is,-3r -1gf,-3e,-1kp,-3q -1is,-3r,-1h5,-4n -1h5,-4n,-1gk,-5c -1gk,-5c,-1gf,-3e -1fd,-s,-1gf,-6 -1es,-12,-1fu,-a -1er,-13,-1fd,-s -1ga,31,-1cr,46 -1fe,3m,-1cr,47 -1c9,3p,-1f1,44 -19r,-a,-1es,-12 -1dl,4c,-1dd,44 -1dd,44,-1d8,6f -1e9,4a,-1dc,46 -1e9,4b,-1c6,3m -1ah,3l,-1dp,67 -1dc,6f,-te,3o -1c6,3m,-1da,6i -1ch,3s,-1ah,3l -16s,63,-1ak,3o -1a9,45,-14e,69 -12j,-5,-19r,-a -149,-j,-19e,7 -1a0,4q,-13d,5j -13j,-v,-18g,h -14a,51,-18d,5h -15f,-9,-12j,-1g -12j,-1g,-12e,-1m -12e,-1m,-12j,-7 -ta,2,-10h,-1t -10h,-1t,-10d,-4 -10d,-4,-t9,3 -v9,-v,-q0,v -uj,-h,-p5,c -oj,-i,-s9,m -ou,-7,-st,9 -ti,2,-r8,4 -tg,1,-rf,d -tm,3m,-mn,68 -ml,-23,-qm,t -ns,-12,-rg,r -m8,5s,-s3,4k -kk,5f,-rd,5o -h4,-8o,-ob,-k -nh,5h,-lp,59 -kp,4v,-no,5j -lp,59,-ji,4e -ji,4e,-i9,3p -e5,-41,-h9,-8i -h9,-8i,-h9,-63 -h9,-63,-e7,-42 -i9,3p,-dq,66 -h6,-8n,-e5,-3t -gb,-6k,-bp,-27 -gm,-7a,-cg,-2o -gt,94,-3j,6j -fi,-5j,-aj,-1t -a7,-27,-e5,-41 -e3,63,-a8,79 -99,6t,-e4,6d -6p,5v,-dh,7j -9p,6v,-dj,6j -c2,-2o,-7f,-1j -3o,-1p,-a7,-27 -9p,7u,-1e,1h -60,5a,-99,6t -1a,-1p,-3o,-1p 2o,-1p,-1a,-1p -1i,1i,1i,1i 2n,-1r,76,-22 1i,1i,7m,1f 71,-1u,9t,-38 7m,1f,bc,v 9t,-38,cg,-5f g2,-ch,cb,-f5 bc,v,ed,-b cg,-5f,ec,-82 ed,-b,gj,-2b hp,-8p,g2,-ch gj,-2b,hq,-55 hq,-55,hp,-8p #
Endret av -Nyhus-
-1i,1i,1i,1i 1i,1i,47,1c 47,1c,67,q 67,q,6s,6 6s,6,76,-f 76,-f,7d,-13 80,-11,89,2 89,2,8r,i 8r,i,9u,19 9u,19,au,1j au,1j,d0,1n d0,1n,eo,1e eo,1e,fm,11 hg,-29,gu,-22 fm,11,fm,25 fm,25,id,25 k6,-20,ij,-2d ij,-2d,hg,-29 id,25,nt,25 l5,-1k,k6,-20 m6,-r,l5,-1k o4,-e,m6,-r q3,-k,o4,-e nt,25,r9,1t r9,1t,sa,12 sa,12,sh,3 u8,-1d,vm,-k vm,-k,16h,-k 16h,-k,16h,-5l #-3r,c fv,2v 15o,-1b
En ny bane fra meg, litt utfordrende om man vil ha tak i alle stjernene ;)
8175277[/snapback]
Hvis man holder inne ^ + > hele tida ligger man med hode på hjula! :w00t:
Endret av Latterkongen
8175985[/snapback]
Det heter ghost rider. Posta noe om det lenger bak...
Dere vet hva ghost rider er? Det er et "modus" (egentli bugg da) man kommer inn i hvis man holder inne opp når man starter på denna banen:
-v,-5b,-1t,-4f -1t,-4f,-1n,-3a -1n,-3a,0,-2m 5,-56,-v,-5b t,-3d,-p,-3v -m,-2g,-p,-1o -l,-2h,-2,-2c -2,-2c,-5,-27 -5,-27,-i,-24 -i,-24,-8,-1t -8,-1t,-p,-1o 1,-21,0,-1q 7,-1e,-1,-1i -1i,1i,1i,1i u,-2k,14,-5a 0,-2m,t,-3d 10,-3q,1f,-41 1f,-41,1a,-2k 0,-1q,8,-1p 8,-1p,8,-21 8,-21,7,-1e i,-1j,r,-29 r,-29,11,-1h 11,-1h,1d,-27 1c,-21,1f,-1g 1f,-1g,1o,-1h 1h,1i,88,1i 2a,-42,1o,-42 1o,-42,1i,-2r 2h,-2q,2a,-42 3r,-42,31,-48 31,-48,2q,-3g 2q,-3g,3h,-39 1i,-2r,1r,-2h 1r,-2h,2h,-2q 3b,-2o,2g,-2g 1d,-1n,1o,-1m 1o,-1m,1m,-20 1m,-20,1c,-21 1p,-23,1s,-1f 1s,-1f,22,-22 22,-22,23,-1c 23,-1c,29,-21 2k,-1v,2c,-1c 2b,-1q,2k,-1i 3c,-19,2h,-15 3h,-39,3b,-2o 4f,-3u,3o,-2f 3o,-3n,4i,-3d 2p,-26,3c,-27 3c,-27,3i,-1o 3i,-1o,2t,-1l 2t,-1l,3h,-1j 3h,-1j,3c,-19 3p,-1l,5b,-15 5d,-2e,57,-58 57,-58,6p,-5d 6o,-45,5n,-3s 5n,-3s,6q,-2j 3g,-2a,5b,-1t 5b,-1t,3p,-1l 6p,-5d,7l,-51 7l,-51,6o,-45 7h,-2g,7i,-3e 7l,-45,7a,-42 7a,-42,7j,-3p 7j,-3p,7o,-3t 7o,-3t,7j,-45 8t,-2g,9d,-5c 93,-3t,84,-47 84,-47,7u,-2s 7u,-2s,90,-2i 8d,2v,a6,o 9m,-38,ak,-3a ak,-3a,ag,-43 ag,-43,9i,-3k 9i,-3k,9r,-2r 9r,-2r,aj,-2j ad,55,g8,55 b3,-2f,b2,-3s b2,-3g,bt,-3p bt,-3p,c7,-3p g8,55,kv,64 l2,3s,q3,5f kv,64,pb,7g p9,7g,101,94 101,94,12i,97 12i,97,17f,98 17f,98,18i,8o 1ah,9h,1go,9j 1cu,46,1bu,5r 1bu,5r,1dp,67 1f9,4l,1ej,4m 1ej,4m,1e7,4s 1e7,4s,1e0,5h 1e0,5h,1e3,64 1e3,64,1ea,6e 1ea,6e,1es,6j 1fv,5o,1fa,4k 1ft,69,1fv,5o 1gl,4b,1g5,6a 1f9,6m,1fg,6m 1fg,6m,1ft,69 1et,6h,1fd,6n 1g5,6a,1hi,6u 1go,9j,1io,2p #1g7,8v
8156396[/snapback]
Endret av Newt32
Nyhus: Høyreklikk og velg lagre mål som
8176911[/snapback]
Hvis man spiller det på den siden der er det skikkelig crappy med nyhus sin bane! :w00t:
Latterkongen, det går ikke.
Jeg er ganske fornøyd med denne banen, artig å kjøre:
-fr,-9m,-e9,-7j -fm,-94,-di,-7b -fc,-a9,-b9,-dt -ee,-bt,-fk,-9d -f2,-bj,-fj,-8n -fj,-ao,-f8,-83 -f2,-88,-ch,-7h -ef,-7s,-bi,-7l -f7,-8h,-ct,-7f -dm,-7i,-ai,-8b -dq,-7o,-c7,-7r -8e,-b8,-cd,-7q -8l,-4g,-5k,-6d -6p,-1b,-82,-4u -64,-11,-7r,-4c -87,-2l,-6p,-6c -8d,-3l,-64,-6m -5p,-r,-8e,-49 -74,-1i,-7l,-5d -7o,-20,-79,-67 -55,-o,-7p,-3b -2u,-r,-6n,-1u -44,-o,-7a,-2f -6f,3n,-4f,89 -6b,57,-3e,96 -5h,1u,-5h,6k -63,2c,-54,7n -66,6f,-2l,9c -5t,7g,-1k,9j u,-3r,-4d,-3r -47,-19,u,-19 -4j,8k,1q,ag 13,-7f,-2l,-9f 3,-7g,-2q,-a4 2l,-7m,-1u,-8e 22,-7f,-2b,-8t -2i,9j,4h,aq 6b,-80,-h,-80 -1i,1i,1i,1i -7,1t,38,12 u,-19,u,-3r t,26,3v,i b,af,5m,aj 10,ar,6l,ai 2g,1u,4h,-1 2b,au,6n,a3 58,-9,40,-3b 4s,f,4i,-2l 39,1s,56,-1a 48,1c,4o,-1n 3h,b4,7j,9p 4k,b8,89,93 5m,b9,8j,8h 5v,b7,8t,7t 6f,b5,9a,70 76,al,9g,67 7o,a9,9s,4t 8f,9i,a3,34 8u,8s,a3,1j 9b,7v,9r,p 9j,72,9j,1 9p,73,9j,72 #-df,-8p -37,1p -26,-ak e,-4k n,-22 64,-9n 8h,a
Denne var ganske morsom
-3n,-2e,-42,-1t -42,-1t,-4a,-1d -4a,-1d,-4h,-m -4h,-m,-4m,j -4m,j,-4l,1m -4l,1m,-4f,2d -4f,2d,-47,36 -47,36,-3q,3q -3q,3q,-38,4c -38,4c,-2b,4v 2s,5v,-1j,1i -2d,4u,-27,52 -28,51,i,6u 14,-3h,-5,-3h -1i,1i,1i,1i 1b,3m,-t,2n 10,3l,-u,2a 26,-3e,14,-3h 3v,3o,f,3i 5,35,1s,3o i,6u,6a,aj 36,-2v,26,-3e 1i,1i,2q,15 2q,15,3a,o 2s,5v,2e,4i 2e,4i,1l,4p 2c,4i,34,47 1n,4o,55,36 30,3r,4j,3g 4l,6a,2s,5v 41,-1a,3q,-28 3q,-28,36,-2v 3q,-8,39,p 3q,-7,41,-1a 34,47,38,41 38,41,4t,6a 2g,3n,4g,3i 4q,3a,33,3s 3q,55,64,6g 3k,4o,4v,5s 7g,6l,4l,6a 5q,-52,5p,-6u 5p,-6u,6p,-8b 5u,-76,5n,-6h 6e,-3p,5q,-52 5n,-5h,63,-4c 63,-4c,6t,-3a 55,36,6f,6e 5h,48,75,6h 78,57,5e,45 56,3k,60,4g 57,3r,6i,4s 57,37,6a,4p 4o,5o,7j,6t 5l,65,8n,71 5b,50,7n,6n 7m,-2u,6e,-3p 6t,-3a,86,-2p 7m,-2u,9r,-2f 8i,2h,7p,2m 5h,3q,6h,4r 56,37,92,6k 64,55,7f,6j 6s,60,7u,6r 78,56,9c,6s 79,58,73,58 7d,6l,b7,79 6a,aj,74,b2 74,b2,8g,bg 8m,-5i,g1,-4o ao,2o,8n,2g 8h,2h,c6,t 7t,5t,9u,76 b6,77,5k,4u 9c,6h,7f,5d 73,6c,88,6s a8,78,8m,6i 8g,bg,a0,bi iq,-27,9q,-2f cd,3r,ao,2o a9,2i,b9,30 b9,30,9s,2i 9c,6s,a8,78 a0,bi,b2,ba c4,af,af,bt bi,b1,ad,bi c5,t,e7,c dh,5u,cd,3r c1,3g,cl,49 b1,76,be,6q b2,ba,bp,at bn,at,cs,9j cb,ab,dj,89 ct,4l,du,7e de,89,dh,5u da,5c,dl,73 dc,5l,dg,6s df,7m,d6,93 cs,9j,de,89 df,8v,ck,aj e7,c,f0,p f0,p,he,23 g1,-4o,iv,-4b he,23,in,3a in,3a,k7,4a iv,-4b,lo,-3l n9,1n,iq,-27 k7,4a,n3,5i lo,-3l,ng,-3d lq,l,qf,2p pd,20,lk,11 nu,1o,ll,b oi,-ac,n3,-a1 n3,-a1,m2,-8v lt,-8g,mc,-9f mo,-9q,ni,-a6 m2,-8v,lt,-84 tj,26,n9,1n n3,5i,sm,6l qm,-a0,oi,-ac o2,-aa,p9,-aa ng,-3d,pe,-3f pv,-3j,ou,-3e pr,-ab,rb,-9g pe,-3f,qm,-42 s2,-5i,q7,-3p r3,-4d,pv,-3j rj,-23,qa,-12 rt,-8v,qm,-a0 rb,-9g,sd,-8b rm,-9f,s4,-80 s4,-73,rt,-8v rl,-96,s2,-8f rm,-58,s4,-73 s4,-7k,ru,-61 qm,-42,rm,-58 ru,-61,r8,-4h se,-2h,rj,-23 rp,-29,t3,-2l rm,6g,tk,6k u8,-2h,se,-2h sm,6l,v1,6e t4,6l,vc,66 102,-1p,u8,-2h tn,-2l,um,-2b vd,64,ue,6k tp,6m,112,5c v1,6e,10h,5e 115,-l,102,-1p vc,-25,10b,-1h 10b,-1h,11c,-5 10h,5e,11d,3p 10q,50,vv,5v vv,5v,110,4m 110,52,vn,66 vn,66,10m,53 vb,64,10f,5m 11n,1k,115,-l 10r,-12,11d,5 11j,10,11k,2g 11d,3p,11n,1k 115,4b,11k,2o 11i,39,115,4b #mi,-85 n9,-88 mp,-7u n6,-7r n8,-83 n1,-7l n3,-72 n5,-6j mj,-72 mu,-79 n9,-7g mq,-7k mr,-6v nf,-74
-1i,1i,-p,1i -p,1i,0,21 0,21,p,2f p,2f,1i,2q 1i,2q,2b,31 2b,31,34,34 34,34,3t,31 3t,31,4m,2q 4m,2q,5f,2f 5f,2f,68,21 71,1i,7q,12 68,21,71,1i 7q,12,8j,k 8j,k,9c,9 9c,9,a5,2 a5,2,au,0 au,0,bn,2 bn,2,cg,9 cg,9,d9,k d9,k,e2,12 e2,12,er,1h er,1h,fk,21 fk,21,gd,2f gd,2f,h6,2q h6,2q,hv,31 hv,31,io,34 io,34,jh,31 jh,31,ka,2q ka,2q,l3,2f l3,2f,ls,21 ml,1i,ne,12 ls,21,ml,1i ne,12,o7,k o7,k,p0,9 p0,9,pp,2 pp,2,qi,0 qi,0,rb,2 rb,2,s4,9 s4,9,st,k st,k,tm,12 tm,12,uf,1h uf,1h,v8,21 v8,21,101,2f 101,2f,10q,2q 10q,2q,11j,31 11j,31,12c,34 12c,34,135,31 135,31,13u,2q 13u,2q,14n,2f 14n,2f,15g,21 169,1i,172,12 15g,21,169,1i 172,12,17r,k 17r,k,18k,9 18k,9,19d,2 19d,2,1a6,0 1a6,0,1av,2 1av,2,1bo,9 1bo,9,1ch,k 1ch,k,1da,12 1da,12,1e3,1i 1e3,1i,1es,21 1es,21,1fl,2f 1fl,2f,1ge,2q 1ge,2q,1h7,31 1h7,31,1i0,34 1i0,34,1ip,31 1ip,31,1ji,2q 1ji,2q,1kb,2f 1kb,2f,1l4,21 1l4,21,1lt,1h 1lt,1h,1mm,12 1mm,12,1nf,k 1nf,k,1o8,9 1o8,9,1p1,2 1p1,2,1pq,0 1pq,0,1qj,2 1qj,2,1rc,9 1rc,9,1s5,k 1s5,k,1su,12 1su,12,1tn,1i 1tn,1i,1ug,21 1ug,21,1v9,2f 1v9,2f,202,2q 202,2q,20r,31 20r,31,21k,34 21k,34,22d,31 22d,31,236,2q 236,2q,23v,2f 23v,2f,24o,21 24o,21,25h,1h 25h,1h,26a,12 26a,12,273,k 273,k,27s,9 29f,1,29e,-8 29e,-8,29n,1 294,0,29o,-b 27s,9,28l,2 28l,2,29e,0 29o,-b,2a6,3 29r,-7,29h,-8 29h,-8,29q,-4 29q,-4,29h,-3 29h,-3,29p,-2 29e,0,2a7,2 2a7,2,2b0,9 2b0,9,2bp,k 2bp,k,2ci,12 2ci,12,2db,1i 2d6,1g,2gv,4e 2gv,4e,2ju,6n 2jq,6k,2ke,75 2ke,75,2l9,7o 2l9,7o,2ls,7u 2ls,7u,2m9,80 2m9,80,2mn,7v 2mn,7v,2n1,7v 2n1,7v,2n6,7u 2n6,7u,2ne,7u 2ne,7u,2nl,7t 2nl,7t,2nr,7t 2nr,7t,2o7,7t 2o7,7t,2ol,7s 2ok,7t,2ql,7q 2ql,7q,2su,7m 2sr,7k,33c,75 33c,75,39n,5o 39n,5o,3h1,4b 3h1,4b,3nl,31 3nl,31,433,-l 433,-l,4d7,-4l 4d7,-4l,4n4,-9p 4n1,-9l,4or,-cl #c1,-35 sn,-2t 1b1,-2g 1pp,-2r 29k,-2h 2tl,6s 4og,-cn
Dagens lille fra meg :)
