Fanboy testen! Sjekk om du er en fanboy.
marius90
Her kan du ta en test som viser om du er litt fanboy eller ei. Kan være morsomt og se hva folk får som resultat. Sorry hvis den har vært postet før.
http://www.nerdtests.com/mq/take.php?id=1256
Jeg fikk dette:
Nintendo Fanboy: 33%
Sony Fanboy: 47%
Microsoft Fanboy: 29%
This means you're: Not a fanboy
Skjønner egentlig ikke hvordan jeg kunne få mer % på nintendo enn microsoft da jeg liker microsoft hakket bedre.
Endret av marius90
Nintendo Fanboy: 51%
Sony Fanboy: 31%
Microsoft Fanboy: 40%
What does it mean?
You like all the systems pretty equally, or at least don't love any of thes systesms. Good for you, you like vareiety.
Nintendo Fanboy: 19%
Sony Fanboy: 24%
Microsoft Fanboy: 42%
What does it mean?
Nintendo Fanboy: 37%
Sony Fanboy: 60%
Microsoft Fanboy: 8%
This means you're: A Microsoft Hater
What does it mean?
You aren't a fanboy, since you love both Nintendo and Sony. But you really hate Bill Gates and everything he creates. Or at least you don't care about anything he creates.
Bombe :p
Endret av tidus2k4
Gjest Slettet+981234789
Nintendo Fanboy: 30%
Sony Fanboy: 18%
Microsoft Fanboy: 43%
What does it mean?
ganske riktig...
kanskje litt mindre på Nintendo og litt mer på¨MS
Endret av Slettet+981234789
Nintendo Fanboy: 52%
Sony Fanboy: 52%
Microsoft Fanboy: 58%
This means you're: You're a Gamer!
What does it mean?
You love all the systems! You'll play anything! Way to go. You should be proud of yourself! You are one of an elite few, to say the least.
:w00t:
Endret av gitarfreak
Skremmende nøyaktig, egentlig :)
Nintendo Fanboy: 64%
Sony Fanboy: 18%
Microsoft Fanboy: 22%
This means you're: Nintendo #1
What does it mean?
You are a gamer, since you like all the systems, but Nintendo is your weapon of choice. But you don't show disdain for any system.
Sony Fanboy: 9%
Microsoft Fanboy: 14%
This means you're: Somewhat Fanboy
What does it mean?
Well, you like Nintendo the best, but you aren't in love with them. Guess you're really not in love with video games period... or at least you're not obsessed with them. Which may not be a bad thing.
