Halo will go on after third installment
http://www.xboxic.com/news/2560
Klikk for å se/fjerne innholdet nedenfor
If you thought that the fight would finish this year, then you’ll be pleased to know that that isn’t quite true as, in collaboration with Peter Jackson, there will be two episodic gaming series coming, one set in the Halo universe. This was initially discussed at X06, but things went quiet, until now. Also, MS admit that the 360 failing on so many people could have been better handled.
All the talking took place during a Microsoft-hosted breakfast session between Shane Kim and Chris Satchell. Of the hardware problems, Kim was reported as saying:
“It’s unfortunate that people have had problems with their Xbox 360… we’ve got room for improvement on both sides of the equation - it’s a top priority for us.”
At least they have recognised the problem and have plans to deal with it. Quite reassuring for anyone who has ever had to experience the Customer “Service” of Microsoft.
Of the episodic gaming series, it was confirmed by Kim that the Halo project was further advanced than the unannounced project, but both are still in the design phase right now. The collaboration between Peter Jackson and Bungie was originally announced at X06, where it was put forward that “a collaborative effort with Bungie Studios to co-create a completely new and original chapter in the Halo franchise.”
There is no more information at the moment as to what kind of content this will be, but it is likely to be in downloadable form, and probably for a price. Not that that will stop any Halo fanatics from buying it!
Halo: The Ghosts of Onyx :)
8176094[/snapback]
Ah... Har bare lagt merke til Halo: The Fall of Reach, Halo: The Flood, Halo: First Strike og Halo Graphic Novel. Men er det
enda en spartan-type
?Spennende! Fortell litt uten å ødelegge The Flood og First Strike!
Vel, skal prøve å fortelle litt uten å ødelegge for de andre bøkene:
Dr. Halsey var jo sjefen for SPARTAN-II prosjektet og valgte ut deltagere til prosjektet med omhu (og deltagere med visse genetiske trekk). Halo 1 gav uttryk fo at Master Chief var den siste spartan i live. Det var jo ikke helt sant men det er/var ikke mange SPARTAN-II igjen.
Ettersom at det var så og si kun spartan-medlemer som kunne fighte The Coventant, trengte menneskeenheten flere spartaner. Uten at Dr. Halsey visste om det, startet generel Ackerson i United Nations Space Command et prosjekt for nye spartaner hvor deltagere IKKE ble valgt ut med omhu og hvor de modifiserte de nye på andre måten enn SPARTAN-II (som resulterte i at de var litt ustabile mentalt). SPARTAN-III har ikke nær så bra armour som SPARTAN-II men de har kamuflasjedrakt som Elites har i Halo 2. Onyx er planeten de blir trent på, som Reach var planeten SPARTAN-II ble trent på
Postet denne i en annen Halo-tråd. Kan være til interesse for samtlige.
Kronologisk rekkefølge av Halo
Hvordan det hele begynte, med både The Covenant og SPARTAN-prosjektet. Dette er historien før spillet Halo: Combat Evolved
Halo: The Flood / Halo: Combat Evolved
Dette er spillet Halo: Combat Evolved i bokformat. Ikke bare gjenforteller boken spillet men du får vite mye mer om marinen som landet på Halo og hvorfor/hvordan Master Chief var den "eneste" som overlevde.
Halo: The First Strike
Denne historien er mellom spillet Halo: Combat Evolved og Halo 2, om hvordan The Covenant fant jorda og hvordan The Arbiter ble til.
Halo 2
Halo: Ghosts of Onyx
Fjerde boka i serien fungerer som en
sidehistorie og fortsettelse av hendelser fra tredje
boka fremfor en fortsettelse av spillserien.
Halo Graphic Novel
Her får du faktisk se ansiktet til en Spartan-II =) Ellers er det historier som er knyttet til Halo-universet som ikke noen andre har gjenfortalt, f.eks hvordan Sgt. Johnson klarte å rømme fra The Flood når hans crew ble overfalt i Forerunner-strukturen i sumpen på Halo (du besøker stedet i Halo: Combat Evolved, første møtet med The Flood)
The Art of Halo: Creating a virtual Masterpiece
Har får du sketcher av alt innenfor Halo-universet. Veldig nyttig for å visualisere Covenant etc. i novellene og her er den eneste sketchen gjengitt av en Covenant Engineer.
Bokkilden selger de tre første bøkene samlet for under 200kr 220kr. Ellers er det ikke noe ekstrakostnad i form av moms og utgifter for bokbestilling på Amazon siden bøker er fritatt for slike merkostander.
Endret av überGoliath
