trenger hjelp med script
hei, når jeg prøver og poste noe på siden min så kommer denne feil meldingen opp:
Warning: chmod(): Operation not permitted in /mnt/home4/s/public_html/inc/plugins.php on line 193
Jeg er helt blank på php og scriptet jeg bruker er Aj-fork..
her er koden som brukes i plugins.php filen:
Klikk for å se/fjerne innholdet nedenfor
<?php
define('ROOTPATH', $cutepath ? $cutepath : '.');
define('CURRENT_APPLICATION', 'CN:AJ');
define('ACTIVE_PLUGINS_FILE', ROOTPATH.'/data/active-plugins.php');
define('PLUGINS_DIRECTORY', ROOTPATH.'/plugins');
define('PLUGINS_DATA_DIRECTORY', ROOTPATH.'/data/plugins');
define('PLUGIN_SETTINGS_FILE', PLUGINS_DATA_DIRECTORY.'/settings.php');
define('PLUGIN_XFIELDS_FILE', PLUGINS_DATA_DIRECTORY.'/xfields-data.php');
define('PLUGIN_FRAMEWORK_VERSION', '1.1.5');
define('PLUGIN_DEFAULT_PRIORITY', 50);
function LoadActivePlugins() {
foreach (active_plugins() as $plugin_filename => $active) {
 $path = PLUGINS_DIRECTORY.'/'.$plugin_filename;
 if (is_file($path))
 	include($path);
 else
 	disable_plugin($plugin_filename);
function plugin_enabled($plugin_filename) {
$plugins = active_plugins();
if ($plugins[$plugin_filename])
 return true;
else
 return false;
function enable_plugin($plugin_filename) {
$plugins[$plugin_filename] = true;
SaveArray($plugins, ACTIVE_PLUGINS_FILE);
function disable_plugin($plugin_filename) {
unset($plugins[$plugin_filename]);
/* List Plugins */
function available_plugins() {
$ffl = FileFolderList(PLUGINS_DIRECTORY,1);
$plugins = $ffl[file];
if (!empty($plugins))
 foreach ($plugins as $null => $pluginfile) {
 	if (stristr($pluginfile, ".htaccess")) { continue; }
 	$plugin_data = GetContents($pluginfile);
 	preg_match("{Plugin Name:(.*)}i", $plugin_data, $plugin[name]);
 	preg_match("{Plugin URI:(.*)}i", $plugin_data, $plugin[uri]);
 	preg_match("{Description:(.*)}i", $plugin_data, $plugin[description]);
 	preg_match("{Author:(.*)}i", $plugin_data, $plugin[author]);
 	preg_match("{Author URI:(.*)}i", $plugin_data, $plugin[author_uri]);
 	preg_match("{Version:(.*)}i", $plugin_data, $plugin[version]);
 	preg_match("{Application:(.*)}i", $plugin_data, $plugin[application]);
 	preg_match("{Conflicts:(.*)}i", $plugin_data, $plugin[conflicts]);
 	preg_match("{Required Framework:(.*)}i", $plugin_data, $plugin[framework]);
 	$required_version = trim($plugin[framework][1]);
 	$conflicts = trim($plugin[conflicts][1]);
 	$application = trim($plugin[application][1]);
 	// Skip plugins that need a better framework
 	if ($required_version && version_compare(PLUGIN_FRAMEWORK_VERSION, $required_version, '<'))
   $compatible = false;
 	else
   $compatible = true;
 	if ($conflicts && in_array($conflicts, active_plugins()))
   $conflicting = true;
 	else
   $conflicting = false;
 	// Skip plugins designed for other systems
 	if ($application && $application != 'CuteNews')
   continue;
 	$available_plugins[] = array(
   name  => trim($plugin[name][1]),
   uri  => trim($plugin[uri][1]),
   description	=> trim($plugin[description][1]),
   author  => trim($plugin[author][1]),
   author_uri	=> trim($plugin[author_uri][1]),
   version  => trim($plugin[version][1]),
   application	=> trim($plugin[application][1]),
   file  => basename($pluginfile),
   framework	=> $required_version,
   compatible	=> $compatible,
   conflicting => $conflicting,
else
 $available_plugins = array();
return $available_plugins;
function active_plugins() {
if (!is_file(ACTIVE_PLUGINS_FILE))
 return array();
$active_plugins = LoadArray(ACTIVE_PLUGINS_FILE);
return $active_plugins;
/* Actions And Filters */
function add_action($hook, $functionname, $priority = PLUGIN_DEFAULT_PRIORITY) {
global $actions;
$actions[$hook][] = array(
 'name' => $functionname,
 'priority' => $priority,
function run_actions($hookname) {
global $actions;
$todo = $actions[$hookname];
if (!$todo)
 return false;
usort($todo, 'SortByActionPriority');
foreach ($todo as $null => $action)
 $buffer .= $action['name']($hookname);
return $buffer;
function add_filter($hook, $functionname, $priority = PLUGIN_DEFAULT_PRIORITY) {
global $filters;
$filters[$hook][] = array(
function run_filters($hookname, $tofilter) {
global $filters;
$todo = $filters[$hookname];
if ($todo) {
 foreach ($todo as $null => $filter)
 	$tofilter = $filter['name']($tofilter, $hookname);
return $tofilter;
function SortByActionPriority($a, $b) {
return $a[priority] > $b[priority] ? 1 : -1;
/* File Functions */
function FileFolderList($path, $depth = 0, $current = '', $level=0) {
if ($level==0 && !@file_exists($path))
 return false;
if (is_dir($path)) {
 $handle = @opendir($path);
 if ($depth == 0 || $level < $depth)
 	while($filename = @readdir($handle))
   if ($filename != '.' && $filename != '..')
   	$current = @FileFolderList($path.'/'.$filename, $depth, $current, $level+1);
 @closedir($handle);
 $current[folder][] = $path.'/'.$filename;
} else
 if (is_file($path))
 	$current[file][] = $path;
return $current;
function LoadArray($pathandfilename) {
if (is_file($pathandfilename)) {
 @include($pathandfilename);
 return $array;
return array();
function WriteContents($contents,$filename) {
if (file_exists($filename))
 if (!is_writable($filename))
 	if (!chmod($filename, 0666))
    return false;
if (!$fp = @fopen($filename, 'wb+'))
 return false;
if (@fwrite($fp, $contents) === false)
 return false;
if (!@fclose($fp))
 return false;
return true;
function GetContents($filename) {
$file = @fopen($filename, 'rb');
if ($file) {
 while (!feof($file)) $data .= fread($file, 1024);
 fclose($file);
} else {
 return false;
return $data;
function SaveArray($array,$filename) {
$contents = '<?php
$array = '. var_export($array,1) .';
return WriteContents($contents, $filename);
/* Data Handling Classes */
class PluginSettings {
function PluginSettings($plugin_name) {
 $this->name = $plugin_name;
 $this->all_settings = LoadArray(PLUGIN_SETTINGS_FILE);
 $this->settings = $this->all_settings[$plugin_name];
function save() {
 $this->all_settings[$this->name] = $this->settings;
 return SaveArray($this->all_settings, PLUGIN_SETTINGS_FILE);
function delete() {
 unset($this->settings);
 return $this->save();
class XFieldsData {
function XFieldsData() {
 $this->file = PLUGIN_XFIELDS_FILE;
 $this->data = LoadArray(PLUGIN_XFIELDS_FILE);
function fetch($news_id, $field_name) {
 return $this->data[$news_id][$field_name];
function set($value, $news_id, $field_name) {
 $this->data[$news_id][$field_name] = $value;
function increment($news_id, $field_name) {
 return $this->data[$news_id][$field_name]++;
function decrement($news_id, $field_name) {
 return $this->data[$news_id][$field_name]--;
function delete($news_id) {
 unset($this->data[$news_id]);
function save() {
 return SaveArray($this->data, $this->file);
/* XFields self-cleaning plugin */
add_action('deleted-single-entry', 'clean_single_xfields');
add_action('deleted-multiple-entries', 'clean_multiple_xfields');
function clean_single_xfields($hook) {
global $old_db_arr;
$news_id = $old_db_arr[0];
$xfields = new XfieldsData();
$xfields->delete($news_id);
$xfields->save();
function clean_multiple_xfields($hook) {
global $selected_news;
foreach ($selected_news as $null => $news_id)
$xfields->save();
<?php
   return false;
return false;
return false;
if (!@fclose($fp))
return false;
return true;
Det ser ut som om denne funksjonen prøver å chmode filer som ikke er skrivbare - du har vist ikke ordnet rettigheter på alle filene.
