Hva skjer når dere går inn på denne siden?
This is our new frontpage here at ManagerLeague. This page requires a modern browser and utilizes technologies such as CSS, Javascript and AJAX.
If you have problems using this page, we recommend you upgrade your browser, as you might experience ingame problems as well. We recommend FireFox. To our knowledge, all recent browsers support these technologies fine, but old versions of Opera and Netscape (as well as certain combinations of Internet Explorer and some Internet Security Packages) may suffer from problems.
You can get around this by using our OLD frontpage, but these advanced features may be required in the game itself.
Do not hesitate to contact support if you need assistance.
Så...der har du svaret.
Jeg lastet akkurat ned firefox, og broren min har en helt ny mac med opera, men kommer ikke inn med noen av dem...hvordan kan jeg bruke den "gamle" versjonen av forsiden?
Edit: Kommer ikke inn på den "gamle" versjonen heller jeg...
Endret av Sondre05
Server not found
Firefox can't find the server at www.managerleague.com.
* Check the address for typing errors such as
ww.example.com instead of
www.example.com
* If you are unable to load any pages, check your computer's network
connection.
* If your computer or network is protected by a firewall or proxy, make sure
that Firefox is permitted to access the Web.
jaja
