Endre minnetimings med P5B-E PLUS?
bs 450mhz
dram ddr2 900mhz
pci express frequency 33.33mhz
memory volt 2.05v
cpu core volt, 1.385
fsb termination voltage 1.300v
nb core 1.45v
sb vcore 1.60v
multiplier:7
Dram cas larency 4
dram ras to cas delay 4 dram clocks
dram ras precharge 4 dram clocks
dram ras activate to precha 12 dram clocks
dram write recovery time 4 dram cloacks
dram trfc 10
dram trrd 10
rank write to read delay 10
read to precharge delay 10
write to precharge delay 10
Rundt 55 load og rundt 38 idle er det greit?
PCI=33,33. PCI-Express=101?
Denne kan settes opp litt for å stabilisere, hvis du skal veldig høyt på FSB.
8110854[/snapback]
Greie temperaturer egentlig. CPU overlever vel en stund til. :tease:
