jornt Skrevet 9. desember 2002 Del Skrevet 9. desember 2002 Hei! Har postet denne på en nyhetsgruppe, teksten er derfor på engelsk: Hi! I'm having a strange problem with my work computer based on ABIT BD7II RAID When the computer has been on for some time, for example over the night, or the monitor has been turned off after 30 min idle time, I experience weird problems with my display. Pull-down menus goes black, like you can see on these images: http://home.no.net/jornt/problem.gif http://home.no.net/jornt/problem2.gif The menu choices become visible when I place the mouse over them. If I restart the computer, the problem disappears until next time the computer has been idle for a certain amount of time. One single program, ICQ, goes bananas every time I come to work and the computer has been turned on during the night. "Low system resources", "Out of memory", and lots of very strange display problems. I have to shut down and restart ICQ to get rid of the problem. I've tried 3 different versions of ICQ, but always get the same problems. I thought this could be a driver problem on my nVidia MX440 card. But I've changed drivers several times, updated Windows 2000 with service pack 3, reinstalled Windows 2000, and so on. I've even changed graphics card, to an old Matrox Millennium G400. But the problem is still there! :sad: So I think the problem must be eiter the motherboard, memory or the processor. I've flashed the BIOS with the newest update, I've changed memory settings and other BIOS settings, but I can't get rid of this problem. I would be thankful if anyone could help me with this one.. :smile: Regards, - Jørn Tømmerås Lenke til kommentar
Zork Skrevet 9. desember 2002 Del Skrevet 9. desember 2002 Er ingen ekspert, men dette ser ut som minne-problemer for meg. Menyer som blir svarte slik du har her, er ett typisk symptom på at det er for lite minne tilgjengelig. Du har ikke hentet ned en skjermsparer eller noe annet program som typisk starter opp når maskinen står ubrukt en stund? Kan jo være en 'memory-leak' i ett av disse. Lenke til kommentar
jornt Skrevet 9. desember 2002 Forfatter Del Skrevet 9. desember 2002 Har 512 MB minne, og swapfil på 768 MB. Problemet oppstår uansett om jeg har mange eller få programmer oppe. Akkurat nå har jeg endel programmer oppe, men det er fortsatt bare 170 MB som er i bruk. Men som du sier, det kan se ut som om det er for lite minne (ICQ sier jo "low on system resources", "out of memory" o.l.) Maskinen har dette oppsettet: ABIT BD7II-RAID 512 MB PC2100 CL2 DDR RAM 120 GB Western Digital 8 MB 1.8 GHz P4 ASUS 40x CD-brenner og en NEC DVD-ROM. Vanskelig å si hvor problemet ligger.. :-/ - Jørn Lenke til kommentar
jornt Skrevet 9. desember 2002 Forfatter Del Skrevet 9. desember 2002 Ingen som har vært borti lignende problem før? - Jørn Lenke til kommentar
EinarB Skrevet 9. desember 2002 Del Skrevet 9. desember 2002 Har opplevd lignende, og mistenker minnet på skjermkortet for problemet. Lenke til kommentar
jornt Skrevet 10. desember 2002 Forfatter Del Skrevet 10. desember 2002 "I've even changed graphics card" Jeg har prøvd å bytte skjermkort, var nesten sikker på at skjermkortet forårsaket problemet - men det ser akkurat likedan ut med et helt annet skjermkort. Prøvde det med å ta vekk "Turn off monitor" og heller sette på en skjermsparer i går ettermiddag. Når jeg kom på jobb i morges var PC'en (og ICQ) faktisk helt normal, så kanskje problemet nå er løst. :smile: - Jørn Lenke til kommentar
soveplast Skrevet 10. desember 2002 Del Skrevet 10. desember 2002 På jobben har vi erfart en del sånne, men det var på litt eldre maskiner. Kom etter skjermsparer. Vi prøvde å bytte skjermkort og legge inn alt på nytt, men det var like ille. Vi fant ikke ut noe særlig, men regnte med det var et maskinproblem. Dette var da Pentium 166mhz maskiner. opptil 200. Lenke til kommentar
Hans Majestet Skrevet 10. desember 2002 Del Skrevet 10. desember 2002 Det kan se ut som du har definert en for liten swapfil. Swapfila bør wære minst 2xRAM helst 3xRAM. Hvis du ikke har definert noe bestemt swapfil selv, bør du sjekke at det er plass nok på den partisjonen windows er innstaler på. Det som skjer er at Windows speiler innholdet i RAM over i swapfila når "strømsparing" kobler inn. MVH. Hans Lenke til kommentar
