Hvordan få boter på lan? (BF2)
Hei, lurer på hvordan jeg får boter når jeg starter en lokal sever, er det noe program jeg kan laste ned elns?
Har utforsket banene på lan, og det virker mye kulere å spille på en 64 player bane med boter enn på en 16 player bane, som man må på singleplayer.
Increasing Singleplayer Bots
To increase the number of bots used in singleplayer mode, go to your \Program Files\EA Games\Battlefield 2\mods\bf2\AI directory and open the file aidefault.ai with Notepad or Wordpad (make sure to create a backup copy of it first). Read the instructions in the file which basically involves placing the word REM in front of each of the first 5 lines starting with 'aiSettings.set', then removing the REM's in front of the next 4 lines starting with 'aiSettings.set'. Change the number at the end of the aiSettings.setMaxNBots 32 line to determine the number of bots to use (e.g. aiSettings.setMaxNBots 64 for 64 bots). Note that more bots can really stress your system and hence destabilize it, causing a crash back to desktop - particularly for those with older CPUs. For example, 64 bots on most systems will cause a crash.
Eventuelt: http://www.fileplanet.com/154700/150000/fi...-on-the-SP-Maps
Første og andre resultat på google forresten :p
Endret av Mow
