Får ikke kontakt med SAMBA
Har i flere dager prøvd å koble meg opp til en av mine maskiner via SAMBA, men uten hell.
SAMBA er svært konfigurerbar, men når man ikke helt vet hva man holder på med, er det ikke så lett.
Maskinen jeg prøver å koble opp mot (kilmanjaro), kjører Ubuntu edgy, SAMBA 3.0.22 og openSSH server (port 512). Har også opprettet en Linux bruker: smbguest
Når jeg kjører lokalt, fungerer det fint:
smbclient -L 10.0.0.2 [-U smbguest]
Men fra annen Linux maskin får jeg:
abc@gallepiggen:~$ smbclient -L 10.0.0.2
timeout connecting to 10.0.0.2:445
timeout connecting to 10.0.0.2:139
Error connecting to 10.0.0.2 (Operation already in progress)
Connection to 10.0.0.2 failed
Her er min smb.conf
[global]
; Uncomment this if you want a guest account
guest account = smbguest
map to guest = bad user
passdb backend = tdbsam guest
log file = /var/log/samba/%m.log
lock directory = /var/lock/samba
interfaces = eth1 lo
bind interfaces only = yes
encrypt passwords = yes
;smb passwd file = /etc/samba/smbpasswd
passwd program = /usr/bin/passwd %u
passwd chat = *password* %n\n *password* %n\n *changed*
unix password sync = Yes
workgroup = WORKGROUP
security = share
restrict anonymous = no
domain master = yes
preferred master = yes
max protocol = NT
ldap ssl = No
server signing = Auto
netbios name = UBU
wins support = yes
[homes]
comment = Home Directories
browseable = no
read only = no
create mask = 0750
invalid users = root nobody smbguest
[tmp]
comment = Temporary file space
path = /tmp
read only = no
guest ok = yes
[public]
comment = Public Stuff
path = /avMedia
guest ok = yes
read only = no
write list = @smbguest
Her er oversikt over iptables:
xyz@kilmanjaro:~$ sudo iptables -L
Chain INPUT (policy DROP)
target    prot opt source              destination
ACCEPT    tcp  --  speedtouch.lan      anywhere            tcp flags:!FIN,SYN,RST,ACK/SYN
ACCEPT    udp  --  speedtouch.lan      anywhere
ACCEPT    all  --  anywhere            anywhere
ACCEPT    icmp --  anywhere            anywhere            limit: avg 10/sec burst 5
DROP      all  --  anywhere            255.255.255.255
DROP      all  --  anywhere            10.0.0.255
DROP      all  --  BASE-ADDRESS.MCAST.NET/8  anywhere
DROP      all  --  anywhere            BASE-ADDRESS.MCAST.NET/8
DROP      all  --  255.255.255.255      anywhere
DROP      all  --  anywhere            0.0.0.0
DROP      all  --  anywhere            anywhere            state INVALID
LSI        all  -f  anywhere            anywhere            limit: avg 10/min burst 5
INBOUND    all  --  anywhere            anywhere
LOG_FILTER  all  --  anywhere            anywhere
LOG        all  --  anywhere            anywhere            LOG level info prefix `Unknown Input'
Chain FORWARD (policy DROP)
LOG        all  --  anywhere            anywhere            LOG level info prefix `Unknown Forward'
Chain OUTPUT (policy DROP)
ACCEPT    tcp  --  kilmanjaro          speedtouch.lan      tcp dpt:domain
ACCEPT    udp  --  kilmanjaro          speedtouch.lan      udp dpt:domain
OUTBOUND  all  --  anywhere            anywhere
LOG        all  --  anywhere            anywhere            LOG level info prefix `Unknown Output'
Chain INBOUND (1 references)
ACCEPT    tcp  --  anywhere            anywhere            state RELATED,ESTABLISHED
ACCEPT    udp  --  anywhere            anywhere            state RELATED,ESTABLISHED
LSI        all  --  anywhere            anywhere
Chain LOG_FILTER (5 references)
Chain LSI (2 references)
LOG        tcp  --  anywhere            anywhere            tcp flags:FIN,SYN,RST,ACK/SYN limit: avg 1/sec burst 5 LOG level info prefix `Inbound '
DROP      tcp  --  anywhere            anywhere            tcp flags:FIN,SYN,RST,ACK/SYN
LOG        tcp  --  anywhere            anywhere            tcp flags:FIN,SYN,RST,ACK/RST limit: avg 1/sec burst 5 LOG level info prefix `Inbound '
DROP      tcp  --  anywhere            anywhere            tcp flags:FIN,SYN,RST,ACK/RST
LOG        icmp --  anywhere            anywhere            icmp echo-request limit: avg 1/sec burst 5 LOG level info prefix `Inbound '
DROP      icmp --  anywhere            anywhere            icmp echo-request
LOG        all  --  anywhere            anywhere            limit: avg 5/sec burst 5 LOG level info prefix `Inbound '
Chain LSO (0 references)
LOG        all  --  anywhere            anywhere            limit: avg 5/sec burst 5 LOG level info prefix `Outbound '
REJECT    all  --  anywhere            anywhere            reject-with icmp-port-unreachable
Chain OUTBOUND (1 references)
Mvh
Rådvill og forventningsfull
Hva om du slår av firewallen?
sudo -s
mkdir /backup
iptables-save -c > /backup/iptables-backup
iptables --flush
Se om det virker. Hvis ikke, reboot, se om det virker igjen...
Hvis ikke kan du gjenopprette iptables med:
iptables-restore -c < /backup/iptables-backup
sudo -s
mkdir /backup
iptables --flush
8075997[/snapback]
Takk for tilbakemelding, men...
Etter flush, får jeg ikke lenger kontakt med omverdenen. ssh fungerer ikke, og ping returnerer meldingen under, selv med sudo:
ping: sendmsg: Operation not permitted
Prøvde også å kjøre: sudo /etc/init.d/network restart
Men dette også uten hell.
Etter reboot, er alt tilbake som før, også iptables (altså som før) :no:
Fremdeles rådvill....
Endret av nutShell
Last ned nofirewall filen jeg har lagt til og prøv:
sudo -s
iptables --flush
iptables-restore -c < nofirewall
nofirewall:
Klikk for å se/fjerne innholdet nedenfor
# Generated by iptables-save v1.3.5 on Mon Mar 5 01:01:55 2007
*filter
:INPUT ACCEPT [98594:12008463]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [162838:213043607]
COMMIT
# Completed on Mon Mar 5 01:01:55 2007
NutCracker!
Det ser ut til å gjøre susen! :thumbup:
Takker og bukker!!
I min desperasjon og søken etter årsak/konfig. muligheter, fant jeg ut at jeg hadde installert en applikasjon som heter: Firestarter
Vet ikke om det er den som har lagt inn alle restriksjonene i iptables, eller om det er default Ubuntu, men her var det ganske enkelt å legge inn f.eks. Samba og åpne for kommunikasjon til spesifikk ip, host eller nettverk.
Men igjen, takker og bukker!
Skriptet kan jo også være til nytte på f.eks. servere uten GUI.
/nut
