Unicode til Quoted-Printable
Tja. Dersom det ikke finnes noe i .Net så skal det vel være mulig å konvertere ved hjelp av cdosys.dll (kan brukes til å generere .mhtml filer som da inneholder en seksjon med quoted-printable).
Ta en titt her: http://www.codeproject.com/aspnet/aspnethtml2mht.asp
 'Make the html part of the document
 iBp = mainBody.AddBodyPart()
 iBp.ContentMediaType = "text/html"
 iBp.ContentTransferEncoding = "quoted-printable"
 stm = iBp.GetDecodedContentStream
 stm.WriteText(html)
 stm.Flush()
Vet ikke om cdosys.dll er standard på smartphones/pocketPC. Men om det er så har du kanskje en løsning her.
Endret av wolf5
+ med litt google fant jeg: http://www.aspemporium.com/classes_src.aspx?cid=6
using System;
using System.IO;
using System.Text;
using System.Text.RegularExpressions;
using System.Security;
namespace mimelib
/// <summary>
/// <para>
/// Robust and fast implementation of Quoted Printable
/// Multipart Internet Mail Encoding (MIME) which encodes every
/// character, not just "special characters" for transmission over
/// SMTP.
/// </para>
/// <para>
/// More information on the quoted-printable encoding can be found
/// here: http://www.freesoft.org/CIE/RFC/1521/6.htm
/// </para>
/// </summary>
/// <remarks>
/// <para>
/// detailed in: RFC 1521
/// </para>
/// <para>
/// more info: http://www.freesoft.org/CIE/RFC/1521/6.htm
/// </para>
/// <para>
/// The QuotedPrintable class encodes and decodes strings and files
/// that either were encoded or need encoded in the Quoted-Printable
/// MIME encoding for Internet mail. The encoding methods of the class
/// use pointers wherever possible to guarantee the fastest possible
/// encoding times for any size file or string. The decoding methods
/// use only the .NET framework classes.
/// </para>
/// <para>
/// The Quoted-Printable implementation
/// is robust which means it encodes every character to ensure that the
/// information is decoded properly regardless of machine or underlying
/// operating system or protocol implementation. The decode can recognize
/// robust encodings as well as minimal encodings that only encode special
/// characters and any implementation in between. Internally, the
/// class uses a regular expression replace pattern to decode a quoted-
/// printable string or file.
/// </para>
/// </remarks>
/// <example>
/// This example shows how to quoted-printable encode an html file and then
/// decode it.
/// <code>
/// string encoded = QuotedPrintable.EncodeFile(
///  @"C:\WEBS\wwwroot\index.html"
/// string decoded = QuotedPrintable.Decode(encoded);
/// Console.WriteLine(decoded);
/// </code>
/// </example>
public class QuotedPrintable
 private QuotedPrintable()
 /// <summary>
 /// Gets the maximum number of characters per quoted-printable
 /// line as defined in the RFC minus 1 to allow for the =
 /// character (soft line break).
 /// </summary>
 /// <remarks>
 /// (Soft Line Breaks): The Quoted-Printable encoding REQUIRES
 /// that encoded lines be no more than 76 characters long. If
 /// longer lines are to be encoded with the Quoted-Printable
 /// encoding, 'soft' line breaks must be used. An equal sign
 /// as the last character on a encoded line indicates such a
 /// non-significant ('soft') line break in the encoded text.
 /// </remarks>
 public const int RFC_1521_MAX_CHARS_PER_LINE = 75;
 /// <summary>
 /// Encodes a very large string into the Quoted-Printable
 /// encoding for transmission via SMTP
 /// </summary>
 /// <param name="toencode">
 /// the very large string to encode
 /// </param>
 /// <returns>The Quoted-Printable encoded string</returns>
 /// <exception cref="ObjectDisposedException">
 /// A problem occurred while attempting to read the encoded
 /// string.
 /// </exception>
 /// <exception cref="OutOfMemoryException">
 /// There is insufficient memory to allocate a buffer for the
 /// returned string.
 /// </exception>
 /// <exception cref="ArgumentNullException">
 /// A string is passed in as a null reference.
 /// </exception>
 /// <exception cref="IOException">
 /// An I/O error occurs, such as the stream being closed.
 /// </exception>
 /// <exception cref="ArgumentOutOfRangeException">
 /// The charsperline argument is less than or equal to 0.
 /// </exception>
 /// <remarks>
 /// This method encodes a large string into the quoted-printable
 /// encoding and then properly formats it into lines of 76 characters
 /// using the <see cref="FormatEncodedString"/> method.
 /// </remarks>
 public static string Encode(string toencode)
 	return Encode(toencode, RFC_1521_MAX_CHARS_PER_LINE);
 /// <summary>
 /// </summary>
 /// </param>
 /// <param name="charsperline">
 /// the number of chars per line after encoding
 /// </param>
 /// string.
 /// </exception>
 /// </exception>
 /// </exception>
 /// </exception>
 /// </exception>
 /// <remarks>
 /// charsperline characters using the <see cref="FormatEncodedString"/>
 /// method.
 /// </remarks>
 public static string Encode(string toencode, int charsperline)
 	if (toencode == null)
   throw new ArgumentNullException();
 	if (charsperline <= 0)
   throw new ArgumentOutOfRangeException();
 	string line, encodedHtml = "";
 	StringReader sr = new StringReader(toencode);
 	try
   while((line=sr.ReadLine())!=null)
   	encodedHtml += EncodeSmallLine(line);
   return FormatEncodedString(encodedHtml, charsperline);
 	finally
   sr.Close();
   sr = null;
 /// <summary>
 /// Encodes a file's contents into a string using
 /// the Quoted-Printable encoding.
 /// </summary>
 /// <param name="filepath">
 /// The path to the file to encode.
 /// </param>
 /// A problem occurred while attempting to encode the
 /// string.
 /// </exception>
 /// </exception>
 /// </exception>
 /// </exception>
 /// <exception cref="FileNotFoundException">
 /// The file was not found.
 /// </exception>
 /// <exception cref="SecurityException">
 /// The caller does not have the required permission to open
 /// the file specified in filepath.
 /// </exception>
 /// <exception cref="UnauthorizedAccessException">
 /// filepath is read-only or a directory.
 /// </exception>
 /// <remarks>
 /// This method encodes a file's text into the quoted-printable
 /// </remarks>
 public static string EncodeFile(string filepath)
 	return EncodeFile(filepath, RFC_1521_MAX_CHARS_PER_LINE);
 /// <summary>
 /// </summary>
 /// </param>
 /// </param>
 /// string.
 /// </exception>
 /// </exception>
 /// </exception>
 /// </exception>
 /// </exception>
 /// </exception>
 /// </exception>
 /// <remarks>
 /// method.
 /// </remarks>
 public static string EncodeFile(string filepath, int charsperline)
 	if (filepath == null)
 	string encodedHtml = "", line;
 	FileInfo f = new FileInfo(filepath);
 	if (! f.Exists)
   throw new FileNotFoundException();
 	StreamReader sr = f.OpenText();
 	try
 	finally
   sr.Close();
   sr = null;
   f = null;
 /// <summary>
 /// Encodes a small string into the Quoted-Printable encoding
 /// for transmission via SMTP. The string is not split
 /// into lines of X characters like the string that the
 /// Encode method returns.
 /// </summary>
 /// <param name="s">
 /// The string to encode.
 /// </param>
 /// </exception>
 /// <remarks>
 /// This method encodes a small string into the quoted-printable
 /// encoding. The resultant encoded string has NOT been separated
 /// into lined results using the <see cref="FormatEncodedString"/>
 /// method.
 /// </remarks>
 public unsafe static string EncodeSmall(string s)
 	if (s == null)
 	string result = "";
 	fixed (char* pChar = s)
   char* pCurrent = pChar;
   do
   	int code = (*pCurrent);
   	result += String.Format("={0}", code.ToString("X2"));
   	pCurrent++;
   while (*pCurrent != 0);
 	return result;
 /// <summary>
 /// Encodes a small string with an appended newline into the
 /// Quoted-Printable encoding for transmission via SMTP. The
 /// string is not split into lines of X characters like the
 /// string that the Encode or the EncodeFile methods return.
 /// </summary>
 /// </param>
 /// </exception>
 /// <remarks>
 /// method.
 /// </remarks>
 public static string EncodeSmallLine(string s)
 	if (s == null)
 	return EncodeSmall(s + "\r\n");
 /// <summary>
 /// Formats a quoted-printable string into lines equal to maxcharlen,
 /// following all protocol rules such as byte stuffing. This method is
 /// called automatically by the Encode method and the EncodeFile method.
 /// </summary>
 /// <param name="qpstr">
 /// the quoted-printable encoded string.
 /// </param>
 /// <param name="maxcharlen">
 /// the number of chars per line after encoding.
 /// </param>
 /// <returns>
 /// The properly formatted Quoted-Printable encoded string in lines of
 /// 76 characters as defined by the RFC.</returns>
 /// </exception>
 /// </exception>
 /// <remarks>
 /// Formats a quoted-printable encoded string into lines of
 /// maxcharlen characters for transmission via SMTP.
 /// </remarks>
 public unsafe static string FormatEncodedString(string qpstr, int maxcharlen)
 	if (qpstr == null)
 	string strout = "";
 	StringWriter qpsw = new StringWriter();
 	try
   fixed(char* pChr = qpstr)
   	char* pCurrent = pChr;
   	int i = 0;
   	do
     strout += pCurrent->ToString();
     i++;
     if (i==maxcharlen)
     	qpsw.WriteLine("{0}=", strout);
     	qpsw.Flush();
     	i=0;
     	strout = "";
     pCurrent++;
   	while(*pCurrent != 0);
   qpsw.WriteLine(strout);
   qpsw.Flush();
   return qpsw.ToString();
 	finally
   qpsw.Close();
   qpsw = null;
 static string HexDecoderEvaluator(Match m)
 	string hex = m.Groups[2].Value;
 	int iHex = Convert.ToInt32(hex, 16);
 	char c = (char) iHex;
 	return c.ToString();
 static string HexDecoder(string line)
 	if (line == null)
 	//parse looking for =XX where XX is hexadecimal
 	Regex re = new Regex(
   "(\\=([0-9A-F][0-9A-F]))",
   RegexOptions.IgnoreCase
 	return re.Replace(line, new MatchEvaluator(HexDecoderEvaluator));
 /// <summary>
 /// decodes an entire file's contents into plain text that
 /// was encoded with quoted-printable.
 /// </summary>
 /// The path to the quoted-printable encoded file to decode.
 /// </param>
 /// <returns>The decoded string.</returns>
 /// A problem occurred while attempting to decode the
 /// encoded string.
 /// </exception>
 /// </exception>
 /// </exception>
 /// </exception>
 /// </exception>
 /// </exception>
 /// </exception>
 /// <remarks>
 /// Decodes a quoted-printable encoded file into a string
 /// of unencoded text of any size.
 /// </remarks>
 public static string DecodeFile(string filepath)
 	string decodedHtml = "", line;
 	if (! f.Exists)
 	try
   	decodedHtml += Decode(line);
   return decodedHtml;
 	finally
   sr.Close();
   sr = null;
   f = null;
 /// <summary>
 /// Decodes a Quoted-Printable string of any size into
 /// it's original text.
 /// </summary>
 /// <param name="encoded">
 /// The encoded string to decode.
 /// </param>
 /// </exception>
 /// <remarks>
 /// Decodes a quoted-printable encoded string into a string
 /// </remarks>
 public static string Decode(string encoded)
 	if (encoded == null)
 	string line;
 	StringWriter sw = new StringWriter();
 	StringReader sr = new StringReader(encoded);
 	try
   	if (line.EndsWith("="))
     sw.Write(HexDecoder(line.Substring(0, line.Length-1)));
   	else
     sw.WriteLine(HexDecoder(line));
   	sw.Flush();
   return sw.ToString();
 	finally
   sw.Close();
   sr.Close();
   sw = null;
   sr = null;
