DirectX9 stort problem
DNA
Vet ikke helt hvor jeg skal putte denne tråden, men prøver her.
Vel problemet ligger i at jeg må ha DirectX9 på datamaskinen for å spille Silkroad.
Så jeg laster ned DirectX9, men det er noe ganske rart jeg må gjøre for å få til at instalasjonen skal fungere, dette her;
Klikk for å se/fjerne innholdet nedenfor
DirectX Software Development Kit Redistributable Code
Redistributable Code is identified as all of the files in the following
directory on the DirectX 9.0 SDK CD/Download:
redist/DirectX9/
All files in the above directory must be included in any distribution of
the DirectX 9.0 Runtime with the following exceptions:
1) ManagedDX.cab may be excluded if support for DirectX for Managed
Applications is not required for your applications.
2) DirectX.cab and BDA.cab may be excluded if your application is not
supported on version of Windows 95, 98, 98 Second Edition or Millenium.
NOTE:
Installing Managed DirectX requirements
1) .NET Framework is installed before calling the DirectX setup.
2) Use "/installmanageddx" command line parameter if using DXSetup.exe
ROLAND SOUNDCANVAS SOUND SET FOR GENERAL MIDI AND GS FORMAT
The Roland SoundCanvas Sound Set includes the necessary sounds to make a
complete General MIDI compatible sound set. It also includes additional
sounds necessary to make a complete GS Format compatible sound set.
WHAT IS THE GS FORMAT?
The GS Format is a standardized set of specifications for sound sources
that defines the manner in which multitimbral sound generating devices
will respond to MIDI messages. The GS Format also complies with General
MIDI System Level 1.
The GS Format also defines a number of other details over and above the
features of General MIDI. These include unique specifications for sound
and functions available for tone editing, effects, and other specifications
concerning the manner in which sound sources will respond to MIDI messages.
Any device that is equipped with GS Format sound sources can faithfully
reproduce both General MIDI sound recordings and GS Format MIDI sound
recordings.
HOW TO CONTACT ROLAND:
For more information, please contact:
Roland Corporation U.S.
7200 Dominion Circle
Los Angeles, CA 90040-3696
Phone: (323) 890-3700
Fax: (323) 890-3701
COPYRIGHT NOTICE AND LICENSE LIMITATIONS
Roland GS Sound Set/Microsoft (P) 1996 Roland Corporation U.S.
The Roland GS Sound Set/Microsoft, the "Sample Set", incorporates the
Roland SoundCanvas Sound Set. Roland Corporation U.S. owns the Sample Set
and all copyrights pertaining thereto and has licensed the Sample Set for
use solely on Microsoft operating system products and Microsoft Application
Products.
Roland reserves all rights to the Sample Set not expressly granted by Roland
Corporation U.S. or by Microsoft under the terms of Microsoft's End User
License Agreement.
The Sample Set may only be redistributed with your software application as a
part of a Microsoft operating system product installation and under the terms
of Microsoft's End User License Agreement. The Sample Set may not be
separated from the Microsoft operating system product; the Sample Set may
only be installed by the Microsoft installation procedure for the associated
Microsoft operating system product or for an associated software development
kit. All other uses of the Sample Set require a separate written license
from Roland Corporation U.S.
The Sample Set may not be used, copied or redistributed in hardware ROM or
similar technology of any device without prior express written permission
from an authorized representative of Roland Corporation U.S. The Sample
Set may not be redistributed with any Musical Instrument . A "Musical
Instrument" is any device that is capable of generating musical sounds
without being directly connected to a computer with a licensed Microsoft
operating system product. You may not modify the Sample Set under any
circumstances.
Ifølge den skal jeg skrive inn "/installmanageddx" i comand line eller hva det var, og jeg vet jo sefølgelig ikke hvor det er siden jeg er MEGANOOB med pc.
Så kan noen hjelpe meg litt her? Screenshot av hvordan det gjøres hadde vært fint!
Mvh DNA.
