anode, katode. + eller -?
I en ordinær galvanisk celle, er anoden negativ og katoden positiv. I en tilsvarende celle hvor det foregår en elektrolyse, går elektronstrømmen motsatt vei, og anoden og katoden vil få motsatt ladning.
Fra http://en.wikipedia.org/wiki/Electrolytic_cell:
The anode and cathode in both types of cell are marked with the polarities of the current flow. In actual practice, the anode and the cathode in a galvanic cell swap functions during the charge portion of the cycle. Thus the electrode marked as anode for discharge is really acting as the cathode while charging and the electrode marked as cathode is actually acting as the anode during charging. In an electrolytic cell, the anode is where the electrons come up from the solution and the oxidation reaction creates electrons from reaction with the negative anions. The cathode reduces the ionic solution, drawing positive cations to the cathode and using electrons to reduce the cation.
