Få vekk "boble-tips" i tray etter ny XP-install
Bytex
Bøh!
Har installert WinXP pånytt idag, og greier ikke å komme på hvor jeg slår av de pokkers prateboble-tipsene som spretter opp i tray (helt nede til høyre). Som f.eks. "You are now connected to internet". Eller "New programs installed". Må klikke dem vekk hver gang de kommer. Vet det kan slås av..men hvor? Har leita overalt..hvertfall nesten :razz:
Tips - Add Your Own
Start/Run/Regedit
HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionExplorerTips. Data Type: REG_SZ (String Value), Value Data: Tip Text. Create a new string valued named by incrementing the existing value names and set it to the required tip text.
Toolbar Repair
This corrects missing Address Bar, Toolbars and/or Menu bars in Windows Explorer and Internet Explorer. Download my Toolbar Repair Utility here.
Tool Tips - Disable
Disable Tool Tips - Start/Run/Regedit
HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerAdvanced. Modify or create, "ShowInfoTip" and set the Value to 0. To restore set the Value to 1. This edit excludes the Start Button.
Disable Balloon Tips - Start/Run/Regedit
HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorerAdvanced. Modify or create, "EnableBalloonTips" and set the Value to 0. To restore set the Value to 1.
How To: Turn off the Balloon Tooltips and Pop-ups
Windows Explorer/Tools/Folder Options/View/Advanced/Uncheck Popup Descriptions for Folder and Desktop Items.
Related Registry entry:
"FolderContentsInfoTip"=dword:00000000
To turn off Windows Explorer Pop-Ups:
HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionExplorertips
"Show"=dword:00000001
"ShowInfoTip"=dword:00000001
How To: Turn off Tooltips
StartButtonBalloonTip - values are from "2" to "1" or "0".
For Pro: Start/Run/gpedit.msc. Local Computer/User Configuration/Administrative Templates/Start Menu and Taskbar/Remove Balloon Tips on Start Menu Items/Right Click Properties...
