siDDis Skrevet 21. februar 2007 Del Skrevet 21. februar 2007 Mens eg satt og skreiv denne feilmeldinga så dukka det opp ein lausning. Sidan andre og garantert vil bryne seg med dette seianre så deler eg lausningsforslaget Feilmelding: olav@olav-laptop:~/railapps/empurium$ script/console developmentLoading development environment. /usr/local/lib/ruby/1.8/irb/completion.rb:10:in `require': no such file to load -- readline (LoadError) from /usr/local/lib/ruby/1.8/irb/completion.rb:10 from /usr/local/lib/ruby/1.8/irb/init.rb:252:in `require' from /usr/local/lib/ruby/1.8/irb/init.rb:252:in `load_modules' from /usr/local/lib/ruby/1.8/irb/init.rb:250:in `each' from /usr/local/lib/ruby/1.8/irb/init.rb:250:in `load_modules' from /usr/local/lib/ruby/1.8/irb/init.rb:21:in `setup' from /usr/local/lib/ruby/1.8/irb.rb:54:in `start' from /usr/local/bin/irb:13 Fiks... Kjelde: http://ruphus.com/blog/2007/01/27/installi...-on-ubuntu-lts/ ror-fan wrote: I had the same problem with script/console in kubuntu. I thought that your solution was a bit lengthy. So, after further search I found a couple of links that solved the problem in a simpler manner. Check them out: http://ubuntuforums.org/showthread.php?t=169891 http://blog.nanorails.com/articles/2006/03...line-on-kubuntu Steps that worked for me: 1.) Download ruby source. Download Here 2.) Extract the tar file. tar -xvf ruby-1.8.5-p12.tar.gz 3.) Change to that directory cd ruby-1.8.5-p12.tar.gz 4.) Type these commands. ./configure make sudo make install 5.) Install readline and ncurses. apt-get install libncurses5-dev libreadline5-dev 6.) go back to the folder ruby source folder. ruby-1.8.5-p12.tar.gz 7.) Type these commands cd ext cd readline ruby extconf.rb make sudo make install Thats it. The console bug no longer appears. Lenke til kommentar
eigan Skrevet 2. mars 2007 Del Skrevet 2. mars 2007 Hva var problemstillinga? Skulle du innstallere ruby/starte? Jeg tror jeg så noe liknede da jeg startet min.. Lenke til kommentar
