gjestebok script som trenger litt modifikasjon
<style type="text/css">
DIV{
 text-align : left;
 padding : 5px;
 width : 520pk;
 height : 25em;
 overflow: scroll;
</style>
<div>
<table border="1" width="100%">
   <tr>
           <td width="1389">
<?php
$include_path = dirname(__FILE__);
require_once $include_path."/admin/config.inc.php";
require_once $include_path."/lib/$DB_CLASS";
require_once $include_path."/lib/image.class.php";
require_once $include_path."/lib/template.class.php";
if (IS_MODULE) {
   if (!eregi("modules.php", $_SERVER['PHP_SELF'])) {
       die ("You can't access this file directly...");
   $ModName = basename(dirname( __FILE__ ));
   ob_start();
   include("header.php");
   $GB_PG["base_url"] .= "/modules/$ModName";
   $GB_SELF = basename($_SERVER['PHP_SELF']);
   $GB_PG["index"]    = "$GB_SELF?op=modload&name=$ModName&file=index";
   $GB_PG["admin"]    = "$GB_SELF?op=modload&name=$ModName&file=index&agbook=admin";
   $GB_PG["comment"]  = "$GB_SELF?op=modload&name=$ModName&file=index&agbook=comment";
   $GB_PG["addentry"] = "$GB_SELF?op=modload&name=$ModName&file=index&agbook=addentry";
   if (!isset($agbook)) {
       $agbook = '';
   switch ($agbook) {
       case "admin":
           require_once $include_path."/lib/session.class.php";
           $gb_auth = new gb_session($include_path);
           $AUTH = $gb_auth->checkSessionID();
           $VARS = $gb_auth->fetch_array($gb_auth->query("SELECT * FROM ".$gb_auth->table['cfg']));
           $gb_auth->free_result($gb_auth->result);
           $template = new gb_template($include_path);
           if (isset($_COOKIE['lang']) && !empty($_COOKIE['lang'])) {
               $template->set_lang($_COOKIE['lang']);
           } else {
               $template->set_lang($VARS['lang']);
           $LANG = $template->get_content();
           $gb_auth->close_db();
           $enter_html = "";
           if (!$AUTH) {
               $message = (isset($username) || isset($password)) ? $LANG["PassMess2"] : $LANG["PassMess1"];
               eval("\$enter_html = \"".$template->get_template($GB_TPL['header'])."\";");
               eval("\$enter_html .= \"".$template->get_template($GB_TPL['adm_enter'])."\";");
               eval("\$enter_html .= \"".$template->get_template($GB_TPL['footer'])."\";");
               echo $enter_html;
           } else {
               $GB_PG["admin"] = $GB_PG["base_url"]."/admin.php?username=$username&password=$password&enter=1";
               header("Location: $GB_PG[admin]");
               exit();
           break;
       case "comment":
           require_once $include_path."/lib/vars.class.php";
           require_once $include_path."/lib/comment.class.php";
           $gb_com = new gb_comment($include_path);
           $gb_com->id = (isset($_GET["gb_id"])) ? $_GET["gb_id"] : '';
           $gb_com->id = (isset($_POST["gb_id"])) ? $_POST["gb_id"] : $gb_com->id;
           $gb_com->id = intval($gb_com->id);
           $gb_com->comment = (isset($_POST["comment"])) ? $_POST["comment"] : '';
           $gb_com->user = (isset($_POST["gb_user"])) ? $_POST["gb_user"] : '';
           $gb_com->pass_comment = (isset($_POST["pass_comment"])) ? $_POST["pass_comment"] : '';
           $gb_action = (isset($_POST["gb_comment"])) ? $_POST["gb_comment"] : '';
           $gb_com->comment_action($gb_action);
           $gb_com->db->close_db();
           break;
       case "addentry":
           require_once $include_path."/lib/add.class.php";
           require_once $include_path."/lib/phrase.class.php";
           $gb_post = new addentry($include_path);
           if (isset($_POST["gb_action"])) {
               $gb_post->name = (isset($_POST["gb_name"])) ? $_POST["gb_name"] : '';
                               $gb_post->email = (isset($_POST["gb_email"])) ? $_POST["gb_email"] : '';
                               $gb_post->url = (isset($_POST["gb_url"])) ? $_POST["gb_url"] : '';
                               $gb_post->comment = (isset($_POST["gb_comment"])) ? $_POST["gb_comment"] : '';
                               $gb_post->location = (isset($_POST["gb_location"])) ? $_POST["gb_location"] : '';
                               $gb_post->icq = (isset($_POST["gb_icq"])) ? $_POST["gb_icq"] : 0;
                               $gb_post->aim = (isset($_POST["gb_aim"])) ? $_POST["gb_aim"] : '';
                               $gb_post->gender = (isset($_POST["gb_gender"])) ? $_POST["gb_gender"] : '';
                               $gb_post->userfile = (isset($_FILES["userfile"]["tmp_name"]) && $_FILES["userfile"]["tmp_name"] != "") ? $_FILES : '';
                               $gb_post->user_img = (isset($_POST["gb_user_img"])) ? $_POST["gb_user_img"] : '';
                               $gb_post->preview = (isset($_POST["gb_preview"])) ? 1 : 0;
                               $gb_post->private = (isset($_POST["gb_private"])) ? 1 : 0;
                               $gb_post->token = (isset($_POST["gb_token"])) ? $_POST["gb_token"] : '';
                               $gb_post->gb_captcha = (isset($_POST["gb_captcha"])) ? $_POST["gb_captcha"] : '';
                               echo $gb_post->process($_POST["gb_action"]);
           } else {
               echo $gb_post->process();
           $gb_post->db->close_db();
           break;
       default:
           require_once $include_path."/lib/gb.class.php";
           $gb = new guestbook($include_path);
           $entry = (isset($_GET["entry"])) ? $_GET["entry"] : 0;
           $entry = (isset($_POST["entry"])) ? $_POST["entry"] : $entry;
           echo $gb->show_entries(intval($entry));
           $gb->db->close_db();
   ob_end_flush();
   $base_path = dirname(dirname($include_path));
   chdir("$base_path");
   include("$base_path/footer.php");
} else {
       </td>
   </tr>
</div>
</table>
<p> </p>
det jeg ikke skjøner er hvorfor jeg får scroll på alle tabel som er i php del her.
og ikke kunn i den tabelen jeg har lagt php delen i.
mvh
lilfire
