Problem med Jedi Academy. Driver issue?
Hei,
Når jeg prøver å starte Jedi Academy klikker spillet og går til console hvor det står masse greier. Til slutt kommer det en error hvor det står:
"GLW_StartOpenGL() - could not load OpenGL subsystem"
Hva er problemet her? Har sjekket mange andre steder men finner ingen måter om hvordan man akkurat fikser det.
For hva det har å si, så er dette alt som står i console:
"JA: v1.0.0.0 win-x86 Jul 22 2003
Initialising zone memory .....
----- FS_Startup -----
Current search path:
C:\Programfiler\LucasArts\Star Wars Jedi Knight Jedi Academy\GameData\base\assets2.pk3 (62 files)
C:\Programfiler\LucasArts\Star Wars Jedi Knight Jedi Academy\GameData\base\assets1.pk3 (8320 files)
C:\Programfiler\LucasArts\Star Wars Jedi Knight Jedi Academy\GameData\base\assets0.pk3 (15346 files)
C:\Programfiler\LucasArts\Star Wars Jedi Knight Jedi Academy\GameData/base
23728 files in pk3 files
execing default.cfg
couldn't exec jaconfig.cfg
couldn't exec autoexec.cfg
...detecting CPU, found AMD w/ 3DNow!
------- Input Initialization -------
Skipping check for DirectInput
Joystick is not active.
----- Client Initialization -----
----- Initializing Renderer ----
----- Client Initialization Complete -----
--- Common Initialization Complete ---
Working directory: C:\Programfiler\LucasArts\Star Wars Jedi Knight Jedi Academy\GameData
Initializing OpenGL subsystem
...initializing QGL
succeeded
...setting mode 4: 800 600 FS
...using desktop display depth of 32
...calling CDS: ok
...registered window class
...created window@0,0 (800x600)
Initializing OpenGL driver
...getting DC: succeeded
...GLW_ChoosePFD( 32, 24, 8 )
...35 PFDs found
...GLW_ChoosePFD failed
...GLW_ChoosePFD( 32, 24, 0 )
...35 PFDs found
...failed to find an appropriate PIXELFORMAT
...restoring display settings
...WARNING: could not set the given mode (4)
...setting mode 3: 640 480 FS
...using colorsbits of 16
...calling CDS: ok
...created window@0,0 (640x480)
...GLW_ChoosePFD( 16, 16, 0 )
...35 PFDs found
...35 PFDs found
...WARNING: could not set the given mode (3)
...shutting down QGL
...unloading OpenGL DLL
----- CL_Shutdown -----
Har ikke peil på hva det har å si, men der er det.
Håper noen kan hjelpe.
Hei og velkommen til forumet! :)
Jeg har opplevd samme problemet, da bare med Medal Of Honor - Allied Assault. Tror det har noe med at Grafikkortet ikke støtter OpenGL. Hvilket grafikkort har du? Har du prøvd å oppdatere drivere?
EDIT: På Lucasarts sitt supportforum fant jeg noe :)Sjekk her!
Endret av Selvin
