Brenning av ISO: K3b i Ubuntu
Tenkte jeg skulle brenne Debian for å prøve fra en Live CD også for å ha i tilfelle jeg få lyst til å bruke det på en pc e.l. så jeg lastet ned ISO-fil. Jeg har lastet ned K3b før og det funker fint å starte og alt men likevel får jeg ikke brent ISO-fila :S
Feilmld
System
K3b Version: 0.12.17
KDE Version: 3.5.5
QT Version:  3.3.6
Kernel:      2.6.17-11-generic
Devices
TSSTcorp DVD+-RW TS-L632D DE03 (/dev/scd0, /dev/sg1) at /media/cdrom0 [CD-R; CD-RW; CD-ROM; DVD-ROM; DVD-R; DVD-RW; DVD-R DL; DVD+R; DVD+RW; DVD+R DL] [DVD-ROM; DVD-R Sequential; DVD-RW Restricted Overwrite; DVD-RW Sequential; DVD+RW; DVD+R; DVD+R Double Layer; CD-ROM; CD-R; CD-RW] [SAO; TAO; RAW; SAO/R96P; SAO/R96R; RAW/R16; RAW/R96P; RAW/R96R; Restricted Overwrite; Layer Jump]
Used versions
cdrecord: 2.1.1a03
cdrecord
/usr/bin/X11/cdrecord: Warning: Running on Linux-2.6.17-11-generic
/usr/bin/X11/cdrecord: There are unsettled issues with Linux-2.5 and newer.
/usr/bin/X11/cdrecord: If you have unexpected problems, please try Linux-2.4 or Solaris.
scsidev: '1,0,0'
scsibus: 1 target: 0 lun: 0
Error trying to open /dev/sg0 exclusively (Permission denied)... retrying in 1 second.
/usr/bin/X11/cdrecord: Permission denied. Cannot open '/dev/sg0'. Cannot open SCSI driver.
/usr/bin/X11/cdrecord: For possible targets try 'cdrecord -scanbus'. Make sure you are root.
/usr/bin/X11/cdrecord: For possible transport specifiers try 'cdrecord dev=help'.
/usr/bin/X11/cdrecord: For more information, install the cdrtools-doc
/usr/bin/X11/cdrecord: package and read /usr/share/doc/cdrecord/README.ATAPI.setup .
Cdrecord-Clone 2.01.01a03 (i686-pc-linux-gnu) Copyright (C) 1995-2005 Joerg Schilling
NOTE: this version of cdrecord is an inofficial (modified) release of cdrecord
     and thus may have bugs that are not present in the original version.
     Please send bug reports and support requests to <[email protected]>.
     The original author should not be bothered with problems of this version.
TOC Type: 1 = CD-ROM
cdrecord command:
/usr/bin/X11/cdrecord.mmap -v gracetime=2 dev=1,0,0 speed=20 -dao driveropts=burnfree -eject -data /home/esso/.azureus/torrents/debian-31r4-alpha-binary-1.iso
Noen som vet om et godt program/ en måte å få K3b til å funke. Liker K3b :D
Laptop: Dell Inspirion 9400
Distro: Ubuntu 6.10
Skrivebord: GNOME + Compiz
Noe usikker, men etter å ha lest litt rundt på nettet, ser jeg at det er flere med samme problem.
Har du prøvd å kjøre k3bsetup for å konfigure k3b? Du har tydeligvis ikke tilgang til devicet.
(Regner med at du har prøvd en annen cd?)
Ellers kan du prøve med gnomebaker istedet for k3b.
(Mulig jeg er helt på viddene her, er egentlig ganske fersk innen Linux).
http://www.google.no/search?q=Error+trying...lient=firefox-a
http://www.linuxquestions.org/questions/sh...ad.php?t=523727
 esso@esso-laptop:~$ sudo aptitude -yr reinstall k3b
Password:
E: dpkg was interrupted, you must manually run 'dpkg --configure -a' to correct the problem.
Leser pakkelister ... Ferdig
Skaper oversikt over avhengighetsforhold
Reading state information ... Ferdig
Les utvidet tilstandsinformasjon
Oppdater pakkenes status ... Ferdig
Building tag database ... Ferdig
esso@esso-laptop:~$
Får den beskjeden uansett hva jeg gjør som gjleder instalering o.l. :S Må ha en løsning på dette før jeg kommer meg videre tror jeg :S :p
EDIT: Jeg finner ikke fila heller :S Pleier da å åpne Azureus (lasta ned Debian via en torrent) og høyreklikke på den ferdige fila og velger Show file men nå når jeg starter Azureus bare lukker den seg igjen :( :S Er noe rart her for tiden.. Kan ikke skjønne hva som har skjedd :S
EDIT2: Prøvde å lage en ny bruker. Fungerte ikke :/
EDIT3: Tror jeg prøver reinstall av Ubuntu. Har home på egen partisjon så...
Endret av Webmaster Esso
Tok reinstall jeg.
Jeg prøver nå å klikke Burn data-CD. Det funker å brenne men vet enda ikke om cd'n vil funke da. Fortsatt feilmld ved Burn ISO-Image knappen (eller hva som står på'n :p)
EDIT: Samme problem kom på Burn data-CD :p Funka frem til 50 %
Den ser ut til å løse det problemet med MP3-filer. Kanskje det er en feil med at det ikke er støtte for ISO-filer? :p
Nei, tipper porblemet er noe med adgang som dere har vist til også. Finnes det ikke noe kontrollpanel for slike duppeditter som er innebygd i maskinen?
Drivere?
