Steffluss Skrevet 16. februar 2007 Rapporter Del Skrevet 16. februar 2007 Noen som vet hvor mye str og agi utgjør i % og armor for en shaman ? Takker for konstruktive svar. Steffluss 68 - Tauren shaman Lenke til kommentar
Rockna Skrevet 16. februar 2007 Rapporter Del Skrevet 16. februar 2007 Agi gir dodge og Crit. ca 29 agi 1% crit og 1,5 dodge chance Husker ikke for Str Lenke til kommentar
Amon Amarth Skrevet 16. februar 2007 Rapporter Del Skrevet 16. februar 2007 (endret) Alt sånn info står nok på wowwiki.com Klikk for å se/fjerne innholdet nedenfor Attributes See the main article Attributes. This breaks down specifically for shamans as follows [1]: Your level's worth of agility will increase your chance to crit on a melee hit by about 3% (e.g., +60 agility will give a level 60 shaman +3% crit). Your level's worth of agility will increase your chance to dodge by about 1% (e.g., +60 agility will give a level 60 shaman +1% to dodge). Every point of strength provides 2 melee attack power (e.g., +70 strength will give any shaman +140 AP). This means that every 7 strength provides 1 additional damage per second (e.g., +70 strength will give any shaman +10 DPS). Every point of strength increases the amount of damage you block with a shield. Every point of intellect adds 15 mana (MP). Your level's worth of intellect will increase your chance to crit with spells by 1% (e.g., +60 intellect will give a level 60 shaman +1% to crit with spells.) Every point of stamina adds 10 health (HP). Every 10 points of spirit regenerates 1 mana per second. This can also be described as "five spirit yields 1 mana per tick" or "2 spirit restores 1 mana per five seconds" (MP5). See also Formulas:Mana Regen or Formula:Mana regen & Shields Every 18 spirit increases health regeneration by 1 health per second (i.e., 9 spirit restores 1 point of health per tick). *Quotet fra wowwiki.com* Klikk for å se Endret 16. februar 2007 av Amon Amarth Lenke til kommentar
janan71 Skrevet 16. februar 2007 Rapporter Del Skrevet 16. februar 2007 (endret) Ang denne: Your level's worth of agility will increase your chance to dodge by about 1% (e.g., +60 agility will give a level 60 shaman +1% to dodge). Var ganske så skikker på at dette skulle vært 3%. Er denne blitt forandret i det siste, eller er det alle literene med etanol som begynner å tære på hukommelsen? Endret 16. februar 2007 av janan71 Lenke til kommentar
Roberticus Skrevet 16. februar 2007 Rapporter Del Skrevet 16. februar 2007 Strenght gir 2 AP pr poeng for shaman. Lenke til kommentar
PSV Skrevet 16. februar 2007 Rapporter Del Skrevet 16. februar 2007 Ang denne:Your level's worth of agility will increase your chance to dodge by about 1% (e.g., +60 agility will give a level 60 shaman +1% to dodge). Var ganske så skikker på at dette skulle vært 3%. Er denne blitt forandret i det siste, eller er det alle literene med etanol som begynner å tære på hukommelsen? 7956191[/snapback] Riktig. Wowwiki må være feilinformert. Lenke til kommentar
