meastp Skrevet 4. desember 2002 Del Skrevet 4. desember 2002 Hei! (skal installere nyeste version) Når jeg prøver å fjerne apache (dvs Web Server) i Package management får jeg følgende feilmelding: Could not remove packages "You hav selacted a system package that is depended upon by a necessary system package. This package must be unselected before package removal can continue" System packages redhat-config-packages 712 kilobytes Hva gjør jeg? Hvilken pakke skal jeg fjerne? <font class=editedby>[ Denne Melding var redigert av: meastp på 2002-12-04 18:38 ]</font> [ Denne Melding var redigert av: meastp på 2002-12-05 18:12 ] Lenke til kommentar
meastp Skrevet 4. desember 2002 Forfatter Del Skrevet 4. desember 2002 dette har jeg prøvd: [root@localhost root]# rpm -qa | grep httpd httpd-2.0.40-8 httpd-manual-2.0.40-8 redhat-config-httpd-1.0.1-13 [root@localhost root]# rpm -e httpd-manual [root@localhost root]# rpm -e httpd error: Failed dependencies: httpd-mmn = 20020628 is needed by (installed) mod_perl-1.99_05-3 httpd-mmn = 20020628 is needed by (installed) mod_python-3.0.0-10 httpd-mmn = 20020628 is needed by (installed) mod_ssl-2.0.40-8 httpd-mmn = 20020628 is needed by (installed) php-4.2.2-8.0.5 libapr.so.0 is needed by (installed) mod_perl-1.99_05-3 libaprutil.so.0 is needed by (installed) mod_perl-1.99_05-3 httpd >= 2.0.40 is needed by (installed) mod_perl-1.99_05-3 httpd >= 2.0.40 is needed by (installed) mod_python-3.0.0-10 httpd is needed by (installed) mod_ssl-2.0.40-8 httpd is needed by (installed) redhat-config-httpd-1.0.1-13 [root@localhost root]# rpm -e redhat-config-httpd [root@localhost root]# ; Hva skal jeg gjøre? avinstallere alle filene som trenger 20020628, libapr.so.0, libaprutil.so.0, httpd >= 2.0.40 og httpd???? Lenke til kommentar
meastp Skrevet 4. desember 2002 Forfatter Del Skrevet 4. desember 2002 Er det ingen som vet? Lenke til kommentar
meastp Skrevet 4. desember 2002 Forfatter Del Skrevet 4. desember 2002 Får ikke starta apache ..... ./configure --prefix=/webserver/apache/ --with-so Likevel finnes det ingen wwwroot eller apachect1 ifølge locate kommandoen.... Hjelp! Fulgte http://www.geocities.com/honey_jal/ (er ikke kommet så langt :smile:) Lenke til kommentar
daffy- Skrevet 4. desember 2002 Del Skrevet 4. desember 2002 Hvorfor ikke heller bare laste ned fra apache.org og følge readme fila som følger med? Og for guds skyld, hvis du skal bruke PHP, IKKE bruk Apache 2.x.. Bare et lite tips.. Lenke til kommentar
Typhon Skrevet 4. desember 2002 Del Skrevet 4. desember 2002 ser du skriver apachect1, det heter apachectl... CTL assa.... Lenke til kommentar
ærlige_roffen Skrevet 4. desember 2002 Del Skrevet 4. desember 2002 Menneh, er det ikke slik at du må oppdatere databasen til locate før den kan finne filene, da? Prøv 'man locate' elns Lenke til kommentar
Ancistrus84 Skrevet 5. desember 2002 Del Skrevet 5. desember 2002 Quote: Den 2002-12-04 18:34, skrev meastp:Får ikke starta apache ....../configure--prefix=/webserver/apache/--with-soLikevel finnes det ingen wwwroot eller apachect1 ifølge locate kommandoen....Hjelp!Fulgte http://www.geocities.com/honey_jal/ (er ikke kommet så langt :smile:) Som sagt det heter "apachectl", hvis du vill sette opp apache meget enkelt last ned Apache Toolbox, meget enkelt. Last ned fra Sourceforge! Lenke til kommentar
meastp Skrevet 5. desember 2002 Forfatter Del Skrevet 5. desember 2002 Ok, har "funnet" det nå... glemte make og make install.... :smile: Ok, har også installert php with MySQL.... Hvordan slår jeg på dette? Virker dette? Skal jeg bare legge phpBB inn i "main directory"? Kan jeg bruke Red Hat's grafiske konfig. tool til dette? mvh, Mats Taraldsvik Lenke til kommentar
n1tro Skrevet 6. desember 2002 Del Skrevet 6. desember 2002 Quote: Den 2002-12-04 21:06, skrev daffy-:Hvorfor ikke heller bare laste ned fra apache.org og følge readme fila som følger med? Og for guds skyld, hvis du skal bruke PHP, IKKE bruk Apache 2.x.. Bare et lite tips.. Hvorfor det? Hva er galt med 2.x i forhold til php? Jeg spør bare nå fordi jeg ikke har peiling. Jeg kjører en web-server selv med 2.x og php, og det lille jeg har brukt den til nå har fungert helt greit.. Lenke til kommentar
daffy- Skrevet 6. desember 2002 Del Skrevet 6. desember 2002 Er bare det at det er en veldig buggy, og fremfor alt usikker kombo.. Edit: Trøtt allerede, ergo noen skriveleifer :razz: [ Denne Melding var redigert av: daffy- på 2002-12-07 00:26 ] Lenke til kommentar
