Gnome-panelet kræsjer ved loading
Har ett problem, når gnome panelet mitt loades får jeg en kræsj rapport:
Klikk for å se/fjerne innholdet nedenfor
Memory status: size: 40456192 vsize: 0 resident: 40456192 share: 0 rss: 20668416 rss_rlim: 0
CPU usage: start_time: 1171264144 rtime: 0 utime: 110 stime: 0 cutime:102 cstime: 0 timeout: 8 it_real_value: 0 frequency: 0
Backtrace was generated from '/usr/bin/gnome-panel'
(no debugging symbols found)
Using host libthread_db library "/lib/tls/i686/cmov/libthread_db.so.1".
[Thread debugging using libthread_db enabled]
[New Thread -1225865552 (LWP 5852)]
0xffffe410 in __kernel_vsyscall ()
#0 0xffffe410 in __kernel_vsyscall ()
#1 0xb75a3323 in __waitpid_nocancel ()
from /lib/tls/i686/cmov/libpthread.so.0
#2 0xb7e9b1b6 in gnome_gtk_module_info_get () from /usr/lib/libgnomeui-2.so.0
#3 <signal handler called>
#4 0xffffe410 in __kernel_vsyscall ()
#5 0xb748b770 in raise () from /lib/tls/i686/cmov/libc.so.6
#6 0xb748cef3 in abort () from /lib/tls/i686/cmov/libc.so.6
#7 0xb76a7122 in g_logv () from /usr/lib/libglib-2.0.so.0
#8 0xb76a7159 in g_log () from /usr/lib/libglib-2.0.so.0
#9 0xb76a71d6 in g_assert_warning () from /usr/lib/libglib-2.0.so.0
#10 0xb7af6d5d in gtk_recent_info_get_short_name ()
from /usr/lib/libgtk-x11-2.0.so.0
#11 0xb7af6dba in gtk_recent_info_get_display_name ()
#12 0xb7af2591 in gtk_recent_chooser_menu_new ()
#13 0xb769caa1 in g_source_is_destroyed () from /usr/lib/libglib-2.0.so.0
#14 0xb769e802 in g_main_context_dispatch () from /usr/lib/libglib-2.0.so.0
#15 0xb76a17df in g_main_context_check () from /usr/lib/libglib-2.0.so.0
#16 0xb76a1b89 in g_main_loop_run () from /usr/lib/libglib-2.0.so.0
#17 0xb7aa0574 in gtk_main () from /usr/lib/libgtk-x11-2.0.so.0
#18 0x08061d8c in main ()
Thread 1 (Thread -1225865552 (LWP 5852)):
No symbol table info available.
Ved å lukke kræsj rapporten reloader gnome panelet og samme meldingen kommer opp.
Noen som kan gi meg svar på hvordan dette skal fikses?
Ubuntu 6.10
-M
