verdi på Nikon D100?
utifra hva jeg har lest så er selve huset mer solid, men D70 har nyere og visstnok mer avansert elektronikk enn D100
"My local camera store guy told me that the D70 has replaced the D100 thus rendering the latter 'obsolete' yet I see many D100's for sale new at ~$300 more than the D70...
I've searched all over the place, mainly to find something definitive regarding the 6.1 mp sensor - is this the same in both cameras? The 'moire' issue mentioned often in D70 reviews doesn't seem to appear regarding the D100......yet the two seem to share so many specs.....
I am confused.
How are these cameras the same, and how do they differ?
Is there a compare/contrast resource for dslr buyers?
All advice appreciated
Two different cameras sharing a similar sensor. The D100 is the first in the "low cost" dSLR genre. It is built to withstand the rigors of pro photography. The D70 is the faster upgraded replacement. Not quit as rugged, but with newer features and speed.
For those of us who have had the D70 since its introduction a year ago moire' is not even an afterthought. It happens once in a thousand shots and can be removed in post processing. The tradeoff is softer pictures.
If you want a camera you can beat the hell out of and still take pictures the D100 is your camera. If you want a camera that is fast and sharp the D70 is the pick, just don't beat the hell out of it (the same is true for most consumer dSLR's).
The D70 is a great consumer dSLR, and I would buy another one in a nanosecond."
Hentet fra: http://www.dcresource.com/forums/archive/i...php/t-6147.html
D100 er nesten 2 år eldre enn D70, og er samtidig med f.eks Fuji S1 og Canon D60. Den vikitgste forskjellen mellom D70 og D100, rent bortsett fra at D100 er et "proffere" hus, er at D100 bare har d-TTL blitzstyring, mens D70 har den nyere i-TTL.
Jeg har ingen praktisk erfaring med d-TTL, men det sies rundt omkring at det var temmelig dårlige saker sammenlignet med i-TTL.
  • 2 uker senere...
