km400 S3 driver
kontra
jeg har et problem med å legge inn driveren for et integrert skjermkort fra S3. http://www.hardware.no/nyheter/april03/km400.html her en en link til hovedkortet. får starte opp installeringen, men før den begynner å legge inn driverene får jeg opp
"Installasjonsprogrammet kunne ikke gjennomføre installasjonen. Du finner nærmere opplysninger i fremdriftsloggen i Windows-katalogen." i loggen får jeg opp dette.
=========== S3SETUP LOG FILE - Started at 20:06:29 on 2-10-2007 ===========
S3Setup v(1.01.22) 1.00.01-DC/1.00.03-WD/1.00.04-AC/1.00.20-JV/1.00.13-CL/1.00.46-M7/1.00.10-SS/1.00.29-G4/1.00.25-M5/1.00.45-MS on Win XP
bAllowReboot: TRUE
bSilentReboot: TRUE
bPromptReboot: TRUE
bPromptSilentReboot: FALSE
bRemoveWindowsINF: FALSE
bDisableMenuAnim: TRUE
bDisableMenuShadow: TRUE
VendorID to find:1106
INF File Located at: C:\driver\KM400_XP2K_169432-11_wIShld_Logod\KM400_XP2K_169432-11_wIShld_Logod\kmviag.inf
Found - ven:1106 dev:7205 ss_dev:80ED ss_ven:1043 rev:01 bus:01 devnum:00 func:00 (inVGA=1)
Enumerating Display class devices...
Display #0 has DevInst=00001878
Instance=PCI\VEN_1106&DEV_7205&SUBSYS_80ED1043&REV_01\4&1FEB96E4&0&0008.
Found matching display.
No more displays.
Found InstID=PCI\VEN_1106&DEV_7205&SUBSYS_80ED1043&REV_01\4&1FEB96E4&0&0008.
Found Mfg line: "VIA.Mfg".
Description="%viagfx.DeviceDesc0% = viagfx, PCI\VEN_1106&DEV_7205".
'DriverVer' is 6.14.10.0092, 'DriverDate' is 11/17/2003.
Calling UpdateDriver... with PCI\VEN_1106&DEV_7205&SUBSYS_80ED1043&REV_01
and INF path at C:\driver\KM400_XP2K_169432-11_wIShld_Logod\KM400_XP2K_169432-11_wIShld_Logod\kmviag.inf
Started Timer window in background.
Doing copy logging.
Finished with copy logging.
UpdateDriver forced install (PCI\VEN_1106&DEV_7205&SUBSYS_80ED1043&REV_01) failed->-536870389.
UpdateDriver failed, returned -536870389. Cannot install.
DestroyTimerWindow OK, but no timer dialog action occurred.
-> Installasjonsprogrammet kunne ikke gjennomføre installasjonen. Du finner nærmere opplysninger i fremdriftsloggen i Windows-katalogen.
Er det noen som har hatt samme problemmet?
  • 1 måned senere...
Ja det er window xp som er oprativ systemet. har prøvd med den nyeste som var i linken. fikk opp den samme feil meldingen.
************ S3ISET32 LOG - Started Tue Mar 13 17:04:16 2007 ************
S3Iset32 v2.00.07-0709 (IShield 7.4.0.377), 2.00.10-0917 Bootleg on Win XP SP1
Internal signature: 6-5432
Caller cmdline: ''
SupportDir: 'C:\DOCUME~1\SIGVE~1.SIG\LOKALE~1\Temp\{2B43252C-A1E3-4C47-927C-9F2C276D3515}\'
Mode: Unattended, Normal
AllowReboot: TRUE
SilentReboot: TRUE
PromptReboot: TRUE
PreInstallFiles: FALSE
DisableMenuAnim: FALSE
DisableMenuShadow: FALSE
Find VendorID: 1106
Driver INF at: C:\driver\KM400_16942416_XP_wIShld_logod\KM400_16942416_XP_wIShld_logod\uc02i.inf
Find hardware code->0
Custom uninstall info: C:\WINDOWS\UChromeP.uns
Uninst DLL: C:\PROGRA~1\VIA\UChromeP\s3iset32.dll
Uninst Log: C:\PROGRA~1\VIA\UChromeP\UChromeP.uns
Reg uninst key: C:\PROGRA~1\VIA\UChromeP\s3minset.exe /u C:\PROGRA~1\VIA\UChromeP\UChromeP.uns
Add. dir to remove: C:\Programfiler\InstallShield Installation Information\{2B43252C-A1E3-4C47-927C-9F2C276D3515}
Installing VIA/S3G UniChrome Family Win2K/XP Display...
Hardware found - ven:1106 dev:7205 ssven:1043 ssdev:80ED rev:01 bus:01 devnum:00 func:00 (InVga=1)
**** Begin Win2K/XP Driver Install ****
Enum devs for GUID {4d36e968-e325-11ce-bfc1-08002be10318} to match ''...
#0, Inst=00001878 ID=PCI\VEN_1106&DEV_7205&SUBSYS_80ED1043&REV_01\4&1FEB96E4&0&0008
Found match!
Found Mfg line: 'VIA.Mfg'.
Ln 0: 'viagfx_3205,PCI\VEN_1106&DEV_7205' - Match!
Keyname #0='"VIA/S3G UniChrome IGP"' - Match!
Inf Driver date '03/09/2005', version '6.14.10.0212'
Do driver file copy logging.
DoDriverFiles: [viagfx_3205] key='CopyFiles' fl=0
Finished copy logging.
UpdateDriverForPlugAndPlayDevice(PCI\VEN_1106&DEV_7205&SUBSYS_80ED1043&REV_01)
and INF at 'C:\driver\KM400_16942416_XP_wIShld_logod\KM400_16942416_XP_wIShld_logod\uc02i.inf'
...force install (PCI\VEN_1106&DEV_7205&SUBSYS_80ED1043&REV_01), error e000020bh.
UpdateDriver failed, error e000020bh (No such device).
DestroyTimer OK, but no timer dialog action occurred.
slInstall returned error. Cannot continue.
Endret av Thumby
