Lei Nye WarRock? Spill koreanske WARROCK!
Flere features, ingen betaling og spillet er i engelsk mye mer gore!! (blod)
Hvordan registrere:
All Credits to: Hihadrs
Grammar fixing, interface fixing and whole lot by: Specnaz91
Download Korean language pack (Google it)
(You need to download the korean language pack to avoid the random numbers your computer will give you, so to see the site properly get the korean language pack and use INTERNET EXPLORER because of ActiveX!
Go to: WarRock homepage
PS: Just be patience, since the servers is in South-Korea the loading take time.
Follow these simple steps:
1. Do this
2. Now scroll down a little
3. Now select the following boxes and press the following button:
Now follow the instructions to make your account.
once you completed the instructions, do the following:
(Dont Submit yet)
At the end you should have something like this:
If upon submitting for some reason a pop-up comes up with the characters of 4-20 then your username is not valid, you have to validate it by clicking on the button next to it. AVOID weird characters and please dont use space.
This is a copy of an old tutorial: To have korean activation, so it`s not 1-9 characters to make an account.
How-to type korean:
There is a program that you can draw and it will give you the letters for you to copy ( I m a bad in drawing so i hate this ) and there is this way bellow to type korean.
First go to START > CONTROL PANEL > REGIONAL AND LANGUAGE OPTIONS. Inside Language options go to LANGUAGE tab, and mark to install east asian language.
Second go to details at the same tab, press add, at the input language find korean, at keyboard layout chouse korean imput system [iME 2002]. Press apply and down to right at the bar a language icon will appear, left to the tray icons, click on it to change to KOREAN. test5ll.jpg
If its working you should type ¤²¤¸¤§¤¡¼î¤Å¤Á¤À¤Ä¤±¤¤¤·¤©È£¤Ã¤¿¤Ó¤»¤¼¤ºÇ»¤Ì¤Ñ Crazy words. Now you have to figure out the combination of the words like [ "E" =¤§, "L" = ¤Ó, "S" = ¤¤] and the total combination added together will be "µò" (This is an example) learn the combinations and you will be able to type the korean activation korean words
If you don`t understand the tutorial or need some help, please PM me or reply in this topic :)
Men så ble det mange bugs, venter noen uker (1 - 2 uker) når serverne har stablilsert seg på vanlige warrock.
De er noen drittsekker, lover mye, men holder ingenting. Go for Korean WR! Mye bedre. Artillery osv.
Nye updates hver uke, bedre enn K2 kapitalister :(
W00t, koreanske warrock gar fått en badge system :). Massse nytt, sjekk innom Items og gamemode :)
Feet!
Vehicles:
http://warrock.nexon.com/warrock/page/gnx....L=item/unititem
Våpen:
http://warrock.nexon.com/warrock/page/gnx....item/weaponitem
Maps:
http://warrock.nexon.com/warrock/page/Gnx....l=info/mapinfo2
Endret av specnaz91
  • 1 år senere...
