grub problemer... igjen :(
Dette er andre gang at jeg får problem med grub i forbindelse med dual-boot av Windows XP og Opensuse 10.2... Når jeg velger Windows XP fra grub menyen så ser jeg dette:
Booting 'Windows XP'
rootnorify(hd1, 0)
chainloader +1
her har dere fdisk -l:
Disk /dev/sda: 37.0 GB, 37019566080 bytes
255 heads, 63 sectors/track, 4500 cylinders
Units = cylinders of 16065 * 512 = 8225280 bytes
  Device Boot      Start         End      Blocks   Id  System
/dev/sda1   *           1           9       72261   83  Linux
/dev/sda2              10        4500    36073957+  8e  Linux LVM
Disk /dev/sdb: 163.9 GB, 163928604672 bytes
255 heads, 63 sectors/track, 19929 cylinders
/dev/sdb1   *           1        6616    53142988+   7  HPFS/NTFS
Disk /dev/sdc: 250.0 GB, 250059350016 bytes
255 heads, 63 sectors/track, 30401 cylinders
/dev/sdc1   *           1       30401   244196001   83  Linux
Disk /dev/dm-0: 34.6 GB, 34682699776 bytes
255 heads, 63 sectors/track, 4216 cylinders
Disk /dev/dm-0 doesn't contain a valid partition table
Disk /dev/dm-1: 2147 MB, 2147483648 bytes
255 heads, 63 sectors/track, 261 cylinders
Disk /dev/dm-1 doesn't contain a valid partition table
og her er /boot/grub/menu.lst
# Modified by YaST2. Last modification on ons feb  7 12:50:03 CET 2007
default 0
timeout 1
##YaST - generic_mbr
gfxmenu (hd0,0)/message
##YaST - activate
###Don't change this comment - YaST2 identifier: Original name: linux###
title openSUSE 10.2
   root (hd0,0)
   kernel /vmlinuz-2.6.18.2-34-default root=/dev/system/root vga=0x31a resume=/dev/system/swap splash=silent showopts
   initrd /initrd-2.6.18.2-34-default
title Windows XP
   rootnoverify (hd1,0)
   chainloader +1
Aner ikke hva som er galt her og hvis noen kan hjelpe så setter jeg pris på det :thumbup:
