abit quad GT "tråden"
Exentler
ABIT AB9 QuadGT
Tester:
- http://www.anandtech.com/mb/showdoc.aspx?i=2911
Ut i fra den testen virker det supert. et AW9D og ab9 mix. klokker som bare det og har god layout så jeg har foreløpig ikke noe å utsette på det.
Produsent / Produkt siden:
- ABIT sin produkt side
- ABIT sin hjemmeside
- Abit sin side for drivere
Spesifikasjoner :
Klikk for å se/fjerne innholdet nedenfor
CPU Support:
- Intel® Core™ 2 Quad/Duo(Extreme Edition)
- Pentium® Dual Core
- Pentium® Extreme Edition
- Pentium® D
- Pentium®4
Chipset:
- Intel® P965 / ICH8R Chipset
Memory:
- 4 X 240-pin DIMM sockets support max. memory capacity 8GB
- Supports Dual channel DDR2 800/667/533 Un-buffered Non-ECC memory
LAN:
- LAN On board PCI Gigabit LAN controller supports 10/100/1000M Ethernet
Audio:
- On board 7.1 CH HD Audio CODEC
- Supports auto jack sensing and optical S/PDIF In/Out
- HDMI ready header (SPDIF header)
Expansion Slots:
- Processor LGA775
- 4 Memory DIMM 240-pin
- 1 x PCI-E X16
- 1 x PCI-E X16 (x4 bandwidth)
- 1 x PCI-E X1
- 2 x PCI
Internal I/O:
- 1 x Floppy Port supports up to 2.88 MB
- 1 x ATA 133/100/66/3 IDE connector
- 6 x SATA 3Gb/s connector
- 1 x IEEE1394, 3 x USB header (support 6 ports)
- 1 x FP-Audio
Back Panel I/O:
- 1 x PS/2 Keyboard
- 1 x PS/2 Mouse
- abit Silent OTES™
- 1 x S/P DIF In
- 1 x S/P DIF Out
- 2 x eSATA
- 7.1 CH Audio connector (Front, Line-in, MIC-in, Center/Subwoofer, Surround, Rear Surround)
- 4 x USB 2.0
- 1 x RJ-45 LAN connector
- 1 x 1394
- Clear CMOS Switch
Serial ATA:
- Serial ATA6 x SATA 3Gb/s offer by Intel® ICH8R support Intel® Matrix Storage Tech(AHCI & RAID0/1/5/10)
- 2 x eSATA 3Gb/s through JMicron® JMB363 support 0,1JBOD RAID function
- RAID: Intel Matrix RAID Technology: RAID 0 / RAID 1 / RAID 10 / RAID 5, RAID 0 / RAID 1 / JBOD
IEEE 1394:
- Supports 2 Ports IEEE 1394 at 400Mb/s transfer rate.
Form Factor:
- ATX form factor 305 x 245mm
- PCB Color: Blue
Technology:
- µGuru
- ABIT SilentOTES
- Diagnostic LEDs
- ATI CrossFire technology support
Bilder: Beklager strørelsen, fant ikke noe wide kode
Mange er tatt her fra
Prisguide:
- https://prisguiden.no/product.php?product_id=60558
Noen som har kortet kan komme med mer ?
jeg har ikke kjøpt det ennå
Endret av Exentler
Det kortet er interessant, jeg skal kjøpe det selv. Men har kjøpt så mye annen hw nå så det for vente.
Det skal ha allt som Abit AB9 Pro ikke har av overklokkings-godis,forventer meg mye av det.
Tenkte jeg skulle ta en test av det og publisere her,men det får bli litt lengre frampå.
Er det noen som har kjøpt det? Post isåfall noen resultater her :)
