Skinney Skrevet 31. januar 2007 Del Skrevet 31. januar 2007 heisann, Installerte opensuse igår og selv om en Vista entry ble lagd i grub så får jeg ikke boota vista... får bare se "innstillingene". Altså, dette kommer opp når jeg prøver å boote Vista... title Windows Vista rootnoverify (hd0,0) chainloader (hd1,0)+1 Og jeg aner ikke hva som er galt... fdisk -l sier: Disk /dev/sda: 37.0 GB, 37019566080 bytes255 heads, 63 sectors/track, 4500 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/sda1 * 1 9 72261 83 Linux /dev/sda2 10 4500 36073957+ 8e Linux LVM Disk /dev/sdb: 163.9 GB, 163928604672 bytes 255 heads, 63 sectors/track, 19929 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/sdb1 1 6527 52428096 7 HPFS/NTFS Disk /dev/sdc: 250.0 GB, 250059350016 bytes 255 heads, 63 sectors/track, 30401 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Device Boot Start End Blocks Id System /dev/sdc1 * 1 30401 244196001 83 Linux Disk /dev/dm-0: 34.6 GB, 34682699776 bytes 255 heads, 63 sectors/track, 4216 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk /dev/dm-0 doesn't contain a valid partition table Disk /dev/dm-1: 2147 MB, 2147483648 bytes 255 heads, 63 sectors/track, 261 cylinders Units = cylinders of 16065 * 512 = 8225280 bytes Disk /dev/dm-1 doesn't contain a valid partition table og her er /boot/grub/menu.lst: # Modified by YaST2. Last modification on ons jan 31 18:05:38 CET 2007default 0 timeout 1 ##YaST - generic_mbr gfxmenu (hd0,0)/message ##YaST - activate ###Don't change this comment - YaST2 identifier: Original name: linux### title openSUSE 10.2 root (hd0,0) kernel /vmlinuz-2.6.18.2-34-default root=/dev/system/root vga=0x31a resume=/dev/system/swap splash=silent showopts initrd /initrd-2.6.18.2-34-default ###Don't change this comment - YaST2 identifier: Original name: windows### title Windows Vista rootnoverify (hd0,0) chainloader (hd1,0)+1 Lenke til kommentar
Langbein Skrevet 31. januar 2007 Del Skrevet 31. januar 2007 (endret) Kan du ikke erstatte Vista-seksjonen av grub.lst med noe slikt: title Windows Vista rootnoverify (hd1,0) chainloader +1 makeactive boot Endret 31. januar 2007 av Langbein Lenke til kommentar
olefiver Skrevet 31. januar 2007 Del Skrevet 31. januar 2007 Prøv dette isteden: title Windows Vista rootnoverify (hd1,0) chainloader +1 Lenke til kommentar
A!1 Skrevet 31. januar 2007 Del Skrevet 31. januar 2007 Hvorfor ikke bare kjøre: sudo sfdisk -fqL /dev/sdb ,,L NB! Kommandoen over var en spøk. Det ser forresten ut som Vista sitt installasjonsprogram har slått til igjen... du har bootflag på harddisk nr 0 og 2 ifølge fdisk outputten din. Jeg ville prøvd (hd2,0) i /boot/grub/menu.lst Lenke til kommentar
olefiver Skrevet 31. januar 2007 Del Skrevet 31. januar 2007 Bootflagga spiller ingen trille. Han kan ikke boote Vista fra en type 83 partisjon. (hd2,0) er nemlig /dev/sdc1. Men på /dev/sdb1 er det NTFS. I grub er det (hd1,0). Lenke til kommentar
A!1 Skrevet 31. januar 2007 Del Skrevet 31. januar 2007 @Olefiver: Jeg vet det, men jeg har sett Vista lagt bootinfoen sin på en helt annen harddisk enn det ligger på selv. Dersom (hd1,0) ikke virker, så prøv (hd2,0). - Det er ikke så godt å vite hva som virker når det kommer til vista. Lenke til kommentar
olefiver Skrevet 31. januar 2007 Del Skrevet 31. januar 2007 (endret) @HavarN Aha, skjønner. Beklager missforståelsen. Siden jeg ikke visste om dette antok jeg at du var på jordet, men du var jo midt i byen Da vet jeg om det til neste gang. Takk. Endret 31. januar 2007 av olefiver Lenke til kommentar
Skinney Skrevet 1. februar 2007 Forfatter Del Skrevet 1. februar 2007 (endret) hmm... får beskjed om at BootMGR ikke finnes... å sette (hd1,0) til (hd2,0) eller (hd0,0) fungerte heller ikke... og installasjons cd'n til vista finner ikke Vista installasjonen min... jaja, re-installasjon da Takk for hjelpen uansett Endret 1. februar 2007 av Skinney Lenke til kommentar
