Problemer med å kompilere TuxRacer
Hei!
Har lastet ned den nyeste tarballen av TuxRacer fra SourceForge, men under kompilering får jeg denne feilmeldingen:
[root@localhost tuxracer-0.61]# ./configure
loading cache ./config.cache
checking for a BSD compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking whether make sets ${MAKE}... yes
checking for working aclocal... found
checking for working autoconf... found
checking for working automake... found
checking for working autoheader... found
checking for working makeinfo... missing
checking host system type... i686-pc-linux-gnu
checking for gcc... gcc
checking whether the C compiler (gcc  ) works... yes
checking whether the C compiler (gcc  ) is a cross-compiler... no
checking whether we are using GNU C... yes
checking whether gcc accepts -g... yes
checking for c++... c++
checking whether the C++ compiler (c++  ) works... yes
checking whether the C++ compiler (c++  ) is a cross-compiler... no
checking whether we are using GNU C++... yes
checking whether c++ accepts -g... yes
checking for ranlib... ranlib
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for sys/time.h... yes
checking for unistd.h... yes
checking for working const... yes
checking whether time.h and sys/time.h may both be included... yes
checking for getcwd... yes
checking for gettimeofday... yes
checking for strdup... yes
checking for finite... yes
checking for isnan... yes
checking for _finite... no
checking for _isnan... no
checking for ieeefp.h... no
checking for Win32 platform... no
checking for X... libraries , headers
checking for dnet_ntoa in -ldnet... no
checking for dnet_ntoa in -ldnet_stub... no
checking for gethostbyname... yes
checking for connect... yes
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking for main in -ldl... yes
checking for main in -lm... yes
checking for tcl8.3 library... no
checking for tcl83 library... no
checking for tcl8.2 library... no
checking for tcl82 library... no
checking for tcl8.0 library... no
checking for tcl80 library... no
checking for tcl library... no
configure: error: Cannot find Tcl library
Jeg har skrevet
[root@localhost tuxracer-0.61]# whereis tcl
tcl: /usr/lib/tcl8.4 /usr/include/tcl.h /usr/share/tcl8.4
så jeg vet at jeg har Tcl installert.
Prøvde også med
./configure --with-tcl-name=tcl8.4
, men det hjalp ikke det heller.
Hvis noen lurte, så har allerede googla det, men fant ikke noe direkte svar. Fant en side med en som hadde samme problemet, men det stod ikke noen løsning. LinuxQuestions
