Hva er en dynamisk disk?
http://technet2.microsoft.com/WindowsServe...b27f661033.mspx
"Like basic disks which are the most commonly used storage type found on computers running Microsoft Windows, dynamic disks can use the master boot record (MBR) or GUID partition table (GPT) partitioning scheme. All volumes on dynamic disks are known as dynamic volumes. Dynamic disks were first introduced with Windows 2000 and provide features that basic disks do not, such as the ability to create volumes that span multiple disks (spanned and striped volumes), and the ability to create fault tolerant volumes (mirrored and RAID-5 volumes)."
Kort sagt gir mulighet til software raid. Vanligvis vil man ikke benytte dynamic disk hvis man vil ha muligheten til å flytte disken mellom maskiner (hvis jeg husker rett)
