trollhatt Skrevet 28. januar 2007 Del Skrevet 28. januar 2007 Hepp, dette virker kanskje som et helt idiotisk spørsmål, men om jeg vil kjøre sli/crossfire hvorav det ene kortet har artifacts, mens det andre er helt ok - vil jeg da oppleve artifacts om jeg bruker det ok kortet som primary? Lenke til kommentar
Mit Skrevet 28. januar 2007 Del Skrevet 28. januar 2007 (endret) Det vil nok det ja, vet du hva grunnen til artifactsa er? det kan være så enkelt som og reinstalere driverne. edit: du kan lese om crossfire, (fant ikke noe slikt om SLI i farta) her er de forskjellige rendering modusene: * SuperTiling: CrossFire's standard dual-GPU rendering mode. It divides the screen up like a checkerboard, allocating adjacent squares ('quads') to alternate GPUs. (To continue the checkerboard analogy, one card would render the white squares, and the other the black). SuperTiling supports all Direct3D applications (but not OpenGL). However, it provides the least performance enhancement of the four modes, a rough estimate being 1.15 times the power of a single equivalent GPU. This is due to the fact that SuperTiling does not allow the geometry of a scene to be scaled between two cards. It is worth noting that SuperTiling only works on cards that have an even number of pixel quads so a setup with an X800 with 12 pixel pipelines paired with an X800 master card will not be able to render the SuperTiling mode. * Scissor: Divides the screen into two rectangles, one above the other. This is the default operating mode for OpenGL-based applications. Unfortunately, the performance boost with Scissor mode is approximately equal to the SuperTiling mode. This render mode is more commonly known as Split Frame Rendering (SFR), which is how nVidia refers to it in SLI. In theory, SuperTiling should provide higher performance, because there is a better chance the work will be evenly divided between the two cards. Using Scissor mode means that the system has to carefully choose the "cutting point" in order to balance the load. * Alternate Frame Rendering: The fastest mode, Alternate Frame Rendering (as the name suggests) sets one GPU to render odd frames, and one the even frames. While this produces a high performance boost, it is incompatible with games using render-to-texture functions because one card doesn't have direct access to the texture buffer of the other. Like nVidia, ATI uses game profiles for Alternate Frame Rendering, and while nVidia allows you to create profiles to use AFR on any application, ATi will only allow such a change for DirectX games. * CrossFire Super AA: This mode is not designed for a large increase in frames per second; rather, it is intended to improve the quality of the frames rendered (hence 'Super AA' - super anti-aliasing). Super AA is able to double the anti-aliasing factor (eg. 4x, 8x and 12x) without any drop in framerate. du kan sikkert tenke deg sjøl hvordan det da blir med artifacts fra det ene kortet kombinert med det andre, ikke fint Endret 28. januar 2007 av Mitjmannen Lenke til kommentar
trollhatt Skrevet 28. januar 2007 Forfatter Del Skrevet 28. januar 2007 Takk for det. Har ikke 2 kort pr idag, men bare lurte på det rent teoretisk Lenke til kommentar
trollhatt Skrevet 29. januar 2007 Forfatter Del Skrevet 29. januar 2007 Et lite tilleggspørsmål; om det ene kortet ikke gir bilde, vil det da fortsatt funke å kjøre sli/cf? tenkte jeg kanskje kunne få kjørt sli/cf litt billigere ved å dra med meg et kort som bare skal scrappes hjem fra jobb Lenke til kommentar
Mit Skrevet 29. januar 2007 Del Skrevet 29. januar 2007 Tviler sterkt, kan jo si det sånn at de produserer halve bildet hver og om det ene kortet da ikke lager noe bilde blir det sikkert mye kødd, jeg vet ikke da jeg ikke har testa dette sjøl men noe sier meg at det ikke blir noe bra Lenke til kommentar
trollhatt Skrevet 29. januar 2007 Forfatter Del Skrevet 29. januar 2007 Jajo, vil si meg enig i det, men det kunne jo hende noen hadde prøvd og at det faktisk funka =) Takk for svar. Lenke til kommentar
Mit Skrevet 29. januar 2007 Del Skrevet 29. januar 2007 Ja om det skal scrappes kan du vel bare teste? hadde vært artig med noen screenshots Lenke til kommentar
trollhatt Skrevet 29. januar 2007 Forfatter Del Skrevet 29. januar 2007 Jo, det kan jeg forsåvidt - bare det å få tak på et likandes kort som funker ok først da - skal se hva jeg kan få fingra i iløpet av uka evt. de neste par dagene Lenke til kommentar
