asus striker extreme vill ikke Boote..
aoottis24
hey har et problem med mitt nye hovedkort her, i stede for og skrive opp alt som jeg har gjor så fant jeg en på asus sinn hjemme side som har akkurat det samma problemet.
hi guys ive been struggling with the board for 3 days now!
my rig:
2gb twin xms2 corsair 55512
core 2 duo e6600
asus 8800 gts
36gb raptor
coolermaster 850 real power pro
zalman 9700
im using the 8pin connector
i set up the rig and came to boot and everything turns ON all the fans spin all the lights come on and the hardrives spins too but there is no display so i read on the forum that it was something to do with ram i removed one stick and put one 1b stick in the last slot and managed to boot!
i went into bios and set the memory voltage to what my memory is that is 1.9v
for the next day everything was fine i installed xp fine and i installed all my games and played for the whole day with no problems and even installed the second stick of ram
however then when i try to start my pc after a shutdown the same thing would happen briefly it would all turn on but no display and NO POST NO BEEP before when it worked it would beep once. so after clearing cmos and removing the MB battery i got it to boot again , put my voltage on ram up again - it booted
so i came to the site and downloaded the new 8020 bios and flashed the bios succesfully
everything was fine since i gamed last night and did some 3d mark tests no problem but today in the morning i come to switch the pc on and it happens again EVERYTHing turns ON the fans are all spinning the raptor is screaming but NO display
my tft works 100% because i tried it on another pc
i tried to remove the one stick of ram again and clear cmos and do what i did before but it does NOT WORK - also again i notice there is NO BEEP any more no boot sound even if a remove all the ram to test the error beep there is no beep, but everything still looks like its on but just no display or post.
please please help i am so frustrated i dont know what to do ! there is no asus phone support for motherboards here in the united kingdom and i just dont know what to do!
some things i got on the led during the whole process:
CPU INIT
DET DRAM
DET IDE
- system time-
these would appear at different times on the led display not together just randomly
bare at jeg har Corsair Dominator 6400, core duo e6600, hyper type R 580.
noen som har noe erfaringer med dette ?
Endret av aoottis24
