kewell79 Skrevet 26. januar 2007 Del Skrevet 26. januar 2007 (endret) >> TheSpecialist (one of the hackers who worked a lot on the original Xbox (360) DVD Firmware hack) sent us an awesome new tool that will allow you to use your own new SATA HDD in your Xbox360! No more 100usd for 20GB The current tool only works with Western Digital BEVS series HDDs (20GB or larger needed) and for now you can use max 20GB, but when Microsoft will release larger drives you will be able to use as much space as Microsoft's largest HDD. Hddhacker v0.5B by the Specialist. *************************** DISCLAIMER ******************************** This tool has only been tested by me. It worked for me. While great care has been taken, this tool may contain bugs and therefore may seriously harm your HDD. Use at own risk ! *************************** DISCLAIMER ******************************** What: This tool will allow you to use HDD's that are not 'certified' by Microsoft. This specific tool is written for use with the Western Digital BEVS series only! How it works: x360 HDD's contain information on sector 16 about the HDD: the HDD serial number, the model, the firmware version and the size in sectors is stored here. The x360 asks the HDD to identify itself, by sending an 'IDENTIFY DEVICE' ATA to the HDD. It will compare the returned information to the info that is stored on sector 16. This information on sector 16 is signed and thus can not be changed. This tool will mod the FW from the WD HDD to comply with the information on sector 16, so that the 'identify' information will match the information on sector 16 and your x360 will accept the HDD as valid. How to use: Get yourself a Western Digital SATA BEVS HDD. Copy sectors 16 - 22 (7 sectors) from a valid x360 HDD to the Western Digital. Then, boot to dos (not a dos box from windows) and run this application. Make sure that you have ONLY this Western Digital drive connected to your sata controller, have the other devices disconnected. Then follow the instructions on screen. Keep in mind that you have to start the utility from a writable path if you want to create an 'undo' file (it will save it to the path you've started the tool from). Make sure that you have FIRST copied the sectors 16-22 onto the drive, BEFORE using this tool ! The tool will need that info on sector 16, otherwise it doesn't know how to mod your FW. After the tool has flashed your drive, turn off your computer, wait a few seconds, restart your computer and re-run the tool. The tool will tell you then whether the whole thing was succesful. FAQ: Q. Will this tool allow me to connect a 500 gb drive to my x360 ? A. No. The information on sector 16 is signed and can't be changed. You can only use size where you have a valid signature for. In otherwords, if a bigger HDD comes out, you can use that signature. Q. With which HDD's does this work with ? A. It should work with *ALL* Western Digital HDD's from the Scorpio BEVS series. Q. Do I need the same size WD HDD as the size on sector 16 states ? A. No. You can use bigger HDD's, but you can't use more than the size stated in sector 16. You can NOT use smaller HDD's than the size on sector 16 states. For example, you can use a 40 GB HDD with a sector 16 from a 20 GB HDD, but not the other way around of course. Q. Can I use the HDD in my PC again ? A. Of course. The tool comes with an 'undo' option, that will restore the original size. For example, you use a 40 gb WD HDD, you copied 16 sector from a valid xbox 20 gb HDD, so the tool will transform your 40 GB HDD into a 20 gb HDD. However, you can restore it to 40 gb anytime you want. The tool has the ability to create an 'undo' file, BUT this current version doesn't contain the option to flash it back. The next version will be able to do that. Just create the undo file and wait for a new version, should be out in the near future. Q. Why do I need more sectors than sector 16, if that one stores all the info? A. The following sectors contain the MS copyright logo and is checked for by the x360. Without it, the x360 will reject the HDD. Q. I have a x360 core version and want to use this hack to buy a cheap HDD. But how do i connect it? A. MS uses a specific connector. While it doesn't look too complicated to create your own, I haven't tried this myself, but I'm sure there are some creative hardware minded souls out there that should be able to think of something Q. How do I copy the 7 sectors? A. You can do so with tools like hex workshop, winhex etc. If you don't understand these tools, ask somebody who does. Q. The tool doesn't detect my HDD ! A. First, make sure you are running it from dos, not from a dos box under windows. Then, try playing with the SATA/RAID settings in your bios. Not all SATA controllers are supported. I use a VIA controller, which works perfectly. However my tool fails to see my Promise controller. I'll see if I can support more different controllers in the next version. Q. Your tool says everything was succesful but the drive doesn't work in my 360 ! A. Make sure you have copied sectors 16-22 correctly and didn't change any data. Q. Could you do this for my Seagate, Maxtor, Samsung or whatever drive too? A. Yes, but I don't have plans to do so. The cheapest WD drive (40 gb) ships for about $50 and thus is one of the cheapest. It is a lot of work to convert this tool for usage with other brands and I don't think it is worth the trouble. Q. So how do I get my 80 GB WD HDD working as 80 GB in my x360 ? A. There are 2 options: wait for a release by MS, so you can use that sector 16 (or hope that the rumours that they ARE out there already are true) OR wait for the kernel to be hacked. These are the only 2 options. Q. Where can I donate ? A. Nowhere. Just enjoy Thanks to: Team MODFREAKz for his initial logic board experiments, Loser for his findings on the sector 16 and everybody else at XBH. Endret 26. januar 2007 av kewell79 Lenke til kommentar
patham Skrevet 26. januar 2007 Del Skrevet 26. januar 2007 satt å håpte på en større disk nå men det får vel vente på seg Lenke til kommentar
UrgeLoL Skrevet 26. januar 2007 Del Skrevet 26. januar 2007 Dumt at ms gjør det så vanskelig å bytte til større harddisk. Kun for å tjene noen kr ekstra på trofaste xbox fans. Lenke til kommentar
patham Skrevet 26. januar 2007 Del Skrevet 26. januar 2007 bombe at noen måtte dra inn ordet fan da Men tror MS flippa litt med tanke på hvordan moddingen på xbox var. Der satt man jo med så mye du nesten vill tilslutt. Men PS3 sin løsning er jo å foretrekke da. Det de skulle gjort var å solgt det "kabinettet" til hardisken separat og latt oss satt inn egen disk eller noe lignende Lenke til kommentar
Straffa Skrevet 26. januar 2007 Del Skrevet 26. januar 2007 (endret) MS vil sikkert komme med en større hard disk til boksen. Arkade spill opp til 512 MB, demoer som er over 1 gig og HD filmer som kan lastes ned over live Endret 26. januar 2007 av avanore Lenke til kommentar
Tharos. Skrevet 26. januar 2007 Del Skrevet 26. januar 2007 MS vil sikkert komme med en større hard disk til boksen. Arkade spill opp til 512 MB, demoer som er over 1 gig og HD filmer som kan lastes ned over live 7803292[/snapback] Jepp, Microsoft kommer med en 200GB harddisk til 360. Med samme pris per GB som den forrige, så blir prisen rundt 8-9 tusen? Lenke til kommentar
UrgeLoL Skrevet 26. januar 2007 Del Skrevet 26. januar 2007 Hmm om ryktet er sant så kommer de med en 100 GB harddisk. Og de ligger på ca 700 kr. Så da blir sikkert microsoft sin å koste 1200-1400 kr? Men det blir bare spekulering. Lenke til kommentar
PaulKemp Skrevet 19. oktober 2008 Del Skrevet 19. oktober 2008 Bump, noen som kan bekrefte at dette virker? Sugen på å bytte ut min soon to be arriving 20 gb hdd med en på 120. Lenke til kommentar
