Forenkle, og få det til å virke....
Hei, hvordan kan jeg få det her til å virke, ?
Lurer på det med rød skrift, hva er galt, har ikke peiling på php :no:
<form method="post" name="kontakt" onsubmit=";if(self.weWysiwygSetHiddenText){weWysiwygSetHiddenText();};return true;" action="/webEdition/we_formmail.php"> <div class="weHide">
<input type="hidden" name="order" value="">
<input type="hidden" name="required" value="Name,Vorname,Strasse,Plz,Telefon">
<input type="hidden" name="subject" value="Konakt Josera Emotion">
<input type="hidden" name="recipient" value="[email protected]">
<input type="hidden" name="mimetype" value="">
<input type="hidden" name="from" value="">
<input type="hidden" name="error_page" value="/josera_emotion/error.php">
Fint hvis noen kan hjelpe meg... :cry:
<input type="hidden" name="mail_error_page" value="/josera_emotion/error.php">
<input type="hidden" name="recipient_error_page" value="/josera_emotion/error.php">
<input type="hidden" name="ok_page" value="/josera_emotion/danke.php">
<input type="hidden" name="charset" value="">
<input type="hidden" name="confirm_mail" value="">
<input type="hidden" name="pre_confirm" value="">
<input type="hidden" name="post_confirm" value="">
<input type="hidden" name="we_remove" value="">
<input type="hidden" name="forcefrom" value="">
</div>
<table border="0"><tr><td valign="top" class="text">Thema</td><td class="text"><input type="checkbox" name="Hundernaehrung" value="Hundernaehrung"></input>Hundernährung</td>
</tr><tr><td valign="top" class="text">Thema</td><td class="text"><input type="checkbox" name="Katzenernaehrung" value="Katzenernaehrung"></input>Katzenernährung</td>
</tr><tr><td valign="top" class="text">Bemerkung</td><td valign="top" class="text"><textarea name="Bemerkung" cols="40" rows="5">
</textarea></td></tr><tr><td valign="top" class="text">Name*</td><td valign="top" class="text">
<input type="text" name="Name" size="40" maxlength="100" value=""></input></td></tr><tr><td valign="top" class="text">Vorname*</td><td valign="top" class="text">
<input type="text" name="Vorname" size="40" maxlength="100" value=""></input></td></tr><tr><td valign="top" class="text">Straße, Hausnummer*</td><td valign="top" class="text">
<input type="text" name="Strasse" size="40" maxlength="100" value=""></input></td></tr>
<tr><td valign="top" class="text">PLZ*</td><td valign="top" class="text">
<input type="text" name="Plz" size="5" maxlength="100" value=""></input></td></tr>
<tr><td valign="top" class="text">Ort*</td><td valign="top" class="text">
<input type="text" name="Ort" size="40" maxlength="100" value=""></input></td></tr>
<tr><td valign="top" class="text">Telefon*</td><td valign="top" class="text">
<input type="text" name="Telefon" size="40" maxlength="100" value=""></input></td></tr><tr><td valign="top" class="text">Fax</td><td valign="top" class="text">
<input type="text" name="Fax" size="40" maxlength="100" value=""></input></td></tr><tr><td valign="top" class="text">Mobil</td><td valign="top" class="text">
<input type="text" name="Mobil" size="40" maxlength="100" value=""></input></td></tr><tr><td valign="top" class="text">E-mail</td><td valign="top" class="text">
<input type="text" name="Email" size="40" maxlength="100" value=""></input></td></tr></table><p><input type="submit" name="simpleformbutton1" value="Absenden" />
<input type="reset" name="simpleformbutton2" value="Zurücksetzen" /></p></form><p><font class="text">* = Pflichtfelder</font></td></tr></table>
</td>
<td> </td>
<td width="177" valign="top" align="right">
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
Ikke allverden peil på javascript, er et godt å siden sist jeg var borti det, men:
Dette ser ut som et metodekall/funksjonskall til en funksjon jeg ikke kan se at du har i koden din her. Om du har kopiert dette fra et eller annet sted kan det være noe du ikke har fått med deg.
Raskt overblikk ser dette ut som et skjema som fylles ut, når man klikker send sjekkes en variabel og alt etter verdien av denne og innholdet i metoden nevnt over bestemmes det om skjemaet skal sendes eller ikke, dvs om man kommer videre til neste side eller ikke.
Edit:
Hvilken funksjonalitet er du ute etter her? Har du prøvd å bare fjerne denne:
og sjekket om det funker for ditt behov?
Endret av Ekko
Edit:
7796222[/snapback]
funka ikke å fjerne den...noen som har et annet formmail jeg kan bruke ?
:ph34r:
