Varj Skrevet 29. november 2002 Del Skrevet 29. november 2002 Saksa fra Anandtech. Quote: Two more "new" products ThermalTake had to show off included their new SubZero4G peltier cooler. The idea of peltier cooling is hardly new, but the problems plaguing peltiers today revolve around their generation of condensation. ThermalTake, with the help of ActiveCool solved this problem by using a PCI adaptor to control the partier’s degree of cooling based on the dew point in that particular condition. ActiveCool boasts the new 4G peltier is capable of cooling both K7 and K8 processors down to 26C while operating around 28dBA. The PCI card has an onboard microprocessor and thermometers to detect miniscule changes in atmosphere pressure, temperature, and humidity. This way, the PCI card never lets the peltier get below the dew point of the particular environment and no condensation is created. We are slightly wary of this technology, but if it proves to be stable and reliable, ActiveCool/ThermalTake might be taking a step in a relatively inexpensive cooling. Bildet her: http://images.anandtech.com/reviews/shows/...ctivecool1l.jpg Lenke til kommentar
b-real Skrevet 29. november 2002 Del Skrevet 29. november 2002 Sikert ei stund til siden den bare hittil har blitt lansert bare på comdex så vidt jeg har fått med meg. Tipper 2-3 måneder. Lenke til kommentar
|Cipher| Skrevet 29. november 2002 Del Skrevet 29. november 2002 Kan noen si meg hva slags kjøler som var på det kortet? Så spennende ut.. Lenke til kommentar
JohndoeMAKT Skrevet 29. november 2002 Del Skrevet 29. november 2002 Tror nok heller det er ribba som blir kjølt. Lenke til kommentar
|Cipher| Skrevet 29. november 2002 Del Skrevet 29. november 2002 Åh, Fa*n, så ikke helt opsettet der nei.. :sad: Trodde det var 2 forskjellige kjølere, en til kort og en til prosessor... Lenke til kommentar
